4wd not engaging - TTORA Forum
post #1 of 30 (permalink) Old 05-12-2008, 10:19 AM Thread Starter
4wd not engaging
My buddy just picked up an 88 4runner with ADD, and the 4wd is not engaging. The light on the dash turns on and the transfercase will shift into low, but the front wheels do not get engaged. I searched alittle, but am feeling lazy. what are the normal culprits that cause this as i have never had this problem with a toyota before. Thanks in advance for any help.
post #2 of 30 (permalink) Old 05-12-2008, 11:49 AM
Thats why I love the manual hubs.
ziggy428 is offline
post #3 of 30 (permalink) Old 05-12-2008, 11:53 AM Thread Starter
I know, i need to convert the taco soon. I just want to figure this out for my buddy so we have another yota out on the trails. He made sevenmile in 2wd this weekend, but he needed several pulls.
post #4 of 30 (permalink) Old 05-12-2008, 02:46 PM
If the light comes on, the ADD is actuating, and it's in 4WD. (The light is positively switched by the throw of the little collar)
If it's ADD, then he has splined flanges, not "auto" or any other kind of movable hub.
Most likely culprit is a broken CV and the open diff just sends all the power to that side. If you jack up the truck (both front and back or remove the rear driveshaft and jack up the front) is the driveshaft spinning?
post #5 of 30 (permalink) Old 05-12-2008, 02:47 PM
Does the T-case lock into 4wd? Have someone watch the front drive shaft to see if it spins while driving slow in 4wd... Dont run over his/her head
cchark is offline
post #6 of 30 (permalink) Old 05-12-2008, 03:26 PM Thread Starter
Will do tonight. I will post up what i find.
post #7 of 30 (permalink) Old 05-12-2008, 03:31 PM
If you turn one drive shaft off the ground then both should turn if its in 4wd right? I would think a broken cv would be really noticeable but maybe I'm wrong. Then while its jacked up the wheels should turn in opposite directions.
ziggy428 is offline
post #8 of 30 (permalink) Old 05-12-2008, 05:23 PM Thread Starter
yeah i didnt think cv either because it drives perfectly normal with no noises from the front end, but it doesnt hurt to look in that direction either.
post #9 of 30 (permalink) Old 05-12-2008, 05:46 PM
When you went wheelin, did you ever see a front tire spinnin?
Check the front DS thing... Having someone to watch it spinning while driving in 4wd is the simple way IMO... Should turn = to the rear
From there you either have-
Tcase linkage issues
Tcase is fukked
Broken CV- Could be at one of the shafts far inside or out. Even then, if the boot clamps are tight, it should have torn a boot open spilling grease. Maybe youre lucky
Front spider or ring/pinion gears went kaabooom. Pull the drain plug and look for fun chunks.
cchark is offline
post #10 of 30 (permalink) Old 05-12-2008, 05:58 PM Thread Starter
we noticed it when attempting a fairly easy hill. you would be in 4 low and sit there spinning one rear tire and no front tires.
post #11 of 30 (permalink) Old 05-12-2008, 06:57 PM
Are the 88's vacuum actuated? I would check vacuum and the solenoid too. Newer trucks the 4wd indicator is plugged into the actuator as well as t-case.
ziggy428 is offline
post #12 of 30 (permalink) Old 05-12-2008, 07:14 PM Thread Starter
I believe it is vacum actuated. Those were my first two thoughts and still items i am going to look at. It doesnt look like our schedules will match up until sunday though, so i will have to wait until then to take a look at anything.
post #13 of 30 (permalink) Old 05-12-2008, 09:41 PM
Believe me - if the light comes on, the vacuum actuation is working. The other not unheard of failure is one of the stub shafts INSIDE the diff.
This might help - it's the FSM for a '93 truck, yours should be the same:
http://personal.utulsa.edu/~nathan-b...onandaxle.html
post #14 of 30 (permalink) Old 05-12-2008, 09:59 PM
88 versions were not ADD. He has those crappy auto hubs. I'd look at those first.
post #15 of 30 (permalink) Old 05-12-2008, 10:20 PM
Well, there ya go ...
post #16 of 30 (permalink) Old 05-12-2008, 11:56 PM
ziggy428 is offline
post #17 of 30 (permalink) Old 05-13-2008, 09:00 AM
sport4x4runner's Avatar
Send a message via Yahoo to sport4x4runner
FAtkid is right....
