The Ultimate IFS CV Axle set. - TTORA Forum
post #1 of 25 (permalink) Old 04-14-2012, 10:07 AM Thread Starter
Tacoeng's Avatar
Has any one had any experience good or bad with an RCV ultimate axle set up for a LT 2005+ Tacoma.
I am looking at upgrading the front CV from the currant stock CV with the Total Chaos extended axle installed. If the axle and CV are installed does the Clamshell diff become the weak link or will it hold up with 35+ tires?
http://www.rcvperformance.com/produc...ku=CVJIFS-TOY2
2006 Tacoma
With a Total Chaos long travel, 4:88s and ARB Air Lockers front and rear.
1990 Solid Axle ( Broke ) but coming back better than new-
Mike V. --- KK6QYJ
Tacoeng is offline
post #2 of 25 (permalink) Old 04-14-2012, 10:10 AM
Scuba's Avatar
I think rippin_red had a bad experience with those guys. Broke an axle and couldn't get it warrantied. Finally I think he got his money back.
Scuba is online now
post #3 of 25 (permalink) Old 04-14-2012, 10:38 AM
j-money$$$'s Avatar
those are 4 grand for a pair!!!!!! They better come gold plated and install themselves
1997 crawlin' 4runner
j-money$$$ is offline
post #4 of 25 (permalink) Old 04-14-2012, 05:41 PM
keepitonall4s's Avatar
I was wondering if they came with vaseline? For that price I would go ahead and link the front instead of long travel. But if you got the money to throw away, hell, go for it.
keepitonall4s is offline
post #5 of 25 (permalink) Old 04-14-2012, 06:07 PM
"Install themselves"
Is FJLed here on TTORA? Check his CVs.
2000 Tacoma
3.4 TRD
ICON C/O
Marlin Clutch
Wainiha is offline
post #6 of 25 (permalink) Old 04-14-2012, 07:44 PM
i thought it was $2000 for a pair? not each. you will wreck and ring and pinion before you take out a shaft or cv though. rippen_red's rcv's were a little to long so they bound up real bad and snapped a shaft, then got the cold shoulder from rcv from what i remember.
the_kernel114 is offline
post #7 of 25 (permalink) Old 04-14-2012, 07:45 PM
FJLED has a set of 930 Adapters from them to run 930 CV Joints on the inner side for the FJ Cruiser with his Camburg kit but he had to determine the length of the axle required and such. I've thought about doing this will my All-Pro kit as well just haven't found the time
theduck911 is offline
post #8 of 25 (permalink) Old 04-14-2012, 08:11 PM Thread Starter
Tacoeng's Avatar
Unhappy
Some good information. I was impressed with the construction of the axles and CVs but you are still working with a small ring an pinion in the front diff. Hard to justify close to 4000.00. As much as I like my IFS I would have to start looking at an SAS before I lay out that much money.
2006 Tacoma
Mike V. --- KK6QYJ
Tacoeng is offline
post #9 of 25 (permalink) Old 04-14-2012, 08:22 PM
im pretty sure it is $2000 for a set, not each. even the d60 rcv's are $2000 for a set and to buy the 930 inner cv's is only $120 each.
post #10 of 25 (permalink) Old 04-14-2012, 09:30 PM
Tiny red truck
johnecon2001's Avatar
When I added it to the cart it added 1 unit. Not two. It says "Axle" in the description... not axles.
Either they're really bad at grammar or it really is $2k/axle.
