Audiophile Thread - TTORA Forum
Go Back   TTORA Forum > Regional Forums > Ohio > Off Topic
LinkBack Thread Tools
Old 02-27-2007, 07:07 AM   #1 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
Send a message via AIM to SuperPoser
Audiophile Thread
Howdy guys,
Post up about your HT, 2ch, and Mobile Audio Systems here!!!
OHIO TTORA
WWW.OHTTORA.ORG since 2006
PA TTORA
WWW.PATTORA.COM since 2002
http://www.facebook.com/kick8472
2007 Blue Taco Double Cab
2004 KTM 200 SX
2003 Green/Tan Spyder 1ZZ
SuperPoser is offline   Reply With Quote Quick reply to this message
Old 02-27-2007, 09:03 AM   #2 (permalink)
HoT_DoGgIN's Avatar
Send a message via AIM to HoT_DoGgIN
Well... I have a sony xplod head unit that came with the truck when I bought it, a set of Alpine type S 6.5" 3 way roundies in the back, and hopefully sometime in the next year i'm going to try putting a sub into the tool cubby, upgrading to another head unit with iPod support, a set of components for the front with the 4-runner tweeter pod mod, and then a nice amp to round it all off...
1998 Toyota Tacoma 2.7L 4wd Xtra Cab
~K&N FIPK Gen II Cold Air Intake
~3" Cornfed Suspension Lift
~Marlin Crawler Heavy Duty Clutch
~Chevy Tow Hook Mod
~Hella FF75 Lights & Custom Bumper Brackets
~Firestone Destination M/T's
~Lit Holiday Wreath/Grille Mod with Bow!! (xmas season)
~Wolo EC Challenger dual trumpet Air Horn -
HoT_DoGgIN is offline   Reply With Quote Quick reply to this message
Old 02-27-2007, 09:59 AM   #3 (permalink)
99TanTaco's Avatar
So does audio tech go here?
every time I crank up my stereo in my truck for more than a few seconds (older Kenwood cd player and Kenwood amp) I'll suddenly lose all sound. the display will still stay on but no noise. If I turn it off and on it will work fine again till next time I crank it up. this just started recently and I haven't made any changes to my system in quite a while. Or hitting the reset button on the face also gets it going again but then I have to reset all the presets if I do it that way
This is kinda important as I need to be able to drown out all the funny noises my truck makes
Also all my wiring should be more than sufficient as my truck was wired for a significantly larger amp which I need to get repaired one of these days
I can get model#s for you later but none of my stuff is high dollar except the amp that is broken sitting at home
99TanTaco is offline   Reply With Quote Quick reply to this message
Old 02-27-2007, 02:08 PM   #4 (permalink)
HT:
Mitsubishi HD 53" widescreen
B&K REF20+ (Upgraded from a Ref 10) Preamp/Decoder
AudioQuest Ruby interconnects
B&K AV5000 5 channel amp
Dish Network HD DVR
Mitsubishi progressive scan DVD
Mitsubishi VCR
Paradigm Studio 20 (Front Left/Right)
Paradigm Studio CC (Center)
Paradigm Bipole surrounds
Paradigm Servo 15 sub
The 4Runner has an Alpine head unit with iPod interface and cheapo speakers
The Impala has a JVC head unit & 12 disc changer feeding into a JLAudio 5 channel amp to drive Illusion Audio separates (6.5" in the front, 8" in the back)
The old truck had TWO systems in it:
(SoundQ)
JLAudio 6.5" coaxials in custom kickpanels
JLAudio 8W6 in the dash
Clarion 9255 (dual 24 bit Burr-Brown D/A)
Clarion 6 disc changer
AudioControl PreEQ
AudioControl EQT (x2)
USAmps 5 channel amp
(SPL)
Clarion 12 disc changer
USAmps VLX50+ (x4 - 1800W each)
JLAudio12W0 (x8)
RedRunnertc is offline   Reply With Quote Quick reply to this message
Old 02-27-2007, 02:11 PM   #5 (permalink)
Sounds like a bad ground is causing the amp to get hot and shut off and protect itself. All grounds need to go to a spot on the FRAME that's been sanded down to clean metal. Make sure all the attachments are still good - you DO induce some .... ummmmm.... vibration shall we say .... with the way you use your truck.
