Clutch starting... - TTORA Forum
post #1 of 5 (permalink) Old 02-08-2009, 01:05 PM Thread Starter
Clutch starting...
When it rains, it pours, first my door, then my breaks now my 98 taco wont start when you push the clutch to the floor. is there a micro that is involved?
thank heavens there is a clutch start cancel button.
as always, thanks for the help...
Duplexx is offline
post #2 of 5 (permalink) Old 02-08-2009, 01:49 PM
Sounds like the contacts are not closing for the clutch saftey switch down by the pedal.
post #3 of 5 (permalink) Old 02-08-2009, 04:45 PM
Gerdo's Avatar
Yes, there is a switch mounted on the clutch pedel. It must be out of adjustment. Did you just get new floor mats?
2000 4Runner.
Gerdo is offline
post #4 of 5 (permalink) Old 02-08-2009, 05:52 PM
It starts with the clutch start cancel? The clutch disengages properly and no issues shifting gears?
post #5 of 5 (permalink) Old 02-09-2009, 10:05 AM
Well first of all, make sure that your foot is all the way to the floor, as far as it can possibly go. I know that sounds simple, but I've made that mistake where I was just far enough off for the switch not to contact. Then check under your dash and make sure that the clutch pedal is contacting the switch, and making it go in all the way. If it is, test the switch with a continuity tester. Unplug it and put a probe on either side of the switch. The needle type probes help for this.. Push the switch manually, and it should indicate continuity, and then no continuity when you let go. Just by doing that, I would guess that you will find the problem. If not, let us know.
96 3.4 not starting lilbuddy Early Tacoma Tech 3 11-03-2008 01:22 PM
Did a clutch job, now clutch engages too soon / low? SuaveGato Pickup/Early 4Runner Tech 10 06-19-2008 04:57 PM
Problem with clutch/clutch pedal bpina4813 Pickup/Early 4Runner Tech 12 01-12-2007 10:18 PM
I am starting to get pissed off.... clutch isses. rojodiablo Early Tacoma Tech 13 09-26-2006 05:42 AM
Clunk when letting out the clutch and starting off in 1st.... The Dude Early Tacoma Tech 7 11-15-2005 12:01 AM
