New Rig - Page 3 - TTORA Forum
Go Back   TTORA Forum > Regional Forums > Ohio > General Discussions
LinkBack Thread Tools
Old 03-21-2012, 03:28 PM   #61 (permalink)
i have one fromhttp://www.davezoffroadperformance.com/ little different than most wasn't terrible price and made in usa
redyota is offline   Reply With Quote Quick reply to this message
Old 03-21-2012, 05:14 PM   #62 (permalink)
Full_Tilt_Fud's Avatar
My Rig: 1985 Pickup
The only one I see on davez sight is trailgears for 130 which is more than on tgs sight. Is there another one I am missing?
~ Todd
85 ex. cab 1 tons, coilovers, ect
09 Dodge Ram 2500 w/ a Cummins.....Tow rig
Full_Tilt_Fud is offline   Reply With Quote Quick reply to this message
Old 03-22-2012, 08:01 AM   #63 (permalink)
Mr. President
head's Avatar
Send a message via AIM to head
I like my trail-gear one. Used the winch for the first time yesterday to pull about 8 stumps out. Didn't tweak or flex at all, and some of the stumps pulled the truck accross the yard with the brakes locked up. Just make sure you reinforce your front cross member first.
~Jed
1984 Pickup Extended Cab - Trail Rig
Locked F/R, 4.88's, 37's, Hi-steer, Twin stick, Dual cases, Flatbed
1986 4runner - e-locker, 4.56's, 31's
1986 Pickup Extended Cab - Work in progress
2004 Chevy 2500HD Duramax 4x4 - Tow Rig
2004 Tacoma Extended Cab SR5 TRD 4X4 - SOLD
Blue Ribbon Coalition #51205
PhotoBucket Page
OHTTORA
head is offline   Reply With Quote Quick reply to this message
Old 03-22-2012, 04:27 PM   #64 (permalink)
Old 03-29-2012, 09:11 PM   #65 (permalink)
My Rig: 1985 Pickup
Got new trans crossmember 3/4 way done tonight...gotta add a couple more bolts and gusset it then its on to the winch.
Also installed cb, and picked up a stereo....its coming along.
~ Todd
Old 03-31-2012, 09:21 AM   #66 (permalink)
My Rig: 1985 Pickup
Crossmember is in....just gotta finish gusseting it.
Also, after many beers worth of deliberation, I said f' it and ordered the trailgear winch mount...it's just not worth messing with building my own
~ Todd
Old 03-31-2012, 08:15 PM   #67 (permalink)
My Rig: 1985 Pickup
~ Todd
Old 04-01-2012, 07:53 PM   #68 (permalink)
Mr. President
head's Avatar
Looks great. Did youhave someone cut it out and bend it for you?
I've found that in some instances, it's way easier to just let someone else do all the engineering and fabbing and just buy prebuilt pieces.
~Jed
PhotoBucket Page
OHTTORA
Old 04-01-2012, 08:08 PM   #69 (permalink)
My Rig: 1985 Pickup
I looked at budbuilts, then took a tapemeasure to my truck and drew a picture of what I needed. Went into the sheet metal shop next to work and showed them....they had a piece of 3/8" flat strap, 6" wide that they bent for me....gave it to me for free. The front gusset and the rear part that covers the back of the case I cut out of 3/16 with the plasma.
It turned out ok....i lost 1 bolt per side since 6" is narrower than stock but it still has a total of 6 bolts holding it on which should be plenty.
I also messed up somehow when measuring and the valley of it ended up about 1.5" deeper than it had to be....but I still gained a crap load ovet stock and I have a total of 2.99$ invested in it so I dont reall care lol.
~ Todd
Old 04-13-2012, 07:20 AM   #70 (permalink)
My Rig: 1985 Pickup
I now have a functioning stereo and in dash cb. Winch plate should be here today...so I can wrap that up. Gonna do a little front fender trimming and swap the steering box if time allows and be ready to wheel somewhere end of the month.