THose 88 some were transition model between add and auto hub. The auto hubs are notorious in the yota shops for being POS. best bet, go with warn or asin manuals...not too expensive but much more reliable.
I understand the Jeep thing, That's why I drive a Toyota!!! HA HA HA!!!
sport4x4runner is offline
post #18 of 30 (permalink) Old 05-13-2008, 02:07 PM
I've Heard that the Aisin oem hubs are the better than Warn. no personal experience though.
ziggy428 is offline
post #19 of 30 (permalink) Old 05-13-2008, 02:26 PM
I run warn hubs on my '90 V6, not a problem whatsoever... I have a friend with an 89 that we swapped the auto-hubs for the asin hubs, went nice and smooth, they work perfectly....
post #20 of 30 (permalink) Old 05-13-2008, 03:38 PM
ToyRunner1's Avatar
My 87 was swapped to Superwinch hubs. I've had no problems at all, but I do prefer the Aisins for the offroad rig.
ToyRunner1 is offline
post #21 of 30 (permalink) Old 05-13-2008, 10:42 PM
I have Warns - only issue is they stick out further.
post #22 of 30 (permalink) Old 05-17-2008, 04:06 AM
poorboyota26's Avatar
ASIN keep it toyota
86 runner
poorboyota26 is offline
post #23 of 30 (permalink) Old 05-25-2008, 09:25 PM Thread Starter
Finally got under this runner. Everything works up to the hubs. Will the manual hub just replace the auto hub assembly, or will i have to change out anything else? Anyone want to help out in a week or so?
post #24 of 30 (permalink) Old 05-25-2008, 10:53 PM
from the looks of it you have to tear everything out of the spindle to the cv shaft.
http://www.yotatech.com/~corey/tech/matt_hubs/matt_hubs.htm
ziggy428 is offline
post #25 of 30 (permalink) Old 05-26-2008, 07:06 AM
Ummm ... your link and the photo aren't for the same thing. The link is for a preTaco with ADD. Seriously, it takes longer to remove the wheels than it does to swap from the ADD plate to manual hubs.
The picture are the parts to convert a Taco or 3rd gen 4runner. All the extra parts are because the ADD on those is semi-floating and the manual hubs are full floating.
Unfortunately, this has limited use to the OP. His will be closer to what the link says, but I think he needs a few more parts than just the hubs to replace the automatic hubs.
post #26 of 30 (permalink) Old 05-26-2008, 09:03 AM Thread Starter
I will start researching. In the meantime anyone who has done this to an 88 post up and let me know what you needed.
post #27 of 30 (permalink) Old 05-26-2008, 11:09 AM
You need everything ouside the bearings.
washer, nut, keyed washer, nut, then your new hub. Warn sells it as a kit or you could pick it up from toyota.
post #28 of 30 (permalink) Old 05-27-2008, 06:32 AM Thread Starter
what would the damage be from toyota?
post #29 of 30 (permalink) Old 05-27-2008, 08:59 AM
I'm not at work today.
If your getting junkyard hubs you might as well get the nuts and washers there. Don't forget the big socket.
post #30 of 30 (permalink) Old 05-27-2008, 09:33 PM
Wasn't sure if it was full or semi, which gen is an 88? 1st? So his should be pretty easy then.
ziggy428 is offline
4x4 not engaging hockeyplayer4 Early Tacoma Tech 10 04-22-2008 08:25 AM
4lo not engaging BOVADS Pickup/Early 4Runner Tech 10 05-01-2007 04:38 PM
4WD H Not engaging no buzzer 4WDProf Newbie Tech 3 11-22-2006 11:49 AM
4wd automatically engaging ktulu1115 Newbie Tech 19 04-15-2006 07:38 PM
TRD Locker not engaging..? LabradorBoy Early Tacoma Tech 5 07-03-2005 05:59 PM
