2nd gear is hard to shift into. - TTORA Forum
post #1 of 9 (permalink) Old 02-27-2007, 03:54 PM Thread Starter
Well, I bought a 97 4 runner 4 cyl,5 speed last august off of craigslist. Naturally I have had a few issues, but one that has started to manifest it's self in cold weather.
When I start up in the morning, I have a bitch of a time getting into 2nd gear. If I take my rpms a little higher in first(3-4k) rather than 2.5k-3k before I shift from first to second, It's a little better.
I kind of have to give it some love to get it in, and when I have driven for a mile or perhaps less, I can then move through my gears with ease.
Any Ideas what might cause this?
As an aside, I get down shift into first unless I am fully stopped, but this may be unrelated, or expected behavior.
Thanks for any help.
sauer is offline
post #2 of 9 (permalink) Old 02-27-2007, 05:01 PM
taco lover's Avatar
Its not much help but I have had the same problems with my truck since I bought it. It seems to be pretty common.
97 2.7l Ex. cab Tacoma
DR coilovers
LCE Header
32 BFG MT's
Budbuilt Skids
CBI Sliders
E-locked trd rear axle
Mossyrock F&R bumpers
taco lover is offline
post #3 of 9 (permalink) Old 02-27-2007, 05:26 PM Thread Starter
Then I wont worry about it
sauer is offline
post #4 of 9 (permalink) Old 02-27-2007, 07:05 PM
you can try overfilling your tranny fluid but usually the fluid is just a little thicker in the morning when its cold and it takes a bit to warm up... you might have syn in there and that kinda exagerates the problem in the colder weather. mine is pretty bad in the winter time....
post #5 of 9 (permalink) Old 02-27-2007, 07:29 PM
Or if the synthetic is TOO slick, the synchros don't work as well...I have more positive shifting since I switched from dino to synthetic, but it does seem to grind a little more...
post #6 of 9 (permalink) Old 02-28-2007, 11:29 AM
Mythica's Avatar
So when it warms up it shifts fine?
If it only has problems in the cold, you might try changing the gear oil. If it was a syncro ring problem I think it would always be hard to shift into second.
I had a problem about a week ago. I usually park in the garage, but I had to park outside over night in the freezing cold.
When I went out to start up the truck I could not shift into any gear, it was like moving my shifter through mud. After about 10 min the tranny warmed up and I could shift fine.
How is your clutch? I have usually experienced problems shifting into Reverse when a hydraulic clutch starts to go. But I suppose it could also effect shifting into other gears.
The not being able to down shifting into first while moving is normal. I have to be almost completely stopped to sift into first. I dont know for sure but first gear may not have a syncro ring. I know a lot of older tranny's have no 1st gear syncro, older fords and VWs come to mind.
Good Luck!
Jerry
'98 Tacoma TRD
Mythica is offline
post #7 of 9 (permalink) Old 02-28-2007, 12:52 PM
x2 on maybe changing the oil viscosity since it only happens when it is cold
post #8 of 9 (permalink) Old 03-01-2007, 12:11 AM Thread Starter
Yes, the problem is temp bound. yesterday, in the AM it was hard to shift, but when I left work after the car had been sitting in the sun for the day, I had no issues.
Good to know that 4 runners also have the same issue getting down to first. I had heard that some older cars have that issue, but I'm glad to know its not just me.
I dont know how to judge the clutch. The only thing that bothers me about it, is that I have to jam the peddle until is hit the floor to get the clutch to disengage.
I lack a basis of comparison with manual transmission, since this is my first.
sauer is offline
post #9 of 9 (permalink) Old 03-01-2007, 08:03 AM
Sounds like your clutch pedal may need to be adjusted. This is for an older truck, but the procedure should be the same:
http://personal.utulsa.edu/~nathan-b.../2checkand.pdf
2nd gear power loss problem #2 97TacoDude Early Tacoma Tech 0 10-06-2006 07:37 AM
Power die-out in 2nd gear 97TacoDude Early Tacoma Tech 5 10-02-2006 05:25 PM
Traction Aiding Devices - Lockers, LSD, etc.... grillmasterp Early Tacoma Tech 9 09-20-2006 10:10 AM
1st gear issues! Big B Newbie Tech 1 09-12-2006 11:22 AM
Yukon Gears Packaged as a Generic Gear Brand? joeylead Early Tacoma Tech 111 07-20-2006 10:23 PM
