case of the shakes - TTORA Forum
post #1 of 22 (permalink) Old 12-25-2007, 06:25 PM Thread Starter
SP!N4L T4P's Avatar
case of the shakes
after we intsalled my lift, i started getting a vibration that would hit around 20 mph, then die at 25 mph. it starts at the front, then as it dies it kinda moves towards the rear. i took it to all american 4x4 down on santa fe and they told me that my rear drive shaft needed adjusting. thats all fine and dandy, except that the vibe is comin from the front, not the rear, so im guessin, and so does Scott over at Add Off, that its the front drive shaft. i pulled out the protective plate right under where the shaft hooks up to the tcase, and sure enough there was evidence of rub-age and shear-age. but the vibe is still there. any ideas anyone?
88' 4Runner: 3.4L, 4" lift, rear Detroit, 33's, 4.88s, sliders, soft-topper,
SP!N4L T4P is offline
post #2 of 22 (permalink) Old 12-26-2007, 07:56 AM
Have you tried pulling the front DS and driving without it and see if the vibration is still there?
Did you get an alignment after doing the lift? Caster could be off, and you're getting the IFS kind of death wobble.
post #3 of 22 (permalink) Old 12-26-2007, 11:35 AM
It could very well be the rear driveshaft.
I've had similar things happen to me in my car. Granted, its a car, not a 4wd truck. But the inner CV joint on the driver axle went out, but it felt like the passenger CV was bad. So i dicked with it for hours, swapped out probably 8 different axles and then it dawned on me... check the other side. And sure enough.
It could be sending vibrations through your t-case/trans/motor then the motor mounts before you feel it
post #4 of 22 (permalink) Old 12-26-2007, 10:26 PM Thread Starter
SP!N4L T4P's Avatar
well, due to the weather and to the fact that i have no garage to work in, i havent gotten a chance to even attempt to take out the front d-shaft, but im goin to Scott's shop to get the front geared to 4.88 and ill take it out then and try it out. also, i got two alignments done after the lift. i tell ya, a SAS keeps sounding better and better...
post #5 of 22 (permalink) Old 12-27-2007, 12:40 AM
Yup. Then you can get REAL deathwobble!!!
Check to see if you've got play in your ball joints, TRE's, and/or idler arm.
Generation Dead
post #6 of 22 (permalink) Old 12-27-2007, 12:59 AM Thread Starter
SP!N4L T4P's Avatar
what causes SAS death wobbles anyway. my friend's K5 had one that made me shit my pants the first time it hit.
post #7 of 22 (permalink) Old 12-27-2007, 08:45 AM
Caster missalignment in combination with manual steering. Go full hydro and you'll never have an issue, i guarantee it.
Generation Dead
post #8 of 22 (permalink) Old 12-27-2007, 10:28 AM
It's a resonance phenonemon, and can be brought on by a combination of several little things - caster is the biggie, but tire pressure, shock damping, wheelbase, driveshaft balance, pinion angle, worn parts, loose parts, and others all contribute.
Isaac - I think hydro is like steering stabilizers - the DW is still there, you just don't feel it as much. More of a bandaid than a true root cause solution.
post #9 of 22 (permalink) Old 12-27-2007, 01:33 PM
Nah. You can't get the resonance on a full hydro set up. It is too large a damper. Your wheels aren't connected except through a fluid. A Hydro assist is a bandaid, but full hydro is a full blown medicine man. You can get individual wheel wobble with worn parts, but you don't feel it, since there is zero mechanical connection to the steering wheel.
Essentially, unless your wheel is about to fall off, the Hydro will damp out almost EVERYTHING. And even if your wheel is falling off, you won't feel it in the steering wheel.
On the other hand, Hydro is definitely NOT street legal. So, yeah, not really an option for a road truck.
Generation Dead
post #10 of 22 (permalink) Old 12-27-2007, 07:46 PM Thread Starter
SP!N4L T4P's Avatar
well, i got another problem...i finally got my 4.88's in the front and rear, and lo and behold the vibe is gone in 4x4 but still present in 2wd. however, there is another demon i gotta excerise out: when im in 4x4 (with my new 4.88's) whenever i pass 45, as soon as i let off the gas i hear a scraping/scratching sound coming from right under me, and its not clear whether its behind or infront of me. the faster i go, the louder the sound, and if im goin fast enough (70+ which isnt good in 4x4 anyway) it gets damn loud and becomes a vibe, and it only happens in 4x4, not in 2wd. did any of you have a problem like this after gearing your axles? is it just that my t-case cant handle all the new amount of pressure from both axles with 4.88?
post #11 of 22 (permalink) Old 12-27-2007, 11:55 PM
You're t case should be fine with the 4.88's.
