2005 Aftermarket Wheel Problems???? - TTORA Forum
post #1 of 8 (permalink) Old 02-18-2006, 04:32 PM Thread Starter
wyotaco's Avatar
I have a 2005 Taco, and am now on my fourth set of aftermarket wheels. The wheel shop, MTO Suspension, kept ordering the wrong bakcspace, offset, etc. Now, the last three sets have vibrated like crazy at about 55+MPH, and no one knows whats wrong. It ain't balance, it ain't tires, and it ain't the truck. Then what the heck is it??? Now running 16x8 Eagle 146's, but I have been through 058's, 186's, and 187's before these. One set did not clear the caliper, and three shake like crazy. Back to the OE wheels, and shaking stops. SAME Tires on all. Any one else fighting this or is it as my wheel guys is trying to say: "Aftermatket wheels sometimes just do that."
wyotaco is offline
post #2 of 8 (permalink) Old 02-18-2006, 05:18 PM
EndersTaco's Avatar
I am running some cheapy pacer wheels and never had any issues besides the caliper clearance. 5 minutes with a grinder fixed that...
EndersTaco is offline
post #3 of 8 (permalink) Old 02-18-2006, 05:27 PM
Actually, it's because you're missing the tire inflation monitor sensors in the wheels. This is why Toyota put them on the 06's.... to balance out the wheels.
SR-71Taco is offline
post #4 of 8 (permalink) Old 02-18-2006, 05:56 PM
cedarbarn
Guest
Posts: n/a
OEM Toyota rims are hub centric. I dont know if putting lug nut centric wheels on a truck designed for hub centric wheels would matter. Maybe it does???
post #5 of 8 (permalink) Old 02-18-2006, 06:26 PM Thread Starter
wyotaco's Avatar
thanks-talked again with American Eagle and he says he will get some hubcentric rings coming for the truck. I am now using lugcentric lugs, but that is apparently not enough. Watch out for new wheels!!!
wyotaco is offline
post #6 of 8 (permalink) Old 02-18-2006, 07:15 PM
SP Jon M3's Avatar
Send a message via AIM to SP Jon M3 Send a message via Yahoo to SP Jon M3
Lug-centric wheels will work fine. Just make sure that the place that balances the wheels/tires uses a lug-centric adapter (an adapter that the wheel mounts but using the lug holes and lug-nuts to attach, then the adapter is attached to the balance machine). If the used the hub-centric adapter (the cone that goes through the center of the wheel to hold it to the machine, without any adapter bolting to the wheel) you will have a vibration. It doesn't matter how many times they try to rebalance the wheels/tires or what wheel you are running.
You best be is to get them to use a lug-centric adapter and balance the wheels on a road-fore balance machine. If you do this your vibration problems will most likely go away. I know it solved the vibration problems on my truck.
Also check out this thread..
http://www.tacomaterritory.com/forum...ad.php?t=27900
Jon
'05 Double Cab 4x4 V6 SR5 Auto White
Mods: Fabtech DirtLogic 2.5 coilovers and Total Chaos UCAs up front, Deaver springs and Bilstein 5150's in the back, American Racing Mojave 16x8, BFG M/Ts 265/75/16, Demello Bolt-on sliders.
'01 Double Cab 4x4 V6 Auto TRD Black, you will be missed.
'89 BMW M3 Alpine White
SP Jon M3 is offline
post #7 of 8 (permalink) Old 02-19-2006, 06:02 PM Thread Starter
wyotaco's Avatar
any idea what shops have the lugcentric adapter? Cheyenne is not a large town, but I have access to most national chains in Northern Colorado.
wyotaco is offline
post #8 of 8 (permalink) Old 03-09-2008, 09:21 PM
Alexe's Avatar
sorry for digging this up, but you mentioned one didnt clear the caliper. which one? i want to put 186's on mine but cant find anyone who's run em. did they clear for you?
Alexe is offline
cant find-alignment specs grumpy Solid Axle Swap Tech 85 03-03-2007 08:12 PM
Stock 2005 16" Wheel crhannig Wanted 0 12-27-2005 10:13 PM
2005 AfterMarket Finds??? robothump Early Tacoma Tech 4 12-27-2005 07:20 PM
2005 Tacoma Paint problems gixxer 1000 Early Tacoma Tech 47 11-15-2005 12:46 PM
2005 Wheel compatibility with other Toyota UncleChris Tires/Wheels 8 08-29-2005 11:13 PM