ARB ~ Bilstien ~ Doug Thorley ~ AllPro ~ Desert Fab ~ Hankook ~ PowerMaster ~ Stubbs ~ Tom Woods ~ Total Chaos ~ TRD Trail Team ~ Bovads ~ Wheelers ~ Nitro Gear
johnecon2001 is offline
post #11 of 25 (permalink) Old 04-14-2012, 09:42 PM
it says "Ultimate IFS CV Axle SET for Toyota FJ Cruiser ('07 and up), 4 Runner ('03-'09) and Tacoma ('05 and up)"
when every other SET of axles rcv sells even through polyperformance.com cost under $2000 (besides the 2.5 ton rockwell set which costs $2195 on poly), i highly doubt adding two $120 930 cv joints would up the price by another $2000. just a bit retarded if you ask me.
post #12 of 25 (permalink) Old 04-14-2012, 10:11 PM
lrgrnr's Avatar
Just buy a couple OEM axles and build them as spares.....they will be the fuse and keep from grenading the r&p.......and you can get them by the hand full.....
lrgrnr is offline
post #13 of 25 (permalink) Old 04-15-2012, 09:17 AM
I see that it does say "set" in the title but if u look at the part number in the little window it say "axle for one side only"
post #14 of 25 (permalink) Old 04-15-2012, 09:54 AM
mpower's Avatar
maybe someone should call rcv and confirm . they are about 2k a pair. if someone actually picked up a phone and called someone, you could get a straight answer. the keyboard cant do everything for you in life.
Defined Engineering
- Fab Services - Installs - Prep -
Light Racing Jouncestop Rebuilding
King Shock Servicing
Yorba Linda , CA 951-217-4947
http://definedengineering.com
2005 tacoma access 4wd sport
getting to be too much to list!!
"I didn't fail 3,000 times. I found 3,000 ways how not to create a lightbulb"-Thomas Edison
"Wise men talk because they have something to say, fools talk because they have to say something."- Plato
mpower is offline
post #15 of 25 (permalink) Old 04-15-2012, 11:25 AM Thread Starter
Tacoeng's Avatar
Yes, good answer. Sent an e-mail to the tech dept to find out the price and options. Have not heard back yet since it is the weekend. If I don't hear from them then it will be a direct call next week. Maybe some other options.
2006 Tacoma
Mike V. --- KK6QYJ
Tacoeng is offline
post #16 of 25 (permalink) Old 04-15-2012, 02:52 PM
Tiny red truck
I saw that, but I also read further down..
CVJIFS-TOY2 Includes axle for one side only
And then as you can see in this image, it lists that model number again for $1995
"Axle comes pre-lubed and includes a Super Duty Chromoly Dome-Mass Cage and Race with SST CV axle shaft fitted with an Ultimate 930 Inboard CV Joint, and a tube of synthetic moly grease."
Again, they could just be really shit with their website layout and sentence function/grammar. But it does make it sound like its $2k per axle.
Too bad they're closed today, or I would just call and settle this.
post #17 of 25 (permalink) Old 04-15-2012, 05:17 PM
i just can't see a toyota ifs axle costing twice as much as a 2.5 ton rockwell axle shaft. doesn't make sense to me lol
post #18 of 25 (permalink) Old 04-15-2012, 09:12 PM
I know for the earlier tacomas they upgrade all of the cv except for the outter stub shaft. That's where I tend to break cvs so it looks like a waste of money to me.
post #19 of 25 (permalink) Old 04-17-2012, 12:16 PM
I have RCVs. They recently updated their website and they hadn't been offering them for quite awhile. Therefore the pricing on poly may not be accurate (poly has listed them forever even though they weren't offering them for Yotas 2010-11). We got one of the first revised prototype sets mid last year.
I'll first say we went with these cause the Camburg LT kit would cycle 14" of travel but the extended axle/cv would bind at droop on the tripod and the rollers would pull out at bump limiting us to 13.25" of travel. Went with these because 1. We wanted to see if the joint really allowed that much more angular movment and 2. I am considering using a similar setup for a future project and this was a cheaper test bed.
RCV was very supportive in getting the axles to meet my expectations at this point. It took a few tries to get things setup the way we wanted, but they never charged for making any of the modifications we requested or replacing parts.
Dan @ RCV was great in getting custom modifications that we requested in order to get everything dialed in and I have no doubt that they'd support the product if an issue came up. The setup does now cycle a clean 14" of travel.
