Aftermarket Body Mounts for Tacoma - TTORA Forum
post #1 of 12 (permalink) Old 03-11-2012, 11:14 AM Thread Starter
y2kbaja's Avatar
Has anybody found an aftermarket polyruethane body mount for the 05+ Tacoma? I contacted Energy Susp last year and they had nother and were not interested in looking into it at anytime soon. I have the Energy 9-4101g for the radiator body mount but I don't see one bigger for the cab mounts. Energy 8-4107g is for the 01-04 Tacoma. I don't really want to spend $85 to see if they work. Has anybody replaced their body mounts with urethane?
2005 Tacoma 4-door, Total Chaos LT front end, Deavers rear, Fox Shox, bed cage built by Richer Racing.
y2kbaja is offline
post #2 of 12 (permalink) Old 03-11-2012, 11:26 AM
Have tried 4crawler?
2000 Tacoma
3.4 TRD
ICON C/O
Marlin Clutch
Wainiha is offline
post #3 of 12 (permalink) Old 03-12-2012, 09:32 PM
PSU Taco85's Avatar
I've talked about that with Roger when I put my 4crawler body lift on. As of yet, there is nothign available for the 2nd gen Tacomas. The rubber mounts are holding up just fine for me.
PSU Taco85 is offline
post #4 of 12 (permalink) Old 03-13-2012, 05:29 PM
Land Pirates Off Road's Avatar
Stock should hold up to just about anything really. But if you can hold off a bit, Daystar is coming out with a kit. We just talked to the factory rep about 2 weeks ago requesting them. They are in the works...
Drive Harder, Faster, Safer & keep it rubber side down!
https://www.facebook.com/LandPiratesOffRoad
Landpiratesoffroad.com
Land Pirates Off Road is offline
post #5 of 12 (permalink) Old 03-13-2012, 06:48 PM
taco4x4rar's Avatar
Send a message via AIM to taco4x4rar
While the stock ones are durable they allow for quite a bit of cab movement, I guess thats a good thing for flexy frames but once I get mine boxed I'll really be wanting something a little more ridged.
Originally Posted by Jomentum View Post
I drink everclear for the flavor.
Originally Posted by Spacecwboy View Post
I'm still a homo!
http://toyotaoff-road.com/
Randy
2006 Tacoma x-cab, flat bed, leaf sprung Dana 44, Dana 60/ 14 bolt coming soon
1992 Chevy C-1500 swapped D60/14bolt 454 and th400 (wrecked it)
taco4x4rar is offline
post #6 of 12 (permalink) Old 03-13-2012, 08:49 PM Thread Starter
y2kbaja's Avatar
copy, daystar, wait.
Yes, cab flexing too much, it's contacting the bed sides which are about 2 1/2 inches away.
y2kbaja is offline
post #7 of 12 (permalink) Old 03-14-2012, 01:43 PM
Thumbs up
100% agree... You would freak if you saw how much the 07+ Tundra flexes!!! Once you start needing a better set up you either go with hard spacers or solid mount.
We solid mounted out own rigs for safety and for control.
If your boxing in your frame, diving fast... etc... Solid mount with 5/8 or 3/4 inch grade 8 or better bolts. Oh, and over sized hardened washers...
post #8 of 12 (permalink) Old 03-14-2012, 02:40 PM
hilux30's Avatar
Man that cab is going to get shaken' to pieces... you caging this truck? Anyone done this and can comment about the NVH and ride?
2007, AC, 4x4, 4.0, intake-spacer, 885s, dakars, D29XL, Tundra steels, 265/75/16 BFs, UrD MAF & Y-pipe ....
hilux30 is offline
post #9 of 12 (permalink) Old 03-14-2012, 08:13 PM
lrgrnr's Avatar
Interested.......
lrgrnr is offline
post #10 of 12 (permalink) Old 03-20-2012, 07:46 AM Thread Starter
y2kbaja's Avatar
Amen to the Tundra flex. I was chasing Choas on the Mojave Road with my Drift in-car rolling, even the license plate was moving a different way. Too bad the camera was out of batteries.
y2kbaja is offline
post #11 of 12 (permalink) Old 10-07-2012, 03:32 PM
Any updates on poly body mounts?? My cab is bouncy as hell after a lot of abuse and I have a really good idea that it's the body mounts. It just doesn't feel coilover related. Also, if I go over speed bumps there's some sort of chassis slap sound coming from the bed. After examining the body mounts I can see some contact marks from the body mount flexing enough to allow the body mount washer to contact the bottom edge of the body mount itself. These are very strange body mounts as they are almost like the control arm bushings but mounted verticle. Any ideas or fixes floating around out there??
rzimm001 is offline
post #12 of 12 (permalink) Old 10-07-2012, 03:39 PM
Is it just me or are my front body mounts collapsed?? The first picture is the front mount and the second picture is the rear mount.
rzimm001 is offline
Body mounts tbst Early Tacoma Tech 19 04-09-2007 09:37 AM
Complete RB 2" Body Lift with Gap Gaurds and Poly Body Mounts Dunk Parts/Electronics/Wheels/Tires 11 12-04-2005 12:35 AM
4Crawler 1" Body Lift w/ Poly Body Mounts - $220 hawaiianbro Parts/Electronics/Wheels/Tires 14 10-23-2005 11:20 PM
Stock Body Mounts 01tacoTRD Wanted 0 09-24-2005 07:56 PM
Body Lift, 33” tires, Body Mounts, 2.7L supercharger, Header and LOTS MORE! Supercharged 2.7L Early Tacoma Tech 4 09-20-2005 10:25 AM
