5 inch shackle on stock springs - TTORA Forum
post #1 of 21 (permalink) Old 08-29-2010, 07:34 PM Thread Starter
Camstoy86's Avatar
gonna order some trail-gear shackles to help level the saggy ass on my 4runner, what are the negative effects of going to a longer shackle?
86 4runner, RUF/chevys, Moose Knuckle Fab bumpers sliders, shock mounts etc.. 4.88s, Mtr's and LED everything.
Camstoy86 is offline
post #2 of 21 (permalink) Old 08-29-2010, 08:41 PM
Gargle my sack
TheAussie1's Avatar
TG FTL, and I wouldn't run JUST longer shackles, get bigger springs too IMHO
Don't Brace Me Bro!
TheAussie1 is offline
post #3 of 21 (permalink) Old 08-29-2010, 09:12 PM Thread Starter
Camstoy86's Avatar
well if I got springs I wouldn't need the shackles, I'd be too high
post #4 of 21 (permalink) Old 08-29-2010, 09:17 PM
Ranger1's Avatar
Send a message via Skype™ to Ranger1
Just get the springs...shackles are crap.
-Aaron
'99 SR5 4Runner
Not much of a Signature, huh?
Ranger1 is offline
post #5 of 21 (permalink) Old 08-29-2010, 09:19 PM
Gargle my sack
TheAussie1's Avatar
I've got a mix of both on my truck and couldnt be happier
Don't Brace Me Bro!
post #6 of 21 (permalink) Old 08-30-2010, 12:01 PM
yotabeast86's Avatar
i dont see any problem with running longer shackles. easy and cheap way to level your ride. to be honest with you though id just make my own shackles it would be alot cheaper.
86 longbed pick-up, SAS with 83 front, 5 inch all pro, crossover steering, bilstiens, propane,bobbed,36inch iroks, EZ locker front,welded rear,exo, 5.29 diffs., 4.7 transfer case, dirty 30s.
86 4runner, stock, resto project?/DD
2002 dodge 2500 cummins 4x4, 6spd, 125hp inj, power puck, 5 inch exaust turbo back, B&W hitch, tow rig
yotabeast86 is offline
post #7 of 21 (permalink) Old 08-30-2010, 01:06 PM Thread Starter
Camstoy86's Avatar
I'm gonna get decent shackles, not just cheap autozone specials. I just heard that you get more body roll and that it puts more stress on the springs if you go longer?
post #8 of 21 (permalink) Old 08-30-2010, 02:14 PM
Send a message via MSN to green96taco
What you get is axle wrap. It will make your springs get a negititve arch. You will get more body roll whenever you lift your vehicle.
Dustin
Dustin
1995 Tacoma Extra cab, Billy 5100s, Toytec Coils, Bastard pack rears, 285s
1984 Trans Am 370 LSX/t56.
Originally Posted by wslytoy View Post
I know this one chick, she'll let you suck on her nipple you fucking titty baby. The kit is shit, not as in THE SHIT, but as in the stuff that comes from my asshole.
green96taco is offline
post #9 of 21 (permalink) Old 08-30-2010, 08:15 PM Thread Starter
Camstoy86's Avatar
will it improve flex at all?
post #10 of 21 (permalink) Old 08-30-2010, 09:49 PM
In short, it wont do anything good for you but give you your lift.That lift will soon disappear though as your springs begin to get a negitive arch. The only thing the shackle has going for it over a add a leaf is that it wont reduce flex where the extra leaf will.
Dustin
Dustin
post #11 of 21 (permalink) Old 08-31-2010, 10:58 AM Thread Starter
Camstoy86's Avatar
Dustin
Hmmm ok thanks. I'm only looking to get about an inch, so would a small block work? I have a U bolt flip kit thats going in at the same time.
post #12 of 21 (permalink) Old 08-31-2010, 02:49 PM
Unfortuatly blocks are horrible too. Just add another leaf man. That's the only way to go
Dustin
post #13 of 21 (permalink) Old 09-01-2010, 01:10 PM Thread Starter
Camstoy86's Avatar
ha alright thanks for the help man.
post #14 of 21 (permalink) Old 09-01-2010, 01:18 PM
sasaholic's Avatar
Dustin
ur a moron and need to quite giving advice. longer shackles dont always make springs die faster(get longer bumpstops) and an addaleaf wont reduce flex(dont know how u figure it does) and longer shackles dont always mean axle wrap.(look at all the prerunner guys with 12 inch shackles)
to the op your leafs are sagging for a reason(there worn the F out) so adding and addaleaf shackle or block is only going to be a short term fix if u can even call it that. you need new springs or a set that arent so beat, but finding a good used stock set for your year probably aint gunna happen.