Old 02-27-2007, 02:32 PM   #6 (permalink)
99TanTaco's Avatar
hmm I was kinda worried it would be amp related, hopefully I can get seat bolts out without breaking any, last time I took em out I had quite a struggle
maybe I'll get my good amp fixed (it's got a couple stripped terminals) and slap it back in to make it worth all the effort
at any rate it'll prob be a while before I get motivated enough to check it out
Old 02-27-2007, 02:47 PM   #7 (permalink)
99TanTaco's Avatar
still at work so I don't have model #s in front of me, but heres a basic list, I can get more specific once I get home if neccessary
my old truck 93 Ranger ext Cab
Kenwood AM/FM Cassette in dash w changer controlls
Kenwood 10 disc Changer
Alpine EQ
Crossover (can't remember brand)
Alpine door speakers and tweeters
Alpine 3522 powering door speakers and tweeters
(2) Kicker 10" subs
(2) Alpine 3548s one bridged for each sub
current truck
Kenwood AM/FM Cd player in dash w changer controlls
Kenwood 6 disc changer
XM
polk door speakers
pioneer 10" sub in MTX enclosure (I think its a thunderform?, it looks factory)
Kenwood 4 channel amp, front running doors, back bridged to run sub
Sitting at home broken
Soundstream 4 channel amp
Old 02-27-2007, 02:57 PM   #8 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
Originally Posted by RedRunnertc
(SPL)
JLAudio12W0 (x8)
8 12s?!
cool man!
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Old 02-27-2007, 02:59 PM   #9 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
terry,
I am guessin your kenwood cdplayer used the preouts to the amp, and all speakers driven off the amp?
if this is the case, I agree with troy... sounds like the amp is kicking off for some reason...
if you do have a good ground... take the amp out of your truck, and blow the insides out with compressed air... I had a lot of buildup in one of my amps... it kept doing this, then eventually blew... it was then I finally took it out, and found it full of dust & dirt...
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Old 02-27-2007, 03:03 PM   #10 (permalink)
99TanTaco's Avatar
yes I'm using F&R preamp outputs
How would dirt possibly get im my truck?
Old 02-27-2007, 03:08 PM   #11 (permalink)
save the bewbies!
OFRD_GRL's Avatar
Send a message via AIM to OFRD_GRL Send a message via Yahoo to OFRD_GRL
emmmmm
~Una
My Trucks | Wheeling
OFRD_GRL is offline   Reply With Quote Quick reply to this message
Old 02-27-2007, 03:16 PM   #12 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
Mobile Audio:
1981 Dodge PowerRAM:
Pioneer CD Player
Optimus 4" mids, & 0.75" tweeters running off the Pioneer Head Unit...
Rockford Fosgate 10" Audiophile Subs running of a Prestiege 400Watt Amp...
(sounded very nice, everything was stolen)
1991 Sunbird:
Sony CD Player (top Sony unit in 1998)
fronts: 1997 Rockford Fosgate Punch 125.2, RF 3.5" Audiophile mids, 1" Alpine Tweeter, 2-way RF Audiophile Crossover,
Rears: 1997 RF Punch 225.2, 1998 Alpine 2-way 6x9s,
Subs: 1997 RF Punch Power 500.2, 1996 Punch Power 12s (qty2)
this was a very nice custom install by myself and several friends... and sounded very very awsome! (after several cans of expanding spray spooge/foam for the body)
2002 Taco: ya... I'm still working on this one... but right now I have a pos kenwood cdplayer, the 500.2 running a pos mtx thunderform taco box, and the 225.2 running a pair of jl audio 5x7 components which are very bright off axis, but sound good on axis (damn speakers in the door!)
