Must drop front diff tonight! - TTORA Forum
post #1 of 11 (permalink) Old 11-06-2007, 02:30 PM Thread Starter
devinsixtyseven's Avatar
Anything I should be aware of? This'll be the first time I've done the drop.
How's this checklist:
Drain
Front d-shaft
ADD unit (vacuum line, power)
CV joints (just pull out, correct? No puller necessary?)
Three bolts, lower on a floor jack
That assumes I've already got the spindles away from the LBJs and the halfshafts loose from the hubs, that's easy enough.
TIA!
-Sean
devinsixtyseven is offline
post #2 of 11 (permalink) Old 11-06-2007, 03:26 PM
Haha....this reminds me of good times...
That checklist looks good. Just make sure you have the right (big) allen wrenches for the drain plugs and rear mount, and a socket for the axle nut. It's somewhere around 34mm....but I don't remember.
You will probably want to unbolt it and drop it half way, so that you can actually undo the vac lines, and electrical, otherwise it's hard to get to.
Also, my CVs just pulled out with a crowbar...so I would assume yours would too.
Is this on a Tundra? I forget what you drive...
post #3 of 11 (permalink) Old 11-06-2007, 04:29 PM
Yeah, it's a Tundra ... bolt sizes n stuff might be different...
Why do you need to drop it?
post #4 of 11 (permalink) Old 11-06-2007, 04:57 PM Thread Starter
Diff getting locked and geared, finally...ORS doing the work, gotta get it in tomorrow so I can get it back Friday & have the truck Monday.
It's full float, so just a snap ring under the manual hub body, and it's the exact same diff as the 95.5-04 Tacomas...got the tools but never done it before.
The inner CVs should come out with a yank based on what a buddy passed along...he's done it too many times...hopefully no crowbar necessary but it wouldn't be the first time.
I'll check back in a bit, gonna get some shuteye before I dig in...
post #5 of 11 (permalink) Old 11-06-2007, 05:50 PM
Kyle's (Quickdraw) were TOUGH to get out and back in.
Kyle's (TowerRigger) were pretty easy.
I'll let the tight/loose jokes slide for now ...
post #6 of 11 (permalink) Old 11-06-2007, 08:20 PM
Like throwing a hot-dog down a hallway
post #7 of 11 (permalink) Old 11-06-2007, 09:26 PM
Oh that was good. We shoulda greased quick-draw's CV up and then thrown a twinkie into the axle housing... *smirk*
post #8 of 11 (permalink) Old 11-07-2007, 02:06 AM Thread Starter
It's out . I won't bore you guys with the details but it was pretty easy, except for getting the snap rings off the manual hub outer CVs. That was like trying to catch a greased deaf guy in a convenience store.
T60 works well enough in place of a 12mm allen wrench for that rear main fastener, and a pair of opposed crowbars makes a great press tool so the inner CVs aren't side loaded on the way out.
-Sean
post #9 of 11 (permalink) Old 11-07-2007, 07:21 PM
TowerRigger's Avatar
I can't help it if my taco's loose. It was made that way.
TowerRigger is offline
post #10 of 11 (permalink) Old 11-12-2007, 05:50 AM
Talking
-Sean
Dude.... We have snap ring pliars in many makes... sexes.. models.. and sizes at the H.O.W.
You hate me now huh? LMAO!
post #11 of 11 (permalink) Old 11-12-2007, 12:33 PM Thread Starter
Well, my snap ring pliers are the midget transvestite model. Who makes the kind with the indexing groove at the end, to capture the snap ring? I need to get some of those...straight nose and bent nose.
Front diff drop kit d4dtaco Newbie Tech 34 09-29-2006 03:40 PM
Front Lift before diff drop heeltoe989 Suspension 2 06-07-2006 10:36 PM
1" Front Diff Drop kit itjobhunter For Sale/WTB in CO 13 02-03-2006 01:53 PM
When do u need a front diff drop spacer 05TRDTaco Early Tacoma Tech 2 04-03-2005 02:14 PM
Front Diff Drop helajames Early Tacoma Tech 12 01-22-2005 09:01 PM