That being said I have yet to test them out (first trip out with the new setup is this weekend) and see how they hold up. So, I'll reserve my judgement/comments until then. The 930 joint is pretty much maxed out at the travel I'm seeing, so I'm not sure there's much more inherent strength at the extreme (inner wasn't normally the OEM end failing tho). However, I'm pretty confident the d60 bell on the outer should hold up well compared to the OEM rzeppa outer.
If you guys have more detailed questions shoot me a pm.
FJLED is offline
post #20 of 25 (permalink) Old 04-17-2012, 07:41 PM Thread Starter
Tacoeng's Avatar
That looks like a great set up. Have fun on the test run and let us know the outcome. Thanks for in input.
2006 Tacoma
Mike V. --- KK6QYJ
Tacoeng is offline
post #21 of 25 (permalink) Old 04-17-2012, 10:28 PM
AZ98TRD's Avatar
I broke a custom set from RCV and also got left in the dark. Also had an awful experience with FOA but that story is for another day.
1998 Tacoma TRD AWD. Lexus 4.7L 2UZ-FE. Lexus A750F 5 Speed Auto. SOLD...
2006 4Runner SR5 4WD. 4.0L V6 1GR-FE. 5 Spd Auto A750F. Bilstein 5100 w/ OME 884 (FRT). Bilstein 5100 w/ OME 895E (REAR). 285/70/17 Nitto Terra Grapplers. BOVADS roof rack. Unitrol Siren w/ Code 3 100w speaker.
AZ98TRD is offline
post #22 of 25 (permalink) Old 04-18-2012, 11:52 AM
BLACKHAWK250's Avatar
Send a message via AIM to BLACKHAWK250
i would just keep replacing stock CV's all day befor i pay 4 g's for those on top of 4 g's orriginally for the front kit/ shocks. If you got 8G's to play with, bring em to a high level shop and have em build u a 4wd centermount set up like a pro 4 truck hahah!
BLACKHAWK250 is offline
post #23 of 25 (permalink) Old 04-22-2012, 12:55 PM
They are not $4k. Standard size for the set is $2k and for one off setups you are looking ~$2,500. They cycle over an inch more than the OEM joints which was our driver. 9" center, with custom cvs, would have still ran considerably more, we priced out the alternatives and are still looking at them for another project.
Took it out to barnwell mountain this past weekend. I haven't tore everything down yet since wheeling, but my general feedback is that I'm quite impressed. Anticipated possibly having some potential issues with them, but they surpassed my expectations. Did everything from high speed runs to testing them out in the rock garden with the locker.
FJLED is offline
post #24 of 25 (permalink) Old 04-27-2012, 07:35 PM
The RCV joints are literally bombproof. The only way you will ever break one in one of these trucks is if they're set up incorrectly. They can't ever see over 45* and you need to make sure the axle shafts are the right length so they don't bottom out or over extend throughout travel. Plenty of guys running these on Pirate with way bigger tires and more horsepower than anyone will ever get out of a Tacoma.
tmorgan4 is offline
post #25 of 25 (permalink) Old 05-03-2012, 01:46 AM
I've had a great experience with RCV. Some of the fastest turn-around for custom parts I've ever dealt with. Turns out I might have a binding issue with my inner joints, and some backlash. Talked to them today and they're sending me new inner joints, no questions asked. Don't even want the old ones back.
I paid just under 2k for my set, and they are a custom/hybrid setup. Cycling 15" clean, after I get the new joints might be able to bump up to 15.5 or 16.
herocopter is offline
Diamond Axle with Spidertrax Ultimate 60 Knuckles 04TacomaDoug Suspension 4 11-13-2011 11:57 AM
Ultimate Rig ? colton1219 Newbie Tech 26 02-28-2011 06:05 PM
The Ultimate! DreamMachine Off Topic 1 09-02-2010 01:10 AM
Ultimate Toy? snowcoma Pickup/Early 4Runner Tech 3 02-24-2010 05:56 AM
Ultimate 4x4 Ludedude Off Topic 4 01-06-2010 03:08 PM