~ Todd
Old 04-13-2012, 07:25 AM   #71 (permalink)
My Rig: 1985 Pickup
Question: how far off the bumpstops are you guys sitting, as in how much up travel do you have?
~ Todd
Old 04-13-2012, 08:52 AM   #72 (permalink)
up front im got about 3in till bumps then about an extra t2in in the progressive stops till they stop compressing
Old 04-13-2012, 09:11 AM   #73 (permalink)
My Rig: 1985 Pickup
That sounds almost identical to mine
~ Todd
Old 04-13-2012, 09:27 AM   #74 (permalink)
Mr. President
head's Avatar
I think I sit about 2-3 inches as well. But I don't have fancy progressive bump stops. Just universal urethane ones.
~Jed
PhotoBucket Page
OHTTORA
Old 04-13-2012, 09:36 AM   #75 (permalink)
My Rig: 1985 Pickup
I dont know what mine are lol
I do know I am 3.5" off them.
~ Todd
Old 04-13-2012, 10:16 AM   #76 (permalink)
i know once i am on the bumps my springs are also touching the fame on the shackle side and the the bumps are a universal thing that i just had laying around but im rather fond of them now.
Old 04-14-2012, 06:09 AM   #77 (permalink)
My Rig: 1985 Pickup
Next question Jed,
When you put your tg winch plate on did you just bolt it on or did you weld it too?
~ Todd
Old 04-14-2012, 10:16 AM   #78 (permalink)
Mr. President
head's Avatar
Originally Posted by Full_Tilt_Fud View Post
Next question Jed,
I just bolted mine on with 6 bolts. You have to replace the stock crossmember though if you do that. I made a new cross member out of 2.5" receiver stock and 2.5" angle. I welded captive nuts to bolt the winch plate to. It held up great pulling stumps, but I have yet to use it pulling my truck. Unless you count pulling my truck accross the yard with the brakes locked up when doing the stumps.
~Jed
PhotoBucket Page
OHTTORA
Old 04-14-2012, 08:48 PM   #79 (permalink)
My Rig: 1985 Pickup
Got it all mounted. Trimming the grill was a real bitch. I ended up bolting it on with the four center bolts then welded it around the outer bolt and in some other areas. Replacing the crossmember really was not option since I had reinforced it and welded the crap out of it when I put the new hanger on a while back.
~ Todd
Old 04-15-2012, 06:11 PM   #80 (permalink)
My Rig: 1985 Pickup
Made a spare tire holder out of a old gm unit bearing and a piece of pipe...its a little redneck but its better than the ratchet strap I had and it was free
~ Todd
Old 05-15-2012, 06:37 PM   #81 (permalink)
My Rig: 1985 Pickup
Bought a old junk, bent to hell dshaft from pullapart...cut it apart....then had glen put it in the lathe and cut the welds where the tube meets the ends so now I just have the ends with the little nubs. I then went and got a piece of 2.5" id schedule 40 pipe which is about ..25 thick...the nubs on the ends fit in it pretty good...a little play but it fits tight enough I think I can get it square enough for what I need.
I wish it were a little smaller than 3" od but its not that bad and it should be tough as hell so its nbd.
~ Todd
Old 05-15-2012, 06:40 PM   #82 (permalink)
My Rig: 1985 Pickup
Also got a new steering box so I can drill and tap it properly. I tore it all down and cleaned it, now just gotta drill and tap it
~ Todd
Old 05-15-2012, 08:23 PM   #83 (permalink)
ugly's ok's Avatar
good take lots of picks and send them to me on my phone I have to do the same thing one day
driveline is still stock www.pete4x4.shutterfly.com
Originally Posted by tacotoy
lol why would you want to? you already post to yourself
ugly's ok is offline   Reply With Quote Quick reply to this message
Old 05-15-2012, 10:26 PM   #84 (permalink)
Truck is bad ass. Why dont you make it street legal and drive it to-from wheeling spots?
85 sr5 and 87 merged to become the sr3, buildup in progress.
