06 leaking oil from front diff - TTORA Forum
post #1 of 6 (permalink) Old 12-08-2006, 02:48 PM Thread Starter
I think that my passanger side front diff is leaking I noticed a spot on the driveway then looked under there and found the whole bottom of my crossmember and comming from my what looks like the seal. Is this normal and would a 3" lift make this happen.? help
lajguess is offline
post #2 of 6 (permalink) Old 12-08-2006, 02:58 PM
You talking CV boot, or differential? You only have one front differential, but 2 CV boots that connect to it on each side. If it is coming from the rubber boot, then yes your lift may have caused this due to the increased angle put on the cv joint. The fins rub together because the CV spin all of the time, even thoough your diff is not engaged.
More lift=more rub=shorter CV boot life
2005 Double Cab V6 TRD Offroad
Thule Xsporter on Bed/Yakima Rack in Front
4x Innovations Bolt-on Sliders
Owsley is offline
post #3 of 6 (permalink) Old 12-08-2006, 03:01 PM
pi
the other white meat
pi's Avatar
Send a message via MSN to pi
Have you had your truck offroad and not cleaned the underside? I had my driver's side axle seal shit the bed couple of months ago due to sand/dirt getting in there from wheeling and not cleaning it properly. Dealership changed it no questions asked under warranty.
pi is offline
post #4 of 6 (permalink) Old 12-08-2006, 03:01 PM Thread Starter
its not the rubber boot but where the axel runs into the diff looks like engine oil.
lajguess is offline
post #5 of 6 (permalink) Old 12-08-2006, 04:14 PM
Sounds like a front diff seal. Here is a little bit I found on somone 4runner
http://jaw.ii.net/cars/4runner/diffseal.html
Does it smell like gear lube?
Owsley is offline
post #6 of 6 (permalink) Old 12-08-2006, 04:15 PM
LavosTRD's Avatar
your timing cover is leaking where it meets at the pass side headgasket area....my work has seen 5 of these so far
LavosTRD is offline
Xfer case front output leaking brendog84cj8 Early Tacoma Tech 19 05-21-2014 08:50 PM
I Have a TrueTrac in the front diff with ADD itjobhunter Early Tacoma Tech 30 08-12-2006 04:16 PM
Replaced front axles, now leaking diff oil??? 98aquataco2 Early Tacoma Tech 10 02-28-2006 09:40 PM
front diff oil question nejnbor Early Tacoma Tech 2 07-06-2005 09:13 PM
Tranny and front diff oil amount? TBob Early Tacoma Tech 8 05-10-2005 12:08 AM