Do you have any belly armor?
This sounds like a drive shaft issue, although quite strange to have it in 2 and not 4.
Here is what I would do:
Call or email Troy and Molly. See if they have a few hours on Sat.
Go over when they do have time, and remove front drive shaft. Drive it around. If you have manual hubs, unlock them. If no noise, lock hubs, no drive shaft. If no noise, stop, put transfer case in 4wd, and so forth. This should enable you to do figure it out by process of elimination.
If not the drive shaft, then I suspect transfer case, but certainly not as a result of the 4.88's.
Good luck man!
Generation Dead
post #12 of 22 (permalink) Old 12-28-2007, 08:32 AM
w however, there is another demon i gotta excerise out: when im in 4x4 (with my new 4.88's) whenever i pass 45, as soon as i let off the gas i hear a scraping/scratching sound coming from right under me, and its not clear whether its behind or infront of me. the faster i go, the louder the sound, and if im goin fast enough (70+ which isnt good in 4x4 anyway) it gets damn loud and becomes a vibe, and it only happens in 4x4, not in 2wd.
Sounds like dry spindle bushings.
post #13 of 22 (permalink) Old 12-28-2007, 09:53 AM
TowerRigger's Avatar
Give it some liquor. A dry Spindle always likes liquor.
TowerRigger is offline
post #14 of 22 (permalink) Old 12-28-2007, 10:13 AM
Spindle likes liquor even when he's wet ...
post #15 of 22 (permalink) Old 12-28-2007, 01:07 PM
spindleshanks's Avatar
Hey, it's not spindle's fault he likes to drink...his girlfriend's mom gave him a huge bottle of Jack Daniels as a Christmas present!
Mr.Clean '03 Taco
spindleshanks is offline
post #16 of 22 (permalink) Old 12-28-2007, 03:13 PM
Hey, it's not spindle's fault he likes to drink...his wife's mom gave him a huge bottle of Jack Daniels as a Christmas present!
Fixed it for ya ... if her parents are that cool, you need to marry the girl!
post #17 of 22 (permalink) Old 12-28-2007, 03:43 PM
Woah now Troy. Let's not let the alcohol have us make hasty decisions.lol
post #18 of 22 (permalink) Old 12-28-2007, 04:21 PM
You met Annaliese in Steamboat ... but you probably don't remember
post #19 of 22 (permalink) Old 12-28-2007, 08:23 PM
Wildturkee's Avatar
Dont go to All American 4X4...unless you like to get RIPPED off...MMM KAY?
Do not DISTURB! Im disturbed enough allready!
90 Runner (Road Kill), SR5, Stock, 3.slow...rebuilt, 5speed 31" bfg mudders, sway bars removed.
Coming soon: SAS, Lincoln locker, 2" B/L for raised drivetrain.
Wildturkee is offline
post #20 of 22 (permalink) Old 12-28-2007, 10:22 PM
JayDawg's Avatar
I just got some Bilstein 5100's for Christmas. I am wanting to set them at 2.5" which is the max lift availible that way it levels out my truck from the rear leaf tsb. Do you all think I will have this same issue?
My current one:
2007 Tacoma 4X4 extended cab TRD off road package. Speedway Blue
5100 Bilstein shocks set to 2.5", Rear leaf TSB, Randy Ellis design lightbar, 4 Piaa 80 racing series off road lights from my 97' Tacoma.
My last one:
1997 Tacoma 4X4 extended cab.
White
Pre runner bumper, 4 PIAA 80 racing series off road lights, American eagle rims, 31" BFG All Terrains and a few other little things. Lost her in 01' because of a bad lease deal.(Will never lease again!)
JayDawg is offline
post #21 of 22 (permalink) Old 12-28-2007, 11:19 PM Thread Starter
SP!N4L T4P's Avatar
here here!
post #22 of 22 (permalink) Old 12-29-2007, 01:55 AM
Not on a brand new truck.
If you have worn out parts on that baby, you need to take it in to the dealer and call bullshit.
You will be fine.
Generation Dead
death shakes toy4us Pickup/Early 4Runner Tech 7 11-07-2007 10:00 AM
Shifter shakes @60-70? im4u2nv Early Tacoma Tech 17 04-20-2007 03:48 PM
Shakes for 3-8 seconds on start up........... D-Dub Performance/Engine/Exhaust 19 02-18-2007 07:59 PM
I got the shakes... sloppytaco Tech 14 12-05-2005 03:47 PM
Truck got the shakes Shakerhood Early Tacoma Tech 17 05-20-2005 10:46 PM
