Gear Swap....Help Needed - TTORA Forum
post #1 of 31 (permalink) Old 10-03-2007, 08:48 PM Thread Starter
Well, after mentioning that I need to swap out the gears in my front diff, Wildturkee graciously offered to give me a hand, as I would have no idea what I'm doing. It seems that we will have all of the tools we need except for one thing.
I was wondering if anybody happened to have a press/puller for the pinion and carrier bearing. Also, my cousin is a diesel mechanic, and may have the right parts, if only I could tell him what kind. What EXACTLY do I need?
Also, if anybody else would like to help out, that would be great too. With enough people, (and another set of jackstands) I may be able to get the new rear axle in at the same time. Sorry, I can't buy beers for anybody, but I can provide a pretty good meal at least.
I'm not quite sure when I can do this... It needs to be a weekend....but I'm in no hurry. Ideally, we could catch a time when the weekly trail runs have tapered off, but it isn't ridiculously cold yet. I'm free just about any weekend after this one. Tell me when you're free, if you're interested, and I can work around that (specifically you, Wildturkee).
post #2 of 31 (permalink) Old 10-03-2007, 09:05 PM
Um not to sell you and Wildturkee short but have either of you ever done gears. I have swaped gears 6 times in the rigs I have owned and still will not do it myself. I am serious. You screw up the backlash and you screw up the gears. If you or wildturkee (sam) have done this before with sucsess (and lower gears are easier to do than my higher gears at 5.71) fine but be forewarned ok?
post #3 of 31 (permalink) Old 10-03-2007, 09:57 PM Thread Starter
Well, I think Sam knows what he's doing... You've done it successfully a time or two, right Sam? Or at least your buddy has...
post #4 of 31 (permalink) Old 10-04-2007, 02:03 AM
Id personally just pay a shop to do it.
Then you also have the re-assurance that if its NOT done right, it falls on them, and they should fix it for free and make it right.
post #5 of 31 (permalink) Old 10-04-2007, 08:49 AM
Yea, those taco front diffs are even more fun. They require a special dial indicator to measure backlash, normal dial indicators don't work. Spliting the cases every time to inspect tooth contact is a pain. I don't like the "clamshell" design.
post #6 of 31 (permalink) Old 10-04-2007, 03:09 PM Thread Starter
Lol...for $100, do you guarantee your work fatkid?
post #7 of 31 (permalink) Old 10-04-2007, 05:36 PM
I'll let you see my pattern to see that it is tits. Anyone can blow a diff quick, just look at me. I can ensure my setup will be correct.
But..... when I PMed you I though we were talking rear diff. I could charger 100 for that because I have all the tools to build that diff. I don't have the "special" dial indicator. I could check the price on one of those but I think it would be cheaper to go to Mike at ORS (he has one). But if you want to cover the cost for the tool I'll still build it.
post #8 of 31 (permalink) Old 10-04-2007, 06:25 PM
Wildturkee's Avatar
well i thought the front diff was a removable 3rd member, not a clam shell type. if it was a removable 3rd id be able to do it correctly and have a few times, but the clam shell type count me out, sorry man.
I have access to the special dial indicator for the back lash. just so every one with a removeable 3rd member knows
Do not DISTURB! Im disturbed enough allready!
90 Runner (Road Kill), SR5, Stock, 3.slow...rebuilt, 5speed 31" bfg mudders, sway bars removed.
Coming soon: SAS, Lincoln locker, 2" B/L for raised drivetrain.
Wildturkee is offline
post #9 of 31 (permalink) Old 10-04-2007, 06:47 PM
I have a normal dial indicator, just not the one that measures radially.
post #10 of 31 (permalink) Old 10-04-2007, 10:02 PM Thread Starter
Ok, well thanks anyway. I really appreciate you offering to help.
I may go to ORS....I have been meaning to check them out anyway. It may be a little longer until I will have the cash, in that case. What do you think a shop may charge? I'm just guessing $150-$200...but I don't know.
post #11 of 31 (permalink) Old 10-04-2007, 10:35 PM
Wildturkee's Avatar
thats probably low due to the amount of labor invalved to remove the front axel assembly, how ever if you pull it your self and take it to them then it might be closer to what you are thinking.
post #12 of 31 (permalink) Old 10-04-2007, 11:18 PM
What is special about the dial indicator?
I may have one in my lab ...
post #13 of 31 (permalink) Old 10-05-2007, 08:13 AM
Most Dial indicators the measuring device moves in/out. The one need for the taco front moves side to side. I just have the in/out one.
post #14 of 31 (permalink) Old 10-28-2007, 08:55 PM Thread Starter
Okay guys, I really need help now. My truck is disassembled in Troy and Molly's driveway, where it will need to stay for a couple days. We have the diff pulled, and I am taking it home with me. I need my diff set up ASAP, so that I can bring it back to Longmont, and get it in the truck. Please let me know if you can help me out, and when. My diff takes a dial indicator that moves side to side, rather than in and out. I'm getting kinda desperate here....
post #15 of 31 (permalink) Old 10-28-2007, 09:07 PM
TowerRigger's Avatar
I know this is hindsite. But I think while the diff was still together and out you should have just taken it to a tech. Diffs aren't something just anyone can fuck with. I also wish I would have watched this thread a little closer so I could have made it a little more clear that this is a job for the pros. Good on ya for trying though.
