breather question - TTORA Forum
post #1 of 11 (permalink) Old 03-17-2008, 09:01 PM Thread Starter
Unhappy breather question
I extended the rear diff breather into the tail-light area.
I found 2 breathers on the left front fenderwell. What do they go to? I get conflicting information from forum searches.
There are 3 more things that need breathers:
1) front diff (pretty sure this one is on the fenderwell.)
2) transmission
3) transfer case
Which ones are on the firewall?
Which one do I need to hunt down?
Don_G is offline
post #2 of 11 (permalink) Old 03-17-2008, 09:11 PM
I thought the transmission and transfercase just had breathers on top of them, but they may have routed these to the firewal..
post #3 of 11 (permalink) Old 03-17-2008, 09:52 PM
Denver Dave's Avatar
The transmission and tcase vent through the top. There is a thread somewhere around here where a guy sealed them up and put in some breathers. If you are interested I think I have the thread bookmarked at work. I know for sure one of the fenderwell breathers is for the front diff but I never really gave the other one much thought.
2001 Taco TRD SR5 XtraCab
5-vee-zee-eff-eeeeeeee
Denver Dave is offline
post #4 of 11 (permalink) Old 03-17-2008, 10:00 PM
So you got me curious - apparently the other one is the electric actuator breather.
http://www.tacomaterritory.com/forum...ad.php?t=89913
post #5 of 11 (permalink) Old 03-18-2008, 06:52 AM Thread Starter
Now I'm still a little confused.
01-04 tcase assy drawing
This shows a breather tube coming off the tcase shifter assembly on 01-04. Does not say where it goes...
Dave, I would like that thread, especially if it shows pics.
Don_G is offline
post #6 of 11 (permalink) Old 03-18-2008, 09:48 AM
I knew I saw it somewhere - not TTORA but helpful nonetheless: http://www.4crawler.com/4x4/CheapTri...l#GearBoxVents
Now I'm confused too - I see the breather hose in your diagrams but I don't remember seeing them the last time I was in there. I know one of the fenderwell breathers is for the front diff FOR SURE because my mechanic overfilled it last time and it blew out that valve along with the driveshaft seal. Now every time I go up the driveway to the cabin in 4-lo I have to top off the front diff Another fix for another day.
Anyways, when I get home tonight I'll check it out.
Another thread to look at for the transmission breather is http://tacomaterritory.com/forum/sho...ssion+breather
Another great picture further down the thread http://tacomaterritory.com/forum/sho...nsfer+breather
post #7 of 11 (permalink) Old 03-19-2008, 07:47 PM
bluetaco's Avatar
If you are that serious about water crossings you need to remove the carpet from the cab... :b
wet carpet does more damage to your truck that anything you are extending the breather from and the heat exchange lose from the extension reducing air flow probably reduces the life of moving parts more than moisture!
just time all your wet excursions just before you need to swap fluids!
if you get water in the t-case and tranny you are more that likely ruining your ECU wiring and sensors before you get a chance to see gear and shaft damage
bluetaco is offline
post #8 of 11 (permalink) Old 03-19-2008, 08:36 PM Thread Starter
I tried hard to buy my truck with only a vinyl floormat, but I could not get one.
If the carpert gets wet I will rip it out and never look back. Does anyone sell a plain vinyl replacement?
I don't intend to get into deep water, but stuff happens. I have been on ranches in Texas where we had to camp 2 days waiting for the water to go down. That water was moving so fast you could hear the boulders cracking and rumbling, and I would have never tried it. But the point is that sometimes water is deeper coming out than going in...
Don_G is offline
post #9 of 11 (permalink) Old 03-19-2008, 10:05 PM
Yeah, it's an FJ Cruiser
post #10 of 11 (permalink) Old 03-20-2008, 11:39 PM
I had a chance to take a peek tonight. The breathers are right on top of the t-case/tranny. You might be able to get a fitting on the t-case breather port but your gonna have a hell of a time finding a way to get tubing from the transmission breather. It is recessed amongst some aluminum fins. A straight fitting *might* work but you risk messing with your shifting.
post #11 of 11 (permalink) Old 03-21-2008, 06:48 AM Thread Starter
Thanks, Dave.
Nothing like a definitive answer!
Don_G is offline
Breather question....TRD E-locker Marc P Early Tacoma Tech 8 01-08-2008 06:55 PM
Question about diff breather . . . Revivalist Early Tacoma Tech 18 05-02-2007 11:26 AM
Rear dif breather install question SADGOAT Newbie Tech 10 03-04-2006 10:39 AM
Diff. Breather Extension Question. tbrown Early Tacoma Tech 8 08-23-2005 07:52 PM
Front Diff Breather question jrizman Early Tacoma Tech 1 03-19-2005 03:10 PM
