1988 Toyota Pickup 22RE - TTORA Forum
post #1 of 9 (permalink) Old 01-02-2008, 02:49 PM Thread Starter
Hi, I have a 1988 Toyota Pickup 22RE and when you first start it up in the morning it makes a pritty lound rrrrrrrrrrrrrrrrrrr ing noise for the first 10-15mins. of warm up. But then it dose not make the noise at all for the rest of the day. And it only makes that noise if I start it early in the morning, when it is kinda cold out side. i have only had this truck for a couple of months and am wondering if this is just normal when it is cold out side. But if I start it up later in the morning it dose not make that noise. Thanks for all of your help.
1988yota is offline
post #2 of 9 (permalink) Old 01-03-2008, 07:59 AM
ky_savage's Avatar
I was making the same noises this morning when I stepped outside leaving work. I also have an '88 22re and it runs a little rough at start up when cold and after it's warm, it is smooth as silk.
ky_savage is offline
post #3 of 9 (permalink) Old 01-03-2008, 08:47 AM
SilverBullet's Avatar
On my old 87, it would vibrate the shroud around the exhaust (heat shield for engine wires) until it warmed up, when the shroud was warm and would expand to make the bolts tight.
If that it the sound you are describing, just tighten everything holding it on when the truck is cold.
If that is not the sound (metal to metal vibration) try to describe it more...
Check out UCORA.org
Brian Letendre, KE6IRJ
"Lifted" in more ways than one
95 4Runner, SAS, 4.88, Locked, Armor, and ready to Rock!
SilverBullet is offline
post #4 of 9 (permalink) Old 01-03-2008, 09:01 AM
Elvi's Avatar
Cold power steering fluid? Does it whine when you turn the steering wheel?
93 PU, 22RE, 4.56, Locked, 8K winch, cab EXO
86 4Runner, 22RE, 4.10; Bone stock.. Fully Restored Garage Queen
Un-Named Buggy, just a pile of parts and a stack of drawings
Elvi is offline
post #5 of 9 (permalink) Old 01-03-2008, 09:24 PM
Norris01's Avatar
could just be the timing chain slapping around a bit until it gets warm and the guides tighten up.
91 yota 4x4...beat to shit...
SAS'ed
4inch TG Springs
4.7 crawler locked f/r
37inch iroks
Norris01 is offline
post #6 of 9 (permalink) Old 01-13-2008, 07:41 PM
check the tensioner of the timing chain.
luispoinciana is offline
post #7 of 9 (permalink) Old 01-13-2008, 07:50 PM
johnnytwelvepack's Avatar
X2 One of the trucks that i had leaked a little at the header flange untill it warmed up. As for the timing chain that noise is usually only heard untill oil pressure comes up about 10 seconds, unless something is very wrong with the tensioner but that would probably make a constant noise.
johnnytwelvepack is offline
post #8 of 9 (permalink) Old 01-14-2008, 11:11 AM
KyleSGorter's Avatar
yuo model 22re uses the AAV to control the idle it is the unit that attaches under the throat of the throttle body and bypasses air past the throttle blade when at idle (closed) position. On older 22res theres an electric motor that opens and closes a small valve to limit idle air bypass called the IAC which would idle up when the engine is cold to aid in warming up the engine and maintaining steady oil pressure until it is heated some. Theres a bimetal spring in you AAV (aux air valve) which acts like a thermostat and closes slowly as the engines coolant approaches OT. Thus when the engine is cold the AAV is wide open and the engine idles up like it should to between 1300-1500rpm and settles as the engine warms to around 800rpms. Likely this is the whirring you hear especially if you have a non-stock muffler and no tach.
Id get a tachometer unit that you can use to set and adjust your idle if your truck doesnt have one. you dont have to spend a bill getting the wiring kit and tach for inside the cab 95% of the time a tach isnt needed especially in these trucks its a luxury. Get a cheapo one from autozone that reads off your dizzy to check your idle.
I can also recomend that you check your timing chain as it will tapp and rub on cold starts if the guides are heavily worn or the chain is stretched because of usage and hot and cold environments. Id pop off the valve cover and use a light to check the guides. if you havent done your chain yet since owning the truck id recomend calling ted stanwood at engnbldr.com or emailing him. he can set you up with a new chain w/ steel backed guides, cover, oil pump, h20 pump etc for a bill and a half shipped. A timing chain with busted guides will make a lot of noise in all types of driving and sounds a bit like pebbles rattling around in an empty beer can. Check your oil and coolant for mixing to make sure it didnt rub through if you do have timing chain woes.
1986 Toyota 4x4 - SOLD
KyleSGorter is offline
post #9 of 9 (permalink) Old 01-15-2008, 11:41 AM
Reasonable engine parts for your timing components availbale here in case you need them. www.japanengine.com. Call or go to their site and ask about your problem.
enginesnparts is offline
1988 4-runner 4wd 22RE 5 speed manual Happysmiley Vehicles/Trailers 6 11-18-2007 12:39 PM
1988 pickup v6 4x4 XSR5X For Sale/WTB in NV 8 07-15-2007 10:18 AM
88 Toyota Pickup 22RE Jackson2008 For Sale/WTB in TX 12 07-09-2007 09:10 AM
Partin Out: 1988 Toyota Pickup 4x4 toyotaman22r Parts/Electronics/Wheels/Tires 1 03-15-2007 11:46 PM
1988 Toyota Pickup JBrown For Sale/WTB in GA 4 10-15-2006 06:34 AM