TowerRigger is offline
post #16 of 31 (permalink) Old 10-28-2007, 10:43 PM
ask molly for anthony's number.... kinda suprised she didn't give it to you already. he can get you setup. he has done quite a few gear setups for toys and stuff.
dunno what kind of funding you have to throw around but harbor freight sells a 20 ton press.... that is what you need to press everything out for the pinon gear. as for setting everything else up it isn't something that you cant do yourself. read up on it about how the gears should mesh and backlash and preload. find a place that will sell you marking grease and take your time. I have seen setups last for a long time that people set up at their houses...
post #17 of 31 (permalink) Old 10-28-2007, 10:50 PM
http://www.4x4wire.com/toyota/tech/gear_setup/
take a look.... the writeup is great
post #18 of 31 (permalink) Old 10-28-2007, 11:50 PM Thread Starter
She was going to, but we both forgot. I should call her, soon, or maybes she will see this.
BTW, Molly and Troy, you are the greatest! Thank you so much for everything you have done for me, and everything you do for the club!
post #19 of 31 (permalink) Old 10-29-2007, 12:54 AM
Well, rest assured, no press nessesary, just prefered.
As for special Dial Indicator, at this point, why not buy one yourself? I doubt they are much more than 50 bucks.
Generation Dead
post #20 of 31 (permalink) Old 10-29-2007, 08:31 AM
I got one from work - no biggie. (Isaac - actually got one that reads in the right scale for our application this time!
post #21 of 31 (permalink) Old 10-29-2007, 01:00 PM Thread Starter
Here's the plan. Today, I'm going to make a bunch of phone calls and get my parts, and line up the labor. I think I will just take the diff to a mechanic that has done a couple things for me. I'll have him do it on Tuesday, and hopefully be able to take it back up to Longmont by Wednesday or Thursday.
post #22 of 31 (permalink) Old 10-29-2007, 05:55 PM Thread Starter
Okay, I've nixed the mechanic idea. After having a conversation with the guy I was going to have do it, I'm not taking another thing to him again. I've looked at other places and got really high price estimates... The best I got was "200-ish", at Drivetrain Industries...which I may consider. After hours of searching, with my left hand typing, my right hand writing, and my ear to the phone, all at the same time, I have not been able to track down an install kit in the Denver area. I did find a crush sleeve, and a replacement bearing, for the one that was destroyed. Troy, I will be giving you a call shortly.
post #23 of 31 (permalink) Old 10-29-2007, 08:58 PM
anthony was right around 140 or so if i remember correctly..... but that was also a few years ago...
post #24 of 31 (permalink) Old 10-29-2007, 09:13 PM
save the bewbies!
OFRD_GRL's Avatar
Send a message via AIM to OFRD_GRL Send a message via Yahoo to OFRD_GRL
have u talked to ORS?
the guys there are great and reasonably priced from everything ive seen...
and they do really good work.
dont expect molly or troy to call u they never follow thru
OFRD_GRL is offline
post #25 of 31 (permalink) Old 10-29-2007, 09:28 PM Thread Starter
Yeah, I called them. They were on the higher end with $400+.
Ugg....I have a few options now....but I don't completely like any of them...
post #26 of 31 (permalink) Old 10-29-2007, 10:46 PM
$400+ to install a new ring/pinion in a diff thats already removed?
holy hell thats nuts.
post #27 of 31 (permalink) Old 10-29-2007, 11:39 PM
Untill you try to do it yourself. A removed rear diff would be cheaper. Those "clamshell" diffs suck. Usally double or triple the time of a normal diff build.
And you only add like $200 for R&R
Just think if the dealer was going to do it. Pricing starts at $550 and 90% of the goobs couldn't do it, they would cry like they had sandy crotch.
post #28 of 31 (permalink) Old 10-30-2007, 05:37 AM
UUGH! ($$$$)
I will try and call anthony again tomorrow for you Kyle. Also troy got your truck moved so we can shut the garage now. So don;t worry about it being in the way. Take your time ok??
post #29 of 31 (permalink) Old 10-30-2007, 10:20 AM
save the bewbies!
OFRD_GRL's Avatar
wow thats pretty expensive....
did you try posting on CO4x4 asking anyone?
i am asking Scotty from Addicted Offroad for you.... Ill let you know what he says.
OFRD_GRL is offline
post #30 of 31 (permalink) Old 10-30-2007, 12:29 PM Thread Starter
UUGH! ($$$$)
Good to hear. Thanks Molly. I'm dropping off the diff at a place in Denver that was recommended to me, by my buddy that I go and see at Napa pretty frequently... He can have it to me by the end of the day, and he's only charging $150. He's a diff specialist too, so I feel it will be okay.
I'm looking to do the install into the truck Thursday...Let me know if that works, Molly. Wednesday would be akward with the early trick or treaters...
Looking For Mechanic To Help with Gear Swap Freak4pedals For Sale/WTB in AZ 7 08-30-2007 12:05 PM
350 swap /what tranny is needed rgus67 Performance/Engine/Exhaust 1 05-07-2007 01:03 PM
Gear Swap in the Van TurdLE Fabrication/Mods 19 10-05-2006 11:10 AM
gear swap write-ups? RadRyan(Fabwerx) Performance/Engine/Exhaust 8 08-24-2005 09:38 AM
What is needed for gear swap joeylead Early Tacoma Tech 5 02-23-2005 10:28 PM
