Runner wont shift - TTORA Forum
post #1 of 6 (permalink) Old 06-09-2008, 02:20 PM Thread Starter
SP!N4L T4P's Avatar
Runner wont shift
my buddy was doing some maintenance on his 92 Runner where he had to disconnect the clutch line. he bled it after he was done but for some reason he's not able to shift gears while the engines running. he bled it again just to make sure, but still it wont shift. any ideas what the problem is?
88' 4Runner: 3.4L, 4" lift, rear Detroit, 33's, 4.88s, sliders, soft-topper,
SP!N4L T4P is offline
post #2 of 6 (permalink) Old 06-09-2008, 11:05 PM Thread Starter
SP!N4L T4P's Avatar
anyone...?
post #3 of 6 (permalink) Old 06-10-2008, 12:07 AM
Sounds like there is still air not allowing the slave cylinder to work!?!
-Keep bleeding the system. Is he getting good flow out of the bleeder?
-Make sure ends are tight- No leakage
-Pull the slave end and make sure you dont have something blocking the line
-Could be a fluke and the slave decided it was time to crap out.
cchark is offline
post #4 of 6 (permalink) Old 06-10-2008, 08:31 AM
poorboyota26's Avatar
x2
also check that the clutch fork didn't pull loose and that it will still move the throw-out-bearing.
when I bled mine a few weeks ago I had to set in the truck and push in the clutch repeatedly for about 30 min to get all the bubbles out. every time I pushed in the clutch and released it I would see bubbles come out of the res. worked pretty good.
86 runner
poorboyota26 is offline
post #5 of 6 (permalink) Old 06-10-2008, 09:45 AM
Those are common to break the clutch pedal braket. If that is broken it will not release the clutch. The break on the farthest left side at the bottom.
post #6 of 6 (permalink) Old 06-10-2008, 10:01 AM Thread Starter
SP!N4L T4P's Avatar
well when he was bleeding it he told me all he saw coming out was a solid steady stream, so im pretty sure there isnt any air in there. and i doubt he would miss a leak as he is pretty thourough about this stuff. i mentioned the clutch fork to him, but is there a quick way to check it so the bellhousing doesnt have to be separated from the engine?
1994 4 runner pre runner with tundra one peace fiberglass full kit IM BIGGER For Sale/WTB in OR 1 04-23-2008 09:41 AM
front shift to top shift MandAtaco Pickup/Early 4Runner Tech 2 10-24-2007 04:38 PM
03 DCab 4x4 shift knob/shift length Tacobike Early Tacoma Tech 0 08-18-2005 07:05 AM
wont shift b/c of the s/c? help[ 00trdtaco Performance/Engine/Exhaust 8 02-04-2005 05:38 AM
wont shift to second at high rpms.?? 00trdtaco Early Tacoma Tech 2 01-27-2005 12:23 PM
