Rear Diff Breather - TTORA Forum
post #1 of 24 (permalink) Old 09-23-2007, 05:52 PM Thread Starter
CoTacoTRD's Avatar
Location: where the air is fresh and the sun is shining
Rear Diff Breather
I am curious I looked at Jackets website with all of his mods and such and noticed the extension of the rear diff breather. My question is did Toyota create a design flaw by not extending the breather somewhere further up than this or is this breather designed as a one way valve and would not allow water to go into the diff but allows it to let off pressure as needed. To me if Toyota is building an Off Road truck some thought would be put into this. Water fording is a common thing to do on off road trails even on easy trails. So I would think that Toyota would think about this and not allow such a simple failure point for the rear axle to exist. Or am I just kidding myself or is this breather only one way? My breather is still stock and is directly attached to the diff with no extension at all. Should this be something I should do ASAP?
CoTacoTRD~07 DC TRD~3" ToyTech Coilovers~Bilstein 5100's ~ Goodyear Duratrac's 285/75/R16~Slee Sliders~Spidertrax Wheel Spacers~ Quick Air OBA~All Pro Skids~ARB Bumper~Custom Exhaust~Snorkel~Sol Tek Lights
CoTacoTRD is offline
post #2 of 24 (permalink) Old 09-23-2007, 06:16 PM
darwink1's Avatar
yes i blew my pinion seal and ultimately my diff because it was not extended.
2000 taco 4x4 SOLD!
93 FZJ80 Aussie locked, sporting 37's on a 2.5" lift. SOLD!
85 FJ60 The "hearingaid toylet". 350 ram jet, D60/arb, 14 bolt/arb, atlas 3.8, NV4500, 40" km2's and stuff.
06 Dodge power wagon beater dd...
1969 fj40 frankenplowvan
darwink1 is offline
post #3 of 24 (permalink) Old 09-23-2007, 06:26 PM
spindleshanks's Avatar
The front diff breather comes extended from the factory. On my Tacoma it's on the driver side fender well under the hood. The idea is that the diff warms up as it's used, and vents out air as the fluid expands. A sudden submersion in water would have a cooling effect on the diff, thus causing the fluid to contract and draw in air and/or water with it. The breather is, in fact, a two-way valve.
Are you gonna ruin your differential every time you drive through water with a stock breather? Absolutely not. I'd say it's freakishly rare. ***EDIT: I guess it may be more common than I thought, Darwink...*** But for a $10 mod that a caveman could do, it's nice reassurance.
It's also a fun opportunity to test your creative mechanical skills. There is a plethora of options of how to make a diff breather mod. I ran mine into the fuel fill area behind the fuel door.
Mr.Clean '03 Taco
spindleshanks is offline
post #4 of 24 (permalink) Old 09-23-2007, 06:45 PM
This should be the FIRST mod anyone who takes their truck offroad should do.
It's more than "peace of mind" - true, you may not suck in water every time, but eventually you will, and if you don't promptly change the fluid (and face it, checking after every run gets to be a PITA) you will destroy your diff.
post #5 of 24 (permalink) Old 09-23-2007, 07:53 PM
that settles it...
diff breather mod this week!
Im assuming there is a write up around here somewhere eh?
post #6 of 24 (permalink) Old 09-23-2007, 08:08 PM Thread Starter
CoTacoTRD's Avatar
Yeah I was wondering about a write up as well. I see that it is easy mod but what do you need to get it done? I am mechanically inclined but I like to know what I need before I get started. Anyone have any suggestions? Peace of mind from this is well worth the time and cost.
post #7 of 24 (permalink) Old 09-23-2007, 08:11 PM Thread Starter
CoTacoTRD's Avatar
Found it!
http://www.wattora.com/index.php?page_id=12
post #8 of 24 (permalink) Old 09-23-2007, 09:51 PM
Jacket's Avatar
Here's what I used:
90404-51319 - Union (Toyota part)
90930-03136 - breather vent (Toyota part)
two stainless steel hose clamps
5' or so of 3/8 fuel line
zip ties to secure the line
I put mine in the same place that spindle did, although you could also put it in the bed somewhere (cubby?). Looks like you found a step by step write up, but it's a pretty simple process of unscrewing the existing breather, and replacing it with the union, running hose from the union to where you will seat the breather, and then attaching the breather to the other end. Clamp both hose attachments, secure the line, and your good.
Good luck!
1976 FJ40
2006 Tacoma *Sold*
Jacket is offline
post #9 of 24 (permalink) Old 09-24-2007, 04:37 PM
devinsixtyseven's Avatar
The ball valve is supposed to be one-way...but it's not. It's supposed to close off when the diff cools and sucks in air suddenly, like a water crossing...but they get clogged, dirty, jammed, rusted, torn off, whatever, and then you get water in the diff.