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Old 02-27-2007, 03:17 PM   #13 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
seriously, that can't be the problem!
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Old 02-27-2007, 03:19 PM   #14 (permalink)
save the bewbies!
OFRD_GRL's Avatar
stock FJ system with subwoofer
4runner - absolutely none whatsoever
~Una
Old 02-27-2007, 03:40 PM   #15 (permalink)
bradleyem's Avatar
Send a message via MSN to bradleyem
Pioneer DEH-P8600MP head unit
MTX Thunder 4200X Amp
MTX Thunder 8.6 component speakers in front
2- MTX Thunder 5500 8" subwoofers in custom sealed enclosures in the walls
I'd like to add another 2 channel amp for the subs and another component set for the rear. It sux having the subs and components powered from the same 4 channel amp, because when you change the volume, it never seems balanced between the subs and components. I just can't find the room for another set of components in the back
Here are some pics:
Newest Project:
1990 4x4 Standard Cab
Winter beater, wheeler and possible SAS...IF I can save it from the Ohio cancer But, for $500, I'm not complaining
bradleyem is offline   Reply With Quote Quick reply to this message
Old 02-27-2007, 03:45 PM   #16 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
I love the 8's in the back!
darn you guys with extra cabs!!!!
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Old 02-27-2007, 04:17 PM   #17 (permalink)
99TanTaco's Avatar
apparently I'm senile my current amp is a eclipse 3640 not a kenwood, the one that I'm to lazy/cheap to have fixed is a soundstream rubicon 404 (freakin huge, just barely fits under the seat)
Old 02-27-2007, 04:48 PM   #18 (permalink)
ugly's ok's Avatar
You mite have a bad voice coil. that would trip the protection serc in the radio.
driveline is still stock www.pete4x4.shutterfly.com
Originally Posted by tacotoy
lol why would you want to? you already post to yourself
ugly's ok is offline   Reply With Quote Quick reply to this message
Old 02-27-2007, 06:43 PM   #19 (permalink)
Originally Posted by SuperPoser
8 12s?!cool man!
8-12" subs + 7200W + ported box = 151.2 dB!
Old 02-27-2007, 09:33 PM   #20 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
individual amp/sub?
thats pretty sweet dude!
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Old 02-27-2007, 09:54 PM   #21 (permalink)
No - 2 subs per amp. Amps were built special to make max power at the impedance of those speakers in that box. Yes, really - I was WAAAAY too much into that stuff, but that's what it takes to place at the World Finals I guess...
Old 02-28-2007, 08:25 PM   #22 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
ok my bedroom system (2ch)
I have my computer and an old Pioneer CD Changer running into a Denon DA-500 DAC via toslink (or whatever the fiber is called)...
a B&K PT3 series 2 preamp
an Anthem PVA 2 amp
and Von Schweikert VR-1 bookshielfs...
I auditioned the VR-1's a wile ago with classic music and they sounded great! when I saw the VS website had B-Stock for 1/2 price, I decided to pick up a pair...
well they do sound great with classic on my system, but just dont' seem to have it for rock... just my opinion, and I am sure repositioning and having stands rather than sitting them on a dresser would help, but oh well...
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Old 02-28-2007, 08:58 PM   #23 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
HT system (hehe)
Marantz DV6500 (SACD & DVD-A Player)
Mitsubishi HS-U445 (VCR & Cable)
Mitisubishi DD-6040 (DVD player)
Anthem AVM 50 (preamp/processor)(link is a similar avm30)
Anthem PVA 7 (7ch amp)
Focal JMLab Chorus S 716 (qty4, Fronts and Surrounds)
Focal JMLab Chorus S CC700 (qty1, Center) (similar in link only 6.5"speakers)
Focal JMLab Chrous S 706 (qty2, Rears)
GE 31" Tube TV (using S-VID )
I plan in the near future:
1080P LCD Monitor (>40" but depends on prices)
BluRay / HD-DVD combo player (when the bugs are worked out)
also looking at the Oppo DV-981HD upconverting dvd player
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Old 03-01-2007, 08:00 PM   #24 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
Personal Planars
thats right!
http://www.decware.com/panels.htm
if the dude ever e-mails me back about the personal planars, I may purchase the plans and give these a go ;o)
we'll see
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Old 03-01-2007, 09:46 PM   #25 (permalink)
Yeah, aren't people converting those Monsoon speakers for computer use?
