All-Pro's new Transmission skids are now ready! - TTORA Forum
post #1 of 19 (permalink) Old 02-14-2007, 10:33 PM Thread Starter
ScottyC's Avatar
All-Pro is announcing the release of our Transmission Skid Plates. These skid plate protect the vulnerable transmissions from damage on the trail. They are made of 3/16" mild steel that has been bent on a press for a perfect fit. The fit both manual and automatic transmission vehciles.
These skid plates will ONLY WORK WITH OUR FRONT IFS SKIDS.. They are 100% bolt-on and bolt to the factory crossmember as well as out front IFS Skid Plate.
Introductory price will be $89/ea.
They will ship bare metal.
ScottyC is offline
post #2 of 19 (permalink) Old 02-14-2007, 11:21 PM
george.arnold's Avatar
Send a message via AIM to george.arnold
damn! that thing looks nice!
George
2003 X-Cab V6 Auto 4x4
Bilstein HD Struts|OME 881s|Small ToyTec Spacer|OME Dakar Leafs|OME Greaseable Shackles|ProComp MX6 Shocks|305/70R16 Goodyear Wranglers w/ Kevlar|Deckplate Mod|Cobra CB|PA|4ft Whip|Custom 'JFab' Front Bumper|Custom Sliders
george.arnold is offline
post #3 of 19 (permalink) Old 02-14-2007, 11:26 PM
jhunter's Avatar
I guess I am going to be forced to ditch the ARB & get one of your front bumpers. Your front IFS skids only work with your bumper, and your new trans skid only works with your front IFS skid. Looks good. Is there any plan to make a skid that will work as a single unit?
jhunter is offline
post #4 of 19 (permalink) Old 02-14-2007, 11:39 PM Thread Starter
ScottyC's Avatar
Our skids work fine with the ARB bumper... But, if you want to get rid of an extra 70lbs, by all means ditch it! LOL
ScottyC is offline
post #5 of 19 (permalink) Old 02-14-2007, 11:48 PM
jhunter's Avatar
Oh, sorry. I e-mailed someone over there a while back and was told that the skids would only work with the allpro front bumper. I guess I will be placing an order. Thanks.
jhunter is offline
post #6 of 19 (permalink) Old 02-14-2007, 11:50 PM
Are they really that vulnerable? Usually whats more vulnerable is the transfer case. Seems a flat bottom skid extending to the tranny crossmember would be more effective as your skid rests above the crossmember, still leaving it prone to snagging on rocks.
ShowStop is online now
post #7 of 19 (permalink) Old 02-14-2007, 11:58 PM
jhunter's Avatar
I guess if you fall down on a rock that larger, your going to have other issues to deal with, but at least the trans will not be one of them if the skid holds up. More options for the transfer case is what we need. Im not familiar with those clocking deals, still reaserching them.
jhunter is offline
post #8 of 19 (permalink) Old 02-15-2007, 12:44 AM
ocdropzone's Avatar
Sweet product, but how about one for the '05 Tacomas?
~Robb
1981 Trekker- 220:1
ocdropzone is offline
post #9 of 19 (permalink) Old 02-15-2007, 03:55 AM
good point. that thing creates a place to hang up, frankly. I'd flip that sucker over so it is flush with the xmember and able to just slide over stuff.
add some 1" sides at a 45* angle for gusseting.
post #10 of 19 (permalink) Old 02-15-2007, 07:35 PM
I agree with the argument that one could get hung up on the edges of the AP plate, but the nice thing is that the AP plates provide a philospohical alternative to underside plating. The kind of smooth "slide over it" approach is already available in the form of the MAF/4+ plates (picture below - had to include it, that's my truck ) and some of the others. The AP plates much more closely hugs the underside of the body as a design philosophy...
mir207 is offline
post #11 of 19 (permalink) Old 02-15-2007, 08:13 PM Thread Starter
ScottyC's Avatar
Yes, they are. I have seen a few dented tranny pans already in fact. And, we will also be building a tcase skid as well.
The problem with the flat bottom skids out right now is that they sit too low. What's the point in a flat bottom skid when you are highcentered on it and can't move anyway? Also, the design will also work with the new crossmember in the works.
