My driver window wont go up!!! Help! - TTORA Forum
post #1 of 7 (permalink) Old 07-17-2008, 12:02 AM Thread Starter
Exclamation My driver window wont go up!!! Help!
Hi,
93 4runner 4 4door SR5
I just tried to roll up my window after running out and nothing...I checked the fuses and everything looked good...I pulled out the master switch and cleaned the contacts...nothing. I live at an apartment complex so I need to get the window rolled up and its already past 10 pm. Anybody know how to get the window up?
Thanks
05 Taco
dirtyXplorer is offline
post #2 of 7 (permalink) Old 07-17-2008, 10:30 AM
Is the window lock button pressed?
post #3 of 7 (permalink) Old 07-17-2008, 01:38 PM
check to make sure the wires in the boot running from the firewall to the door are good, and the plug there isnt loose.
My car has this issue, where the window will randomly quit working and its because one of the clips on that plug finally snapped off so every once in awhile my windows quit working and i just have to push on that plug a little and its fine for another 3-4 weeks.
post #4 of 7 (permalink) Old 07-18-2008, 08:44 AM Thread Starter
I ended up pulling the pannel and I am getting power to the motor when I roll up and down the switch. I took the motor off and it only goes down and does nothing when I apply power for it to roll up. I am guessing the motor is dead since I am sending it power and its doing nothing. If it was dead would it still work in only one direction?
05 Taco
post #5 of 7 (permalink) Old 07-18-2008, 09:31 AM
possibly, depends on how the motor failed.
post #6 of 7 (permalink) Old 07-18-2008, 12:36 PM Thread Starter
I am planning on trying to pick one up from yotayard and trying it out. It does not look like the motors are serviceable...New one are quite pricey
05 Taco
post #7 of 7 (permalink) Old 07-18-2008, 07:25 PM
I think that was just gravity at work if it only goes down?
ziggy428 is offline
rear driver window mgoose82 Maintenance & Parts 0 05-14-2008 07:43 PM
power window motor, driver side LILTACO Wanted 1 10-15-2007 03:42 PM
driver side window air leak silvertaco613 Late Tacoma Tech 1 05-11-2006 02:46 PM
Dana 44 Driver Side Drop/Driver side Flat Top Knuckle TACORICAN Parts/Electronics/Wheels/Tires 19 10-07-2005 12:48 AM