If you think you're running water, pull the drain plug a little bit. If good oil seeps out, you're fine. If you're getting that thin gunky stuff, or straight water, flush it.
Also FYI if you did get a bunch of water in there, the best way to get everything out is free the rear axle (disco rear dshaft, pull ubolts is all you need to do), pull the fill plug and point the pinion up...do it after you've drained it normally, so you can clean any metal off the drain plug, then tilt it up and let it sit for a while.
-Sean
devinsixtyseven is offline
post #10 of 24 (permalink) Old 09-24-2007, 08:03 PM
The WATTORA write-up is a good one. I used it. I remember reading somewhere that gear oil from the diff will get into the line and pool up in any bends in the line, blocking airflow, but I checked my line the other day and it was fine.
Mr.Clean '03 Taco
post #11 of 24 (permalink) Old 09-25-2007, 06:13 PM
Hmm....I can't believe I haven't heard anything about this until now... Well, I will do it on my new axle when I get it...should be anyday now....
post #12 of 24 (permalink) Old 09-25-2007, 09:19 PM
just did this tonight...
bit of info for you pre-taco guys reading this (very few lol)
the filler neck area is STEEL, not plastic like on the tacomas... so i had to route mine into a hole on one of the bedside support beams.
post #13 of 24 (permalink) Old 09-26-2007, 04:43 PM
Found both parts online but there is a minimum purchase of 17$ so does anyone want me to pick them up a part or two? I live up in Thornton
numb_fingers is offline
post #14 of 24 (permalink) Old 09-26-2007, 06:26 PM
go to your local ace hardware...
1/8NPT male brass fitting, with a 1/4" barb on it... worked perfect for me... and it only cost me $1.29 + tax
post #15 of 24 (permalink) Old 09-26-2007, 06:27 PM
Damn... 20 min too late
post #16 of 24 (permalink) Old 09-26-2007, 08:44 PM
heres a pic of mine... sorry it was getting dark:
post #17 of 24 (permalink) Old 09-26-2007, 10:10 PM
Mmmm Diff Breather pr0n!!! God I love CoTTORA (And props to WaTTORA and Rob's crew for the write up!)
post #18 of 24 (permalink) Old 09-26-2007, 10:35 PM
lol anybody else notice my car tire sidewall exhaust hangers?
I dont know wtf is up with them being there :shrugs:
oh well, they'll get replaced when i get the new exhaust done.
post #19 of 24 (permalink) Old 08-18-2008, 10:11 AM
sl3807's Avatar
FYI
So I went to do this mod on Saturday so I could make it up to MSV. I picked up the 1/8 NPT brass fitting. I pulled the stock breather and compared the threads. They were different . Althought they appear to be very close, the brass fitting is a 1/8-27 NPT tapered pipe thread, the breather is a M10x1.0 thread. They looked close enoough that I thought i would give it a try. I couldn't even get the brass fitting to thread in one full turn. Apparently the new gen Tacomas's have a different thread, or were manufactured to a tighter tolerance so the 1/8 NPT won't quite fit. Called Toyota this morning and they will have the union here tomorrow morning.
07 Doublecab V6 TRD 4x4 - R.I.P
11 Doublecab Rock Warrior Tundra
sl3807 is offline
post #20 of 24 (permalink) Old 08-18-2008, 10:17 AM
Jacket's Avatar
Originally Posted by sl3807 View Post
FYI
Yea - were talking about a few dollars difference here. No reason not to go OEM.
PS - Our diffs were submerged yesterday....
1976 FJ40
2006 Tacoma *Sold*
Jacket is offline
post #21 of 24 (permalink) Old 08-18-2008, 11:17 AM
I have a 1/8" NPT tap for anyone doing this mod with regular hardware...
post #22 of 24 (permalink) Old 08-18-2008, 12:27 PM
I would just buy the toyota part.
post #23 of 24 (permalink) Old 08-18-2008, 12:34 PM
my 1/8 NPT thread fitting fit fine in both my pre-taco, and my taco, it threaded damn near all of the way in by hand.
post #24 of 24 (permalink) Old 08-18-2008, 08:22 PM
I've seen a lot of variation on whether the 1/8 NPT fits or not. I just used the Toyota part. You can find them on most junk intakes, by the way...
Don_G is offline
Rear Diff breather mod, improved anestech* Cheap Tricks 92 09-06-2013 07:03 AM
Diff breather oilsandsfj FJ Cruiser Tech 2 04-18-2007 09:52 AM
Rear diff breather Ohio_Taco Early Tacoma Tech 5 10-22-2006 08:23 AM
diff breather mod claytonfaulkner Newbie Tech 25 10-11-2006 09:56 PM
Rear diff breather Wgasa84 Newbie Tech 7 04-09-2005 08:40 PM