Old 03-01-2007, 09:55 PM   #26 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
I do not know?
to what Monsoon speakers are you refer?
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Old 03-01-2007, 10:02 PM   #27 (permalink)
I think the ones out of cars - they are a planar type (like a Magnaplanar - not an electrostat like the one you're looking at or a Martin Logan)
A guy I used to work with was a HUGE audiophile, and was putting one together. He bought my old Velodyne sub to go with them...
Old 03-02-2007, 05:22 AM   #28 (permalink)
bradleyem's Avatar
Planars are cool as hell.....I'd love to get my hands on a set of the old Quad ESL57's and matching Quad monoblock amps
I used to have a Marantz tube amp back in high school.....that was the best sounding amp I've ever heard.
Newest Project:
Old 03-08-2007, 10:38 AM   #29 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
I will probably pick up the DAYTON HPSA1000-R 1000W RACKMOUNT SUBWOOFER AMPLIFIER in a few weeks ;o)
time for some new toys
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Old 03-08-2007, 10:39 AM   #30 (permalink)
IN NEED OF TACO
SuperPoser's Avatar
why did ya get rid of it?
OHIO TTORA
PA TTORA
2004 KTM 200 SX
Insurance
4 Link and 3 Link kit Progress thread DrVic@BallisticFab Suspension 57 10-26-2009 07:37 PM
Ultimate FJ Diff Re-Gearing Thread Rockrawler FJ Cruiser Tech 0 01-25-2007 12:16 PM
Parting Out - 2004 Toyota Tacoma V6 4x4 Extended Cab Thread # 2 PWScottIV Parts/Electronics/Wheels/Tires 184 11-15-2006 12:05 AM
Electric Fans, thread in sensor dannn Performance/Engine/Exhaust 8 04-11-2006 04:02 PM
05/06 taco thread J.T.054x4Taco News/Error Reporting/Suggestions/Help 12 01-22-2006 11:02 PM
» Premium Vendor Showcase
» Recent Discussions
Lower Control Arm...
11-07-2010 06:35 PM
by terryj5
Last post by injohneer
Today 09:14 PM
1 Replies, 5,248 Views
Electric Gremlin
04-21-2017 12:56 PM
Last post by Scuba
Today 08:36 PM
4 Replies, 118 Views
2001 Tacoma For Sale
Today 08:19 PM
Last post by alpha_nett
Today 08:19 PM
0 Replies, 20 Views
91 4runner Excessive...
Today 02:28 PM
Last post by Yota4runner91
Today 02:28 PM
0 Replies, 17 Views
3VZE Headers WANTED!
Today 02:24 PM
Today 02:24 PM
0 Replies, 17 Views
log in problem
Today 02:15 PM
by KILROY
Last post by KILROY
Today 02:15 PM
0 Replies, 16 Views
Few upgrades
04-21-2017 09:11 PM
Last post by ShowStop
Today 11:27 AM
1 Replies, 93 Views
Transmission mount...
04-22-2017 09:44 PM
Today 11:22 AM
6 Replies, 130 Views
Looking for a Inside...
Yesterday 04:51 PM
Last post by JTSDIFFS
Yesterday 04:51 PM
0 Replies, 35 Views
Last min.. trip Cougar...
04-20-2017 10:01 PM
Last post by SafetyDang
Yesterday 04:33 AM
2 Replies, 129 Views
» Buyer's Resource
