help bender ?s - TTORA Forum
LinkBack Thread Tools
Old 04-12-2009, 05:05 PM   #1 (permalink)
Moderator
natetru's Avatar
help bender ?s
where is the bend a thon thread? bear i here you have a "modified hf bender....whats the part number and mod? i am on a mission to build a tube bed and possibly a semi cage maybe..........thanks!
84 truck....woohoo for me...currently driven project
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
2003 Rubicon- current d.d. and toy
natetru is offline   Reply With Quote Quick reply to this message
Old 04-12-2009, 08:15 PM   #2 (permalink)
What part of the state are you in?
I broke my back so I cant really do any work for awhile...anyway I have two JD2 benders w/ 1.75 and 1.5 dies you could use if you are anywhere near me.
twentyfootdaredevil is offline   Reply With Quote Quick reply to this message
Old 04-13-2009, 06:30 AM   #3 (permalink)
Moderator
natetru's Avatar
i am in elwood. it is north central indiana.... u?
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 07:44 AM   #4 (permalink)
Moderator
My Rig: 2005 TACOMA DCSB
Sorry nate, the thread name changed to project rockster. Basically, take the HF bender dies the next size down from the size tubing you are using, and grind it out to fit th OD of the tube you are using. get some silica sand to pack the tube with, and bend away!
NwiTACO is offline   Reply With Quote Quick reply to this message
Old 04-13-2009, 08:16 AM   #5 (permalink)
Moderator
natetru's Avatar
so grind down the 1.5 if using 1.75 tube? is it the model with jack or the one with handwheel?
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 08:29 AM   #6 (permalink)
Moderator
I used the 12 ton jack model. I believe they have a 16 ton version as well. Oh, here ya go too:
http://www.harborfreightusa.com/usa/...9&keycode=0000
We ground out the 1.25 pipe die for 1.5 mechanical tubing. Why you using 1.75" ? Sounds like alot of overkill...everyone else seems to use 1.5", .120 wall.
http://www.allprooffroad.com/pickupt...ckupflatbedkit
Blue Ribbon Coalition #4847
'05 Tacoma DCSB on Tons
Old 04-13-2009, 08:34 AM   #7 (permalink)
Moderator
natetru's Avatar
no 1.5 is fine, just thought id match the sliders/front bumper. but 1.5 will work for me. i dont wana go broke doing this so i am thinking of making bed frame outa steel , then the floor and stuff possibly composite decking instead of regular treated lumber? opinions?
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 08:37 AM   #8 (permalink)
Moderator
natetru's Avatar
i like the look of that kit^ i should be able to make it cheaper than 500 bucks even buying myself a bender right?
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 08:46 AM   #9 (permalink)
Moderator
I've been getting 24'-6" sticks of 1.5", .120 wall for around $70, so yeah you can do it way cheaper.
Old 04-13-2009, 08:48 AM   #10 (permalink)
Moderator
natetru's Avatar
where are you getting it? what type? dom or hrew?
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 09:04 AM   #11 (permalink)
Moderator
AAA steel supply here by me. ASTM A-500, this is the basic standard for mechanical tubing which dictates the material properties, yield, etc.
I have been getting HREW, DOM is more $$$, but stronger, not material property wise, but because it hase no weld seam. HREW will be fine, the only real thing we use DOM for here at work, is boiler piping and hydraulic systems.
If the bed is braced/gusseted right, the tubing shouldn't flex enough to split a weld seam.
You can also "orient" the seams to remove them from the principal stress plane for the tube location within the bed. TMI probably, I know, can't help it sometimes.
Old 04-13-2009, 09:09 AM   #12 (permalink)
Moderator
natetru's Avatar
my local supply has 24-6 1.5x.120 for 70.81 a piece so i am good there, they also sell drops for 60cents a pound
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 09:30 AM   #13 (permalink)
Bear's Avatar
My Rig: 1997 Toyota Tacoma
Nate, try Warner steel for your metal "Y" turned me on to them and it has worked out pretty good so far. Their drop is $.50 a pound and they have it organized pretty well also.
As for the Harbor Freight bender, "Y" also has mine right now, but he won't have it for very long, so if you are not quite ready for your project, and can wait a bit, you can use mine that already has the die modified.
But I also know the homemade bender projects isn't a bad idea either, just gets expensive due to having to buy the dye.
BEAR
Originally Posted by abbott
GO SPURS GO!!!!
Old 04-13-2009, 09:43 AM   #14 (permalink)
Moderator
natetru's Avatar
if you would let me use yours then i need not spend extra money buying one. we all are on a budget right now, how long befroe he may be done? i need to get my bed off and "touch up" my frame and prep.
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 09:45 AM   #15 (permalink)
Bear's Avatar
I am not sure how long Bryan is going to have the bender, I do know he was waiting for it from when NWI was borrowing it, so I am not going to rush him over it.
But you are welcome to use it, I rather be used than collecting dust.
I do have a couple of projects I need to work on before take Over, but we have plenty of time, so if you want to borrow it, the timing is pretty good, as long as you can wait for Bryan to finish up which it sounds like you might be able with your touch up stuff.
