Timing Belt/Water Pump Tool Help ASAP - TTORA Forum
post #1 of 14 (permalink) Old 06-30-2008, 07:16 PM Thread Starter
Hi,
93 4runner V6
I am attempting my timing belt and water pump and I need a few tools. It looks like I need a tool to hold the crankshaft pulley so I can loosen it, a puller for it, and another tool to hold the cam pulleys to losten the timing belt.
Does anybody in/near Denver have these that I can borrow?
Thanks
05 Taco
dirtyXplorer is offline
post #2 of 14 (permalink) Old 06-30-2008, 09:49 PM
Sounds like a job for a HOW, but i dont know if you can wait until the next one is scheduled. I personally dont have any of the special tools that you need.
post #3 of 14 (permalink) Old 07-01-2008, 07:08 AM
The Last Marshall
DriftinCO's Avatar
Send a message via AIM to DriftinCO
I rely on the expert skills of our master techs on here to do that kind of work. Mainly because he does great work, I don't have the right tools, and we get to visit while he's knocking out the task with really cool air tools and other gizmos that make an otherwise challenging task seem really easy. And his time is quite affordable!
Over 50 years of quality products.
http://http://www.amway.com/
BrianKellyGauck
DriftinCO is offline
post #4 of 14 (permalink) Old 07-01-2008, 12:52 PM
PM blowntaco (Daryll) or thefatkid (Brian)
post #5 of 14 (permalink) Old 07-01-2008, 04:17 PM Thread Starter
Thanks for all your reply's. I almost have everything apart and I ended up making one of the tools. I have never done a job like this but its fun and everything is going smoothly.
05 Taco
post #6 of 14 (permalink) Old 07-01-2008, 05:42 PM
Then you must not be doing it right
Those timing belts are a pain in the butt. Out of curiosity, what did you use to hold the crank pulley still while you unbolted it?
post #7 of 14 (permalink) Old 07-02-2008, 07:48 AM Thread Starter
I can post some pictures this afternoon but I bought a little piece of flat stock for Lowes and drilled two holes in it. then I put one side under the frame rail and bolted the other side to the pulley. It flexed alittle but worked pretty good.
05 Taco
post #8 of 14 (permalink) Old 07-02-2008, 08:56 AM
Yeah, pix would be good if you don't mind. I had the kind of the same idea in mind. I have some flat stock and was thinking of drilling 2 holes, then cutting out a center hole to fit the socket thru. Not sure how I'm going to cut thru this 1/4" stock tho (no plasma torch at my disposal).
post #9 of 14 (permalink) Old 07-02-2008, 09:01 AM
Looks like you need to add a plasma cutter to your list of things to buy
post #10 of 14 (permalink) Old 07-02-2008, 12:49 PM Thread Starter
My problem now is lining up the belt. I can get it on and point all the marks an the sprokets at 12 oclock but the FSM says there should be a mark on the belt by the lower timing cover that lines up with the edge and there is not there. Does anybody know a good method of lining everything up coprectly? I really dont want to put everything back togather and have to take it back apart.
Thanks
05 Taco
post #11 of 14 (permalink) Old 07-02-2008, 07:40 PM
I was gonna say when I did mine I didn't need any specialty tools...
The mark on the belt is optional - just line up the marks on the cam sprockets
post #12 of 14 (permalink) Old 07-03-2008, 09:30 AM Thread Starter
Thanks RedRunner. I got the mark on the belt lined up but when I rotate the engine twice to chech the alingment it always seems to get off one tooth on the two cam sprockets. Do I need to ad tension to the belt when I rotate the engine?
05 Taco
post #13 of 14 (permalink) Old 07-03-2008, 09:37 AM Thread Starter
Here is what it looks like. Its kind of thin but it held the 181Ft-lb good.
05 Taco
post #14 of 14 (permalink) Old 07-03-2008, 09:42 AM
oh, this is a 3.0!.. heh... was thinking 3.4 Thanks for the pix anyway
When to change the timing belt and water pump? The Grayt 1 PreRunner Tech 5 05-28-2008 12:37 AM
Timing Belt + Water Pump Advice? MtnM Newbie Tech 5 05-19-2008 08:17 AM
timing belt/water pump sac5.0 Off Topic 1 04-15-2008 11:19 AM
Timing Belt, Water Pump...Oh yeah bagal General Discussions 0 02-15-2007 10:10 AM
Getting parts for timing belt, water pump eng208 Performance/Engine/Exhaust 5 12-29-2005 06:01 PM
