IFS front crossmember solution....? - TTORA Forum
post #1 of 9 (permalink) Old 09-16-2009, 08:06 PM Thread Starter
madness's Avatar
Send a message via AIM to madness
Problem:
So I've been told that this doesn't happen. I guess I'm skilled.
Solution:
I've wrapped it in 1/4 inch mild steel plate. I'm pretty sure I know the problems that are going to be pointed out. (1) I've weakened the structure of the cross member by putting all of that weld on it and it is going to shear instead of bend. (2) Its not strengthened where it mounts. (3) Its going to move the weak point to another part of the suspension.
I did NOT quench the part after I was done welding (I know better than that) I'm going to let it cool over night. I was hoping you guys would have a little input on how I could make it a little stronger overall and maybe make some of the other parts of my lift stronger.... possible cross bracing like the prerunner guys.
I know the welds don't look all that great but i couldn't really see through the ARC hood that we have.
Just wanted to see what you guys thought.
madness is offline
post #2 of 9 (permalink) Old 09-16-2009, 09:40 PM
You need a rear crossmember now. Something like this
http://www.sonoransteel.com/Early_IFS_Brace.html
post #3 of 9 (permalink) Old 09-16-2009, 09:44 PM Thread Starter
madness's Avatar
Already have one of DOM and 1/4 in plate Ill see if I can get a picture of it.
madness is offline
post #4 of 9 (permalink) Old 09-16-2009, 09:47 PM
Then it sounds like bumpstops are the next thing - because I would guess the next load is going into bending the arms, breaking the balljoints, etc.
post #5 of 9 (permalink) Old 09-16-2009, 09:53 PM Thread Starter
madness's Avatar
probably should put on those bump stop extensions....
madness is offline
post #6 of 9 (permalink) Old 09-16-2009, 10:14 PM
Personally, instead of extending down the hard bumpstop, I'd put in a longer, softer one to more gradually slow things down.
post #7 of 9 (permalink) Old 09-16-2009, 10:20 PM Thread Starter
madness's Avatar
alright. makes sense. ill see what i can come up with.
madness is offline
post #8 of 9 (permalink) Old 09-16-2009, 11:01 PM
Crossmember looks fine, but, well, the rest of the suspension doesn't. Might want to unbend the rest of that bracket lift before going too much farther.
Generation Dead
post #9 of 9 (permalink) Old 09-17-2009, 08:32 AM Thread Starter
madness's Avatar
well i think that pretty obvious.
madness is offline
clearanced crossmember for front DS Alan11116 Solid Axle Swap Tech 10 09-18-2008 12:49 AM
Reweld Front Crossmember rayos Suspension 19 12-22-2007 04:21 PM
Best front shock solution for New England are? cogs Suspension 6 08-23-2007 03:41 PM
Tacoma Front Crossmember SAR_Squid79 Wanted 10 10-04-2006 02:39 PM
front crossmember bent 99TanTaco Early Tacoma Tech 7 08-05-2005 07:54 PM