ScottyC is offline
post #12 of 19 (permalink) Old 02-15-2007, 10:40 PM
Given where the exhaust cross over, muffler and fuel tanks sit, you probably can't make a flat bottomed skid that isn't "too low", right (what is "too low" anyway ?) That's a symantics issue... I've only ever been stuck on the ridge that has to be in the skid to cover the exhaust cross over - without that ridge, I think I would have slid over... Will you guys be extending further at some point? How will you deal with the exhaust cross-over? I've seen that dealt with by changing the pipe to hug closer to the vehicle further down the vehicle and behind the tcase:
http://www.fjcruiserforums.com/forum...ht=exhaust+fix
mir207 is offline
post #13 of 19 (permalink) Old 02-16-2007, 03:43 AM
I still say a flat bottom and the ability to slide over stuff is a better way to go regardless of how low the complete plate is. Having that tranny skid up above the other plates like that only creates a spot to get hung up on, IMO. If the lowest point in a set of skids is all basically the same or at least has smooth transitions from plate to plate the rig can be pulled or pushed over anything that might high-center it. But, if you creat one high spot like that with a damn-near 90* angle you wind up with a real sticking point in the middle of the truck that can make it very hard to recover from.
post #14 of 19 (permalink) Old 02-16-2007, 09:13 AM Thread Starter
ScottyC's Avatar
This is the inherent problem with all Toyotas out of the factory. They use that silly monster crossmember to hold everything up killing all ground clearance. Even my 88' 4runner had one. IMO, it wouldn't make much difference at all if it was a flat skid at that location. With the long wheelbase, and low crossmember, you're gonna need a strap to get over a sand dune, let alone a rock. You can always use reverse if its holding you up as well.
We simply don't see the point of adding things further below the factory crossmember to take even more ground clearance away. We've protected what is important under there. Its also far enough forward that I doubt it will be an issue. The Tcase area is by far more important and we are working on that as well.
ScottyC is offline
post #15 of 19 (permalink) Old 02-16-2007, 09:02 PM
Send a message via MSN to green96taco
very sexy
Dustin
1995 Tacoma Extra cab, Billy 5100s, Toytec Coils, Bastard pack rears, 285s
1984 Trans Am 370 LSX/t56.
Originally Posted by wslytoy View Post
I know this one chick, she'll let you suck on her nipple you fucking titty baby. The kit is shit, not as in THE SHIT, but as in the stuff that comes from my asshole.
green96taco is offline
post #16 of 19 (permalink) Old 02-17-2007, 12:29 PM
VooDoo FJ's Avatar
I wish that they came powdercoated already.
2007 FJ MT6||K&N Air Filter||OEM Rock Rails||TRD Quick Shifter & Knob
N.C. Beach Buggy Assoc. #12893
TTORA #13074
NRA #149022131
VooDoo FJ is offline
post #17 of 19 (permalink) Old 02-17-2007, 01:16 PM
Banned
Spray paint it. Its something that is going to get scratched, plus you have to get on your ass to even see it.
Paul is offline
post #18 of 19 (permalink) Old 02-17-2007, 06:53 PM
you really don't have to add much below the xmember, ie. 3/16".
something like this:
the tcase skid then butts up against that at the mid-point of the xmember.
My point is that you can slide over a rock just fine until you hit that xmember with its 90* angle and 2" 'wedge point and the truck will just stop right there. No strap will get it moving forward. You'll have to back up and reset the line. (I know, so what? ) We're not talking a lot of extra metal here so why not just make it a flat skid for the whole length? I really don't think a loss of 3/16" of clearance is a big deal.
post #19 of 19 (permalink) Old 02-17-2007, 06:58 PM
Banned
I have skids very similar to those.
Paul is offline
New Marlin Crawler 'RZ' Engine to R-series Transmission Bellhousing BigMike Vendors Marketplace 12 07-16-2007 02:47 PM
Transmission Mount Condition Jwitc075 Early Tacoma Tech 6 01-02-2007 07:50 PM
6 speed transmission noise eatnbugs Late Tacoma Tech 19 11-30-2006 04:00 PM
Looking For Transmission Gear Ratios partyman66 Early Tacoma Tech 14 04-21-2006 03:09 PM
Stock skids, running boards Zackattak Parts/Electronics/Wheels/Tires 9 01-12-2005 04:50 PM
