Do these work? Jet chips - TTORA Forum
Go Back   TTORA Forum > Regional Forums > Ohio > Off Topic
LinkBack Thread Tools
Old 06-13-2007, 05:33 PM   #1 (permalink)
99TanTaco's Avatar
Do these work? Anyone have any experience?
http://store.summitracing.com/partde...5&autoview=sku
Also does anyone see any difference between that and http://store.summitracing.com/partde...5&autoview=sku ?
99TanTaco is offline   Reply With Quote Quick reply to this message
Old 06-13-2007, 09:41 PM   #2 (permalink)
save the bewbies!
OFRD_GRL's Avatar
Send a message via AIM to OFRD_GRL Send a message via Yahoo to OFRD_GRL
jet chips are typically for GMs (and imports i think) and jet modules are typically for Fords.
They do work though. Friend put one in an older camaro and big difference in power to the wheels
~Una
My Trucks | Wheeling
OFRD_GRL is offline   Reply With Quote Quick reply to this message
Old 06-13-2007, 10:02 PM   #3 (permalink)
I have a Hypertech for the Impala, and I feel it made a noticeable difference, but Toyota really locks down their ECU's and the National Board reports I've seen haven't been too positive...
RedRunnertc is offline   Reply With Quote Quick reply to this message
Old 06-14-2007, 05:58 AM   #4 (permalink)
99TanTaco's Avatar
It's for the Ford, l'm thinking I may try this first before spending $$$ to regear
Old 06-14-2007, 08:40 AM   #5 (permalink)
Full_Tilt_Fud's Avatar
My Rig: 1985 Pickup
Go cut one of the wires running to the o2 sensor so the thing runs in open loop all the time........it will do about the same thing that that chip does ........On GAS motors all those chips and programers are about a joke........you may end up with more power but it is never in a good way.
If you want to add some better power / mileage you needto look into what is holding your truck back.......things like exhaust, air intake, ect.........If it were me I would start by freeing up the exhaust flow.......it is god awful restrictive on fords like yours......especially the big blocks.
~ Todd
85 ex. cab 1 tons, coilovers, ect
09 Dodge Ram 2500 w/ a Cummins.....Tow rig
Full_Tilt_Fud is offline   Reply With Quote Quick reply to this message
Old 06-14-2007, 10:48 AM   #6 (permalink)
99TanTaco's Avatar
the factory exhaust is 3" dia, I wouldn't have thought that to be very restrictive
I could see changing the muffler to a less restrictive one but I don't think the rest of it could be made significantly less restrictive
Old 06-14-2007, 11:15 AM   #7 (permalink)
My Rig: 1985 Pickup
Yours does not have the single inlet/ dual outlet muffler where the outlet pipe is like 2.25"??
that is the system I was thinking of..........but maybe I just don't know what the hell i am talking about??
Either way I would spend my money there rather than that chip......my
~ Todd
Old 06-14-2007, 12:58 PM   #8 (permalink)
Well, or they richen up the A/F ratio and give you more power by burning more gas...
Old 06-14-2007, 02:15 PM   #9 (permalink)
99TanTaco's Avatar
it's got a single 3" going in and dual outlets like your saying so the last few feet are dual 2.25 pipes
so would 1 single 3" pipe flow better than the (2) 2.25"pipes there?
I did look at this http://store.summitracing.com/partde...5&autoview=sku but after looking at the size and condition of my current exhaust I did not think I would gain anything, the muffler shop down the road didn't seem to think you could get much less restrictive than the current one either
Old 06-14-2007, 02:42 PM   #10 (permalink)
My Rig: 1985 Pickup
The muffler is the biggest issue..........it flows like crap.
