Alignment shop - TTORA Forum
post #1 of 8 (permalink) Old 06-20-2006, 03:13 PM Thread Starter
DZRTRESQ's Avatar
Alignment shop
Can anyone recommend one on the east side? I searched and came up with nada.... Thanks.
Bryan
DZRTRESQ is offline
post #2 of 8 (permalink) Old 06-20-2006, 03:24 PM
ToyBoxAuto's Avatar
Shuman's Auto (480)894-2165, talk to Matt if possible. Tell him Carlos at SRD recomended you. He is also an offroader, so he won't get weird over mods.
Don't count the days, Make the days count
ToyBoxAuto is offline
post #3 of 8 (permalink) Old 06-20-2006, 04:37 PM
Bryan
If you don't go to the one 'los suggests, Tire Pros on Baseline East of Country Club on the north side, down more toward Mesa dr., Rafael is hella cool, they have laser alignments adaptors for up to a 39" tire I believe, and they always take good care of my tire mount and dismount needs and love modified trucks, several 4x4 shops drop vehicles off for them to set up after a lift has been put on. Tell them Kirk with the big white double cab that gets tires mounted every other month sent you.
Truck specs:2001 D-cab Taco with solid axle conversion, front and rear 65" wide Diamond axles, Tundra 8 inch rear w/ARB, H.P. front w/ARB 30 spline Long's, full floating rear from FROR and blah blah blah, IE lots-a cool stuff.
Later~captkirkyota~Kirk
Captkirkyota is offline
post #4 of 8 (permalink) Old 06-20-2006, 04:49 PM
Takama's-N-Shit!
FAUX X 4's Avatar
"Tell them Kirk with the big white double cab that gets tires mounted every other month sent you."
I Break for Rocks.
FAUX X 4 is offline
post #5 of 8 (permalink) Old 06-20-2006, 06:01 PM Thread Starter
DZRTRESQ's Avatar
Thanks guys...
Now for the problem! I cant get the bushings out of my rear leafs... Im putting some new shackles in the back, which require new bushings as well. But the stockers are stuck! I already cranked my coilovers up so the rear needs to get done too, I dont want to look like a So-Cal prerunner... So if anyone has any good advice, please let me know. Im heading back out to the garage to make more noise... 480-495-7069
-Bryan
DZRTRESQ is offline
post #6 of 8 (permalink) Old 06-20-2006, 06:03 PM
Takama's-N-Shit!
FAUX X 4's Avatar
Thanks guys...
-Bryan
You need to put some heat to them.
I could be offended by the "Prerunner" comment but I'll let it slide this time!
I Break for Rocks.
FAUX X 4 is offline
post #7 of 8 (permalink) Old 06-20-2006, 06:32 PM
seth_js's Avatar
Send a message via AIM to seth_js Send a message via Yahoo to seth_js
Whitey's Auto in south Scottsdale. $50
-Seth
seth_js is offline
post #8 of 8 (permalink) Old 06-20-2006, 08:52 PM Thread Starter
DZRTRESQ's Avatar
Got the shackles on... Just had to use my air chisel to get the damn bushings out Laters..
Bryan
DZRTRESQ is offline
cant find-alignment specs grumpy Solid Axle Swap Tech 85 03-03-2007 07:12 PM
alignment shop socaltacoma Tires/Wheels 10 11-07-2005 08:47 PM
San Diego Alignment Shops? da'Burd Off Topic 1 10-12-2005 05:10 PM
Shop cant do alignment zosimov21 Suspension 18 09-06-2005 06:39 PM
Alignment how soon after lift? P1michaud Suspension 26 03-24-2005 07:53 AM
