Reassembling rear end... - TTORA Forum
post #1 of 5 (permalink) Old 07-07-2009, 01:31 PM Thread Starter
im in the process of replacing my rear axle housing on my '92 4x4 pickup. few questions:
1. i cut my U-bolts to get them off. can i use a u-bolt flip kit and keep the stock lower strut mount plates? all i need are new u-bolts but the flip kit is as cheap as 4 individual ones but i think they need custom welded new strut mounts...
2. i need to replace the two triangular center bumpstops. where is the cheapest source for replacements? could i still use stock ones with the flip kit (dont think i can) or should i just custom mount a set of bumpstops to the upper brackets that hang off of the frame?
3. what are those round bushings called that are mounted toward either end of the rear leaf springs? not at the very ends but hanging off of the top between two vertical tabs/brackets. 2 of mine are missing, just the brackets are there - they appear to be bumpstops as well?
4. anybody recommendations for a good website for rear brake parts? i need drums / shoes / cylinders.
i can post pictures tonight if necessary. any help would be great, its sitting in pieces and id like to get parts ordered so i can get it back together again!
cp[mike] is offline
post #2 of 5 (permalink) Old 07-07-2009, 01:50 PM
What's Mommy Say?
jtaco1's Avatar
Send a message via AIM to jtaco1
1. I would get the u-bolt flip and weld a set of shock tabs to the axle. I did this on my 4 Runner, works fine.
2. You can reuse the stock ones and tack them to the u-bolt flip plate, or pick up a set of universal bumpstops, ebay has them often, and mount them to the bracket that hangs down from the frame. This is how mine are mounted.
3. Those are to hold the springs if too much weight is put in teh bed, I wouldn't worry too much about them.
4. For brake parts, check out Rock Auto online. They usually have great pricing and all the parts needed.
JT
DD - 05 Toyota 4 Runner
Trail Rig - 88 4 Runner with dual cases w/ 4.7's, 37" PB Rockers and no lift
Was
99' Toyota Tacoma Crushed by Toyota
jtaco1 is offline
post #3 of 5 (permalink) Old 07-07-2009, 02:35 PM Thread Starter
sounds good. i am assuming shock mounts are designed to work with stock length shocks? i will have to look into a pair of those to supplement the flip kit. i still have to get the TG armor welded on so i will get these done at the same time.
and rockauto does appear to have good prices... thanks for the website!
cp[mike] is offline
post #4 of 5 (permalink) Old 07-07-2009, 05:53 PM
corax's Avatar
2) http://www.suspension.com/Bumpstop.htm <- simple mounting with a post & nut + these guys are easy to deal with, I always go to them for any urethane/bumpstop needs
-Keith-
'88 4runner SR5 - 3L 7MGE - Marlin HD W56 - 4.56 V6 Thirds - 7.5" Supra LSD up front - 33x10.5 KM2's - home fab front and rear bumpers - OME Dakar rear springs w/ Bilstein 5150 reservoir shocks - Garage thread
"Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
corax is offline
post #5 of 5 (permalink) Old 07-07-2009, 07:47 PM Thread Starter
thanks for the link. i actually ordered a set of the 2-1/8" x 2" conical bushing, its the top left #9.9101 (Energy Susp). got it on Summit for 14 shipped, a pair of black ones. going to fit nicely on that bracket.
you werent kidding, they had a set of Rancho OE u-bolts for $30 including hardware, with combined shipping with the other brake parts i purchased - 2x drums, shoes, 2x cylinders, 2x bearings, and a brake hardware kit. that price made me decide to use the OE ubolt setup for now, i couldnt justify $70 for the flip kit + $20 for the strutmounts + the hassle of welding, just to flip my bolts over... now that everything is going to be fresh, it would be very easy to add in the future when i have more of a upgrade plan in mind - right now im just getting it put together.
cp[mike] is offline
2003 Tacoma TRD stock Bilstein rear shocks, rear leaf mounting hardware Box Parts/Electronics/Wheels/Tires 0 07-06-2008 03:59 PM
05+ white grill and rear bumper, solid rear window yosh2000 Wanted 0 09-16-2007 03:21 AM
01 Chrome Rear Bumper & mounts, Driver side rear fender, Tailgate dmaxin Wanted 3 07-23-2006 02:01 PM
wanted rear axle stub and rear diff conecter pad96 Wanted 0 09-07-2005 06:44 AM
F/S: Stock TRD Rear Leaf Springs/Shackles and Rear TRD Shocks sticks Parts/Electronics/Wheels/Tires 2 03-14-2005 05:31 PM
