changed O2 Sensor, Now won't start. HELP! - TTORA Forum
post #1 of 10 (permalink) Old 05-29-2011, 08:17 AM Thread Starter
hayesvegas's Avatar
alright guys i need some help. bought this truck last july. has ran great since i bought it. the p.o. rebuilt the engine right before i bought it. its an 88.
the o2 sensor had been out of it since i bought it and the CE light had been coming on the whole time. so i put in a Beck Arnley splice in sensor in, the p.o. had but the plug off, and there was another splice in sensor in too. when i went to crank the truck, nothing. turns over like a champ but will not crank.
could it be coincidental that my fuel pump has gone bad at the same time and was throwing the code along with the bad o2 sensor? when i turn the key on i cannot hear it prime.
this is my dd and i need to try to get it running by tuesday.
hayesvegas is offline
post #2 of 10 (permalink) Old 05-29-2011, 09:00 AM
Banned
I think the issue is in the o2 sensor wiring I would replace the slice in sensors with plug in's or at least remove the aftermarket wiring from the harness and only use the new o2 sensor wiring
hunter4runner is offline
post #3 of 10 (permalink) Old 05-29-2011, 03:25 PM Thread Starter
hayesvegas's Avatar
the only aftermarket wiring is the new sensor, the old sensor that i took off was an aftermarket. the oe wiring is the same just no plug, it was cut off when i bought it.
i don't see how the o2 sensor wiring would keep it from cranking. the old sensor was dangling underneath the truck caked with mud and grime when i bought it.
can someone give me their on my fuel pump suspicion. tomorrow will be the first chance i have to work on it. i will check fuses and i think there is a relay in there.
correct me if i'm wrong, the fuel pump is in the tank and the bed must be removed to get to it? once the bed is off is it a pain in the neck to change the pump, special tools etc?
post #4 of 10 (permalink) Old 05-30-2011, 08:23 AM
yotaneck13's Avatar
The sensor you replaced it with , was it a heated O2? the 88 truck had a heated sensor ( big black wire in the harness) if you cut it it will look like a radio antenna wire solid center with a braided ground around the outside. In order for the o2 to function the center wire must be spliced along with the outside wire. With that said if your truck craqnks but wont firs id say when you sspliced the wires you got one grounding out somewhere causing no spark issue.
RNR FABRICATION ON THE EAST COAST!!! cullin1234@yahoo.com (814)-516-5176 can recieve txt
R.I.P Derek James Black 1995-2010 I miss you BUD!
"THE GENERAL" My build http://www.ttora.com/forum/18-pickup-early-4runner-tech/175166-1990-general-lee.html
yotaneck13 is offline
post #5 of 10 (permalink) Old 05-30-2011, 08:38 AM
4runnerchevy's Avatar
I agree with Yotaneck. Your truck should start, even without an O2 sensor. Un-wire what you just did and look for problems, isolate all those wires and try and start. If you think its the pump then check fuel pressure. I believe there is a pump electrical check connector somewhere, but its been a while since I have had a Toyota motor.
1986 4runner SAS 4.3 CPI/700R4/4.7/4.88 Twins, RUF's, Welded/Spooled, Hydro Assist, 30 Super Longs, X-Over, Disks out back, Winch, and other stuff on 36"x12.5" TSL's
https://www.facebook.com/SantaCruzWheelers
4runnerchevy is offline
post #6 of 10 (permalink) Old 05-30-2011, 08:40 AM
extremetoy2000's Avatar
Did you read what I posted on your thread on IH8MUD?
If the O/2 sensor wires ground out it can blow your main EFI fuse under the hood. Blown EFI fuse means no power to the fuel injectors.
This happened to me during a snow wheeling trip. As soon as the wires hit the exhaust and melted the fuse blew and engine died.
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE
extremetoy2000 is offline
post #7 of 10 (permalink) Old 05-30-2011, 05:38 PM Thread Starter
hayesvegas's Avatar
blown efi fuse. wired it up again and still get check engine light though.
post #8 of 10 (permalink) Old 05-30-2011, 07:12 PM
Disconnect battery for 30 minutes.
post #9 of 10 (permalink) Old 05-30-2011, 07:13 PM Thread Starter
hayesvegas's Avatar
i'll try that i only did it for about 30 sec.
post #10 of 10 (permalink) Old 06-01-2011, 09:06 PM
give it a shot of starting fluid and crank it if it fires then shutsoff it is probley your fuelpump, just my 2cents
chuckh is offline
'03 3.4L w/ECT is Stalling/Hesitation and won't start.. Could it be a sensor issue? GunshipDriver Early Tacoma Tech 27 05-24-2011 05:52 PM
P0335 No start - crankshaft position sensor PsychoTaco Early Tacoma Tech 5 10-01-2010 12:39 PM
Busted Crank Sensor, no start agbuckle98 Early Tacoma Tech 7 09-09-2006 12:45 PM
Changed plugs and wires now does not start Onimacus Performance/Engine/Exhaust 4 04-18-2006 05:40 PM
Have you changed your Oxygen Sensor yet? Tacoma Jake Performance/Engine/Exhaust 4 06-30-2005 10:40 AM