The problem with the tail pipes is......if I remember correctly......is 1. they are not "mandrel" bent meaning they have dimples in the bends and the bends neck down in the middle......where as mandrel stuff (which is what the flowmaster kit is I believe) will be smooth around the bend and will remain the same diameter all the way thrue rather than necking down.......both of witch will help it flow alot better.
the 2nd issue with the factory system is it makes an 90 degree turn at the very end where as the aftermarket stuff should make a "sweeping" bend which will flow better.......think about it this way......can you drive your truck faster around a 90 degree corner or a 45 degree corner??
If I were gonna try something I would try the cat back system and perhaps some sort of high flow air filter / air intake before I would chip it. my
~ Todd
Old 06-14-2007, 04:54 PM   #11 (permalink)
I would do headers before a catback ... 1 - 3" into two 2.25", the bends etc are not going to be the limiting factor.
Air intake could be cheap power - I know on Dodges the stock airbox is SUPER restrictive, you get big power with a cold-air kit.
Old 06-15-2007, 06:08 AM   #12 (permalink)
99TanTaco's Avatar
I did some searching over on a Ford forum last night, from what I found the only real gains could be gained from headers (like Troy said) replacing muffler or doing a cat-back would only improve sound but with no significant gains
As for chips/modules they work but they recommend the more expensive tunable ones like hypertech & superchip sell
Now if I was rich Banks is now making kits for gas engines with significant increases in power http://rds.yahoo.com/_ylt=A0geu8VTgH...sults_AF06.cfm but that kit is around $2000 if I understood correctly
Old 06-15-2007, 07:09 AM   #13 (permalink)
Out of Money
ohio03trdtaco's Avatar
Send a message via Yahoo to ohio03trdtaco
Those numbers for stock are worse than I thought. I new these gen engines wore dogs but come on that is bad. 460 ci engine putting less than 200 hp down to the ground. I would start basic though and put some good spark plugs in wires and cap and rotor and you may want to replace the coil with a good new one. Other things you can try is to advance the timing a few degrees. This is a bit tricky because you have to trick the computer. It did a little bit of good on our 300 strait six.
ohio03trdtaco is offline   Reply With Quote Quick reply to this message
Insurance
Lifts-N-Chips ahaynow Newbie Tech 8 05-09-2007 07:49 PM
Chips or modules johnnyringo Performance/Engine/Exhaust 3 04-24-2006 02:43 PM
cheap chips tacolover Performance/Engine/Exhaust 7 03-24-2006 08:05 PM
chips? tacolover Newbie Tech 23 03-10-2006 06:42 PM
Chips? fast frank Performance/Engine/Exhaust 19 12-22-2005 03:43 PM
» Premium Vendor Showcase
» Recent Discussions
Transmission mount...
Yesterday 09:44 PM
Last post by Brake Weight
Yesterday 11:03 PM
1 Replies, 28 Views
Few upgrades
04-21-2017 09:11 PM
Last post by edschepis
04-21-2017 09:11 PM
0 Replies, 54 Views
Electric Gremlin
04-21-2017 12:56 PM
Last post by Crawler677
04-21-2017 07:16 PM
2 Replies, 90 Views
License plate light...
04-21-2017 04:48 PM
04-21-2017 04:48 PM
0 Replies, 59 Views
Sell CVV Quality 100% -...
04-21-2017 02:21 PM
Last post by beatbills
04-21-2017 02:21 PM
0 Replies, 62 Views
NITRO Lunch Box Lockers...
01-31-2017 04:12 PM
Last post by JTSDIFFS
04-21-2017 12:12 PM
3 Replies, 185 Views
01-31-2017 04:09 PM
04-21-2017 12:11 PM
3 Replies, 214 Views
Cat to exhaust flange...
04-17-2017 05:21 AM
Last post by Beejis60
04-21-2017 08:00 AM
4 Replies, 241 Views
Last min.. trip Cougar...
04-20-2017 10:01 PM
Last post by sparky
04-20-2017 11:22 PM
1 Replies, 85 Views
Old Guy New Here Central...
04-20-2017 01:05 PM
Last post by ShowStop
04-20-2017 09:19 PM
1 Replies, 125 Views
» Buyer's Resource
