1997 4runner idle problem - TTORA Forum
post #1 of 16 (permalink) Old 04-24-2008, 08:03 PM Thread Starter
This is a 1997 4runner, 3.4L, 5speed, and its having idle issues.
Symptoms are, upon start up, the idle sits at normal 8-900 range. Then, it will jump to 1200 ish, and back down to 800-900. Tapping the gas will stick the new idle at 1800.
Any thoughts? This truck needs to be ready to run to Moab Saturday AM. Any help would be greatly appreciated.
Thanks!
Generation Dead
post #2 of 16 (permalink) Old 04-24-2008, 08:29 PM
Blowntaco's Avatar
Thanks!
Maybe sticky throttle plate or TPS? Just a couple ideas. Dunno without seeing the truck
Blowntaco is offline
post #3 of 16 (permalink) Old 04-24-2008, 10:24 PM Thread Starter
Right now, thinking this is an idle air control valve problem
Throttle body etc was recently removed and cleaned. Thinking something got hosed whilst in there.
Generation Dead
post #4 of 16 (permalink) Old 04-24-2008, 10:26 PM
I've seen a couple throttle bodys worn and sticking throttle plates. Milage is around 180-220k, they were both t100s though.
Could be a IAC also, 1st startup should be over 1200rpms.
post #5 of 16 (permalink) Old 04-24-2008, 10:28 PM
Just seen the second post, Cleaning the IAC is usally a nail in the coffin. Those things are touchy. I would try to find a cheap used throttlebody assembly.
post #6 of 16 (permalink) Old 04-24-2008, 11:38 PM Thread Starter
oh, thats not going to make the old man happy. (his truck)...LOL.
Thanks Brian. Thanks all, good stuff. Its the old man, so he'll go new. Unlike me, he makes a shit ton o money.
Generation Dead
post #7 of 16 (permalink) Old 04-24-2008, 11:44 PM
Vacuum leak? Like maybe something didn't get hooked up quite right?
O2 sensor wiring? (That's what was causing my erratic idle)
post #8 of 16 (permalink) Old 04-25-2008, 12:21 AM Thread Starter
Possible. Not likely though. Vacuum seems to be in order. O2 is possible. However, I've posted on lots of forums, and the IAC is a popular candidate.
Also, doesn't O2 usually throw codes?
Generation Dead
post #9 of 16 (permalink) Old 04-25-2008, 09:22 AM
Yeah, don't mess up those 4 vacuum line the 5vz has
O2 sensors can be funny. The voltage swing and wavelenght can degrade enough to act funny but not set a code. Fuel milage is first to go when this happens.
Blown taco might have seen somthing different with TPS sensor. I have just seen them stumble on acceleration. These sensors are bad about setting a code also.
post #10 of 16 (permalink) Old 04-25-2008, 09:33 AM
Yeah, my O2 sensor was bad for a long time before throwing a code.
post #11 of 16 (permalink) Old 04-25-2008, 11:34 AM
Denver Dave's Avatar
I've been fighting a similar problem for over a year.
What did you do (if anything) to start the problem?
When you push the throttle closed manually does it go back down to normal? Mine did and I attached a spring to the plenum to hold the throttle closed more tightly.
My mechanic said I needed a new throttle body and I've replaced everything associated but that. Everything is working fine for now.
2001 Taco TRD SR5 XtraCab
5-vee-zee-eff-eeeeeeee
Denver Dave is offline
post #12 of 16 (permalink) Old 04-25-2008, 02:42 PM Thread Starter
cleaned the throttle body.
That seems to have screwed the pooch.
Generation Dead
post #13 of 16 (permalink) Old 04-25-2008, 05:48 PM
Blowntaco's Avatar
That was my first gut feeling, seen that many times
post #14 of 16 (permalink) Old 04-25-2008, 11:37 PM Thread Starter
Its fixed.
Looks like it was the IAC, but who knows. Screwed with it and it started working. Drove it a bunch, it worked. Got a spare in case it craps out.
Generation Dead
post #15 of 16 (permalink) Old 04-26-2008, 12:14 AM
Blowntaco's Avatar
Ok....so I was wrong. Damn. Glad you got it fixed Sorry wasn't better help
post #16 of 16 (permalink) Old 04-26-2008, 01:35 AM Thread Starter
Dude! no worries. We checked all of the things you suggested. Just didn't turn out to be them. But I'm grateful for ALL the help!
Generation Dead
Idle problem on 3.0l crazymanz28 Pickup/Early 4Runner Tech 3 04-30-2007 04:34 PM
idle problem 01yota Performance/Engine/Exhaust 11 01-24-2007 06:22 PM
Idle Problem. SnellRules Early Tacoma Tech 5 09-09-2006 04:42 PM
idle problem joshtpa111 Early Tacoma Tech 1 06-17-2006 07:17 AM
Idle problem prezidentredz Early Tacoma Tech 6 03-22-2006 10:31 PM
