Turn Signal Problems - TTORA Forum
post #1 of 12 (permalink) Old 02-15-2007, 09:54 PM Thread Starter
kirk1005's Avatar
I am having problems with my drivers side turn signal. When my headlights are off, they work perfectly. When I turn the headlights on, the blinker light stays on in cab and both the front and rear lights stay on continuously. I have changed the bulbs, but am at a loss for what to do next. I'm not very good with vehicles, but am trying to learn. Any help would be much appreciated. Thanks.
kirk1005 is offline
post #2 of 12 (permalink) Old 02-15-2007, 10:43 PM
HoT_DoGgIN's Avatar
Send a message via AIM to HoT_DoGgIN
sounds to me like you have a cross somewhere... trace your positive leads between your headlights and turn signals, and see if they aren't touching/rubbing etc to the point that current can flow through both?
1998 Toyota Tacoma 2.7L 4wd Xtra Cab
~K&N FIPK Gen II Cold Air Intake
~3" Cornfed Suspension Lift
~Marlin Crawler Heavy Duty Clutch
~Chevy Tow Hook Mod
~Hella FF75 Lights & Custom Bumper Brackets
~Firestone Destination M/T's
~Lit Holiday Wreath/Grille Mod with Bow!! (xmas season)
~Wolo EC Challenger dual trumpet Air Horn -
HoT_DoGgIN is offline
post #3 of 12 (permalink) Old 02-15-2007, 10:49 PM Thread Starter
kirk1005's Avatar
Thanks, if they are, what is the fix? Thanks again.
kirk1005 is offline
post #4 of 12 (permalink) Old 02-16-2007, 12:40 PM
blown4runner's Avatar
fix the wire... What is probably happening is exactly as was stated above, you have some electrical interference backfeeding into the system. Trace the wires and look for damage, signs that someone has been wiring aftermarket accessories in, anything not factory or broken in association with the circuit... then repair the wire(s) appropriately. You'll need a multimeter, EWD for that systems circuit and a basic knowledge of how electricity works to start... and maybe some extra wires, electrical tape, a set of dykes, some solder and soldering iron, etc once the problem has been found
blown4runner is offline
post #5 of 12 (permalink) Old 02-16-2007, 07:03 PM
ooo oooo i know this one and nicole doesn't. you have a trailer wiring setup on your truck. these usually go bad after a while ( it converts your brake and turn lights into one light.) when they short out you will see all sorts of crazy things happen. running lights on with the brakes and yada. if it is aftermarket look along the frame on the drivers side by the rear. it should just be tagged onto the nessecary wires. cut and remove( and replace if you need it) if it is factory you might want to check the FSM for your truck but it is usually behind the seat or under the xtra cab portion.
post #6 of 12 (permalink) Old 02-16-2007, 08:06 PM
yeah Rich... I know about that. Remember when Dan came out to Denver and I fixed his taillight problem... it has EVERYTHING to do with the trailer wiring. I was being generally vague because I try not to get too specific in diaging vehicles 3 states away with a bare minimum of info... lol! The harness ecu (if dealer or factory installed) will be under the LF seat on an xtra cab and behind the left side of the rear bench seat on a DC... hehehehe
silly, silly Rich... you may be god with the special Nicole decoder ring but I do know some things every once in a while.... *long pause* I think
Originally Posted by Mike
I would appreciate if you would find the nearest firearm, shove it in your mouth, and pull the trigger.
Originally Posted by Wes
Seriously, quit stalking me. I'm shy and violent.
sexy.taco is offline
post #7 of 12 (permalink) Old 02-16-2007, 11:42 PM
every once in a very long ass while lol
post #8 of 12 (permalink) Old 02-17-2007, 04:55 PM
speaking of which, I am not sure when that last time was... lol!
post #9 of 12 (permalink) Old 02-17-2007, 06:40 PM
lol you might be coming up pretty soon again then lol
hows that fix going kirk?
post #10 of 12 (permalink) Old 02-20-2007, 11:24 AM
I guess I had a good day... lol! So hows the snow and cold in Colorado, I was out on the SF bay yesterday cruising around Alcatraz and stuff in my friends' very large boat enjoying the mid 70 degree sun!!!
post #11 of 12 (permalink) Old 02-22-2007, 03:01 PM Thread Starter
kirk1005's Avatar
I found a wire that had come completely out of the trailer wiring harness. I'm pretty sure this is the problem, but havent tried to work with it yet. Thanks for all the advise everyone, will keep you posted on what happens when I try to fix it this weekend...
kirk1005 is offline
post #12 of 12 (permalink) Old 04-17-2007, 09:22 AM Thread Starter
kirk1005's Avatar
I fixed..
the light issue I was having. After messing with it for almost 2 months, I finally got a fix. It was pretty expensive, but a needed fix for multiple problems. I traded in my Taco for a 2002 4Runner. It killed me to do it because I loved my PreRunner, but I needed the extra seat in the back for my 3 year old. I really didnt like her riding in the front seat anymore. Thank you all for the advice.
kirk1005 is offline
anyone else having window problems? amishclark Newbie Tech 5 06-29-2006 12:04 PM
How to turn off ABS on 04 Gregoma Early Tacoma Tech 22 12-29-2005 03:45 PM
Key won't turn past ACC! CuriousJ0N Early Tacoma Tech 40 10-28-2005 08:49 PM
frt turn signal relocate farakon Newbie Tech 2 10-07-2005 09:13 AM
My turn signal stays on! 4-Bangerfromtheburg Interior/Electrical/Electronics 10 01-06-2005 12:51 AM