09 dbl cab TRD taco kiddie hauler
Warsloth is offline   Reply With Quote Quick reply to this message
Old 05-16-2012, 05:40 AM   #85 (permalink)
My Rig: 1985 Pickup
Really all it needs is turn signals, a better rear driveshaft, and some different tires.
~ Todd
Old 05-16-2012, 09:15 PM   #86 (permalink)
Do it! I keep extra wheels and tires around just grab them every chance i get. Have a decent set of street tires stock size i took off the 85 and some misc wheels. I really need to find some badass tires and set up a good rig. Want to take my 85 and build a new frame and slap panels on to make the body like an effin tank.
Old 05-23-2012, 03:52 PM   #87 (permalink)
My Rig: 1985 Pickup
built my new driveshaft last night....it turned out really sweet....I think lol. We had no dead sure way to make sure it was square but the nubs on the flanges fit inside the pipe pretty snug and we did everything we could to make it as square as we could....it is better than the old one I can gaurentee that much LOL.
If any of you are looking to build a new driveshaft the 2 1/2" id schedule 40 pipe is where it is at....it is almost perfect size, beefy, and cheap.
~ Todd
Old 05-23-2012, 07:25 PM   #88 (permalink)
My Rig: 1985 Pickup
Put the new drive shaft in and pulled the old steering box out. Apparently the box is really fucked up lol. If I grab the input shaft I can spin it and turn the pitman arm....however if I grab the pitman arm I can not turn it...it binds tight...something inside is fubar for sure.
~ Todd
Old 05-23-2012, 10:57 PM   #89 (permalink)
Ernies foreign salvage 740-773-5912
If they have a part you need there IE steering box, or hubs, I can run down and get it for you, and probably ship it to you, they arent one of these network yards, just let you fish around and see what they have. Theres a couple others, town n country is further north, and Rons (foreign) salvage is just down the road from me, they had some toyotas last time I checked, but I was pissed off last time I priced something there. Wasted a lot of my time because their place is so big, and then were sky high on price for some rusty ass wheels.
Can probably look town n country, and Rons, on google for phone#
Same deal goes for anyone, you want me to look at a junkyard for something, or pull and ship I can do it. Would like to trade for some help, but no one lives down here.
Old 05-24-2012, 09:43 PM   #90 (permalink)
My Rig: 1985 Pickup
Put the new steering box in...was pretty much a giant pita but it is in and works good so far. Pulled the old one apart and the worm geat in the input was all broke to hell....i have no idea how it was still steering.
~ Todd
Insurance
» Premium Vendor Showcase
» Recent Discussions
2.7 Timing chain?
12-20-2007 04:30 PM
Last post by RDCRunner
Yesterday 10:30 PM
21 Replies, 13,438 Views
Cougar Buttes - Feb. 18,...
01-19-2017 02:07 AM
by sparky
Last post by gofj80
Yesterday 05:55 PM
8 Replies, 178 Views
getting a frame...
01-12-2017 06:27 AM
Last post by Brake Weight
Yesterday 03:58 PM
2 Replies, 184 Views
Wraith Spawn
10-19-2016 06:37 AM
Yesterday 03:44 PM
1 Replies, 193 Views
Bomber basher
07-15-2016 01:40 AM
Yesterday 03:38 PM
3 Replies, 388 Views
Big Bear snow run - Jan...
01-20-2017 05:51 PM
Last post by ShowStop
Yesterday 02:17 PM
5 Replies, 250 Views
Intercooler/Aftercoo...
06-30-2008 05:18 PM
Last post by Jwsav1
01-22-2017 11:12 PM
26 Replies, 6,174 Views
TruckHaven in March
01-16-2017 11:04 PM
Last post by 4x4orTOY
01-22-2017 04:26 PM
2 Replies, 156 Views
Dash lights come one...
03-05-2011 10:58 PM
by Tipsovr
Last post by John T
01-22-2017 03:57 PM
10 Replies, 14,122 Views
Random Picture thread.
01-16-2006 03:20 AM
Last post by mountainguyed67
01-22-2017 08:35 AM
7 Replies, 1,280,457 Views
» Buyer's Resource
