E-brake ideas - TTORA Forum
post #1 of 7 (permalink) Old 01-01-2009, 05:42 AM Thread Starter
vwfastg60's Avatar
E-brake ideas
So i have a few choices with the truck. I can either replace the stock E brake OR i can do something like this
http://www.spidertrax.com/s.nl/it.A/...2&category=215
What do you guys think? I want a reliable E brake and Will have to add a bracket on the frame that was part of the Tbar mounting but i will have to fab something up for this...
Anyone use one before? The cost is about the same for a used cable from a yard or to buy this. I cant afford a driveline ebrake right now so this will be the answer for now.
87 Dlx Longbed mall crawler
93 c3500 lowerthanstockdually
vwfastg60 is offline
post #2 of 7 (permalink) Old 01-01-2009, 08:21 AM
I have heard of people using them before, but it doesn't seem right to me ... what if the pressure bleeds down? What if you have a hydraulic issue? The thing to me about the mechanical ebrake is that its basically a redundant system - pretty much no matter what happens, you have SOME brakes.
Here's another thing though ... with as built as your truck is, you REALLY need to consider a full-float conversion on the rear axle, and that will require some consideration of a driveline ebrake too...
post #3 of 7 (permalink) Old 01-01-2009, 12:54 PM
devinsixtyseven's Avatar
looking for an emergency brake or a parking brake?
1st one needs to be completely separate from the service hydro system
line locks will work fine for a parking brake.
i've had to use the mechanical e-brake on my truck in an emergency. very few emergency brakes will hold a truck with big tires on a steep hill and nothing works as well as big oem drum brakes.
are you only missing a cable, to hook up your existing mechanical brake?
devinsixtyseven is offline
post #4 of 7 (permalink) Old 01-01-2009, 01:05 PM Thread Starter
vwfastg60's Avatar
More of a parking brake. The cable on my set up now was torn in half almost a year ago when my U bolt broke, So now i can pull it but if the lockers not on the truck rolls still.
post #5 of 7 (permalink) Old 01-01-2009, 10:27 PM
y not just replace that cable?
post #6 of 7 (permalink) Old 01-02-2009, 03:08 AM Thread Starter
vwfastg60's Avatar
They always seem to be gone or cut at yards and even when they work they dont seem to work well with heavy rigs. I may wind up doing it tho cause i was looking at it and running the brake line under the drivers side is going to be a pain.
post #7 of 7 (permalink) Old 01-02-2009, 09:57 AM
For yours, all of the cables should be avalible at Napa. I cant seem to find any of them for the 79 though, everyone claims they dont have them anymore.
rear brake line and park brake help KRYPTO(dale) Early Tacoma Tech 3 11-21-2008 01:10 AM
TRD Performance Brake Pads vs. Factory Brake Pad TACOMA03 Performance/Engine/Exhaust 8 07-14-2008 12:22 AM
Brake light on when i brake hard? Anthony Sordi Early Tacoma Tech 11 01-12-2008 10:24 AM
Fab Ideas hlracing69 Fabrication/Tools 44 11-29-2007 12:03 AM
Wierd Brake warning light issue - any ideas? Jamier2 Newbie Tech 18 09-28-2006 03:40 PM