Never make your passion your occupation. it will loose it's luster and become work. that's why i never wanted to become a gynecologist!
1997 toyota 4 runner. lc coils and donahoe coils goin on soon with 255 75 17 brk km's on titan rims
sasaholic is offline
post #15 of 21 (permalink) Old 09-01-2010, 02:52 PM
I have always liked longer shackles in the rear of a Toyota. They do improve flex because they allow the leaf spring to drop down further and compress back more. I have an 88 4runner that had the typical sag, I put some Dave's Offroad 1.5 lift rear shackles and an extra leaf from an 89 2wd pickup. It leveled the truck out and firmed the rear up just a little bit which I like because I pull a trailer and carry a dirt bike on a receiver hitch carrier.
1996 Taco Dana 60, 14 Bolt, dual cases, 42's
blakeape is offline
post #16 of 21 (permalink) Old 09-02-2010, 08:39 AM Thread Starter
Camstoy86's Avatar
did you have any problems with the springs going "negative" when you flexed it?
post #17 of 21 (permalink) Old 09-02-2010, 10:39 AM
sasaholic's Avatar
with longer shackles and no extended bump stops they will always go negative. just extend the bumps like your supposed to and call it a day. how much you lift it is how much you need to extend them generally
post #18 of 21 (permalink) Old 09-02-2010, 12:45 PM
Your a douche bag, Longer shackles do kill your springs, I knew nothing about the longer bump stops. And Ive always seen on here that the short aal like pro comps kill the flex. I know this for a fact as well because I had them on my 96 taco. Just do yourself a favor and make some bastard packs like alot of people do on toyotas and jeeps and mix the leafs the way you want them.
Dustin
Dustin
post #19 of 21 (permalink) Old 09-02-2010, 12:54 PM
sasaholic's Avatar
Dustin
no they dont when set up properly.(proper angle, and not much negative arch). and if your in a tight spot i guarantee that short addaleaf will flatten right out. it will take more pressure to do so, just like my chevys but they sure will. thats why long addaleafs and multileafs are better. i ran a 7 leaf pack that i built to carry more weight from a set of tacoma old toyota and
s10 leafs and they flexed just fine
post #20 of 21 (permalink) Old 09-02-2010, 01:49 PM
What's Mommy Say?
jtaco1's Avatar
Send a message via AIM to jtaco1
Here is my just go with the shackle if all you need is an inch or so. On my 88 4 Runner with nearly 300K on the stock suspension, I installed a 5" shackle to level it out with the heavy top. It worked perfect, now that I do not run the top it gives the rear about 1.5" over stock. With the longer rear shackle I am able to flex the springs much further than the stock shackle affords. My buddy runs a stock shackle on his 4 Runner witht e same suspension setup that I do and I have noticibly more flex in the rear than he does. He will lift a tire and mine will stay planted, and believe it or not, stock rear springs are quite flexy.
As for the use of bumpstops, this is also a big help with my setup as I have about 2-3" of verticle uptravel out back so that the tires do not get into the body too much. The springs do go into a slight negative arch, but hasn't been an issue. I have the bumpstop sitting about .75" off the u-bolt flip pad and the bump compresses about 2" or so adn works very well.
The comment about axle wrap can kill springs, yes it can, but in my experience this slightly longer shackle has had no ill effect on my rear springs, even with a nearly 200:1 crawl ratio running single digit tire presure with heavy ass 37" PitBull Rockers. Sure the springs wrap some, but hasn't been an issue yet in 3 years of heavy use.
JT
DD - 05 Toyota 4 Runner
Trail Rig - 88 4 Runner with dual cases w/ 4.7's, 37" PB Rockers and no lift
Was
99' Toyota Tacoma Crushed by Toyota
jtaco1 is offline
post #21 of 21 (permalink) Old 09-02-2010, 02:48 PM Thread Starter
Camstoy86's Avatar
thanks jtaco. like I said I only really need an inch and I heard that a longer shackle will help flex a little so i assumed thats the best way to go. I'd rather spend 70 bucks on TG shackles rather than dump 300 on new springs for 1 inch of lift. I'm only running 31's so I wouldn't imagine I would get too much axle wrap.
marlin 4 inch springs offroadin88 For Sale/WTB in AZ 6 03-06-2008 06:22 PM
who makes 2 inch lift springs Kaehler Suspension 4 05-24-2006 11:49 PM
2 Inch Lift Shackle Sandhman75 Wanted 3 05-08-2006 11:32 PM
Stock Shackle for 96 pete_santana Wanted 2 02-06-2006 10:00 PM
1.5 inch shackle measurement tacojuice Suspension 1 09-27-2005 07:38 PM