BEAR
GO SPURS GO!!!!
Old 04-13-2009, 09:47 AM   #16 (permalink)
Moderator
natetru's Avatar
i am not wanting to rush anyone either, but if he needs it for awhile, i may go get one from hf....let me kno, i do appreciate it.........
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 09:51 AM   #17 (permalink)
Moderator
They are only like 79.99 at HF then with the coupon...make one set of doors/sliders for someone, and like AC/DC says your "Back in Black"!
Old 04-13-2009, 09:55 AM   #18 (permalink)
Moderator
natetru's Avatar
hey mark, how are you notching the tube?
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 09:57 AM   #19 (permalink)
Moderator
Just go to the hardware store and get a bi-metal hole saw. Like $10 for an 1.5" diameter. Just go slow and use cutting oil. Works great!
Old 04-13-2009, 09:57 AM   #20 (permalink)
Moderator
natetru's Avatar
hf has a notcher for 50 bucks
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 09:59 AM   #21 (permalink)
Bear's Avatar
I'll talk to Bryan today/tonight and check his plans. I don't think it should be an issue though for anyone.
Hmmm I wonder where you got the "slow and cutting oil" idea from?
BEAR
GO SPURS GO!!!!
Old 04-13-2009, 10:00 AM   #22 (permalink)
Bear's Avatar
can you give me a link to the notcher? I believe it is not much more than a vice that holds your drill and material in place. But I could be wrong
BEAR
GO SPURS GO!!!!
Old 04-13-2009, 10:11 AM   #23 (permalink)
Moderator
natetru's Avatar
basically you r correct, but it also has angle finder on it and may make it easier to get it right???
http://www.harborfreight.com/cpi/cta...emnumber=42324
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 10:14 AM   #24 (permalink)
Bear's Avatar
It's your money, but I think a $10 hole saw, a vice (already have) and a $10 angle finder is cheaper than that notcher.
I am not sure how it would work off a drill press as they have illustrated, like I said, for a hole saw, and the two other existing tools I already have, it is cheaper just to go "primitive" for your notching.
BEAR
GO SPURS GO!!!!
Old 04-13-2009, 10:15 AM   #25 (permalink)
Moderator
natetru's Avatar
thanks....save me $$
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 10:17 AM   #26 (permalink)
Moderator
natetru's Avatar
mark for some reason my puter wont print the sku/barcode for the coupon???
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 10:18 AM   #27 (permalink)
Bear's Avatar
If your vice is like mine, you can rotate it around to basically any angle as well, then drill straight off that mark.
I do my notches this way, and double check the angle with my angle finder which I bought from Lowes for $9.99 if I remember the price right (it even has a magnet on it that sticks pretty good to my tubing)
BEAR
GO SPURS GO!!!!
Old 04-13-2009, 10:26 AM   #28 (permalink)
Moderator
natetru's Avatar
ok, got it to print. also i dont have a drill press thats why i thought it may work out better
85 4runner, sold
86 truck, sold
87 truck, sold
88 4runner, sold
Old 04-13-2009, 10:28 AM   #29 (permalink)
Moderator
I really like the notcher. Unfortunaely I dont have a drill press either.
Looks like it would help on some of the "longer" notches for the smaller joint angles. You can simplify the notching of said "long" notches by using a longer pilot bit to pierce both sides of the tube first to set the angle of the hole saw prior to the hole saw portion hitting the tube.
Nate thy getting to the coupon through this link, it might generate a new sku every time you link to it. And print out a few, make seperate purchases and save on every item
Originally Posted by kruza View Post
Found this on the internet...good till June
20%
I use this every time I go there.
Old 04-13-2009, 11:58 AM   #30 (permalink)
99sr54wd's Avatar
http://metalgeek.com/static/cope.pcgi
99 4Runner, SR5, 3.4L 4WD, 5spd. 265/75/16 Hankook A/T. SS 1.2, Marlin 1200 Clutch, ARB front bumper, BruceTS rear bumper, Tundra Brakes, Brembo rotors, Stubb's HD-SKO sliders.
04 SR5 4.0L 4WD, , Scion H/U, FJC silver Bil' shocks and coils, BFG A/T.
Daily Driver: 2000 Odyssey.
99sr54wd is offline   Reply With Quote Quick reply to this message
Insurance
bender twentyfootdaredevil Off Topic 4 03-03-2009 11:48 AM
bender on CL - TBob For Sale/WTB in AZ 18 06-16-2008 05:10 PM
Bender Amplified Central Region 9 07-26-2007 07:42 PM
Hey... It's Tin Bender Tin Bender Tell us who you are 8 08-03-2006 10:08 PM
i need a bender tacotoy General Discussions 0 07-07-2006 11:14 PM
» Premium Vendor Showcase
» Recent Discussions
Intercooler/Aftercoo...
06-30-2008 05:18 PM
Last post by Jwsav1
Yesterday 11:12 PM
26 Replies, 6,157 Views
Big Bear snow run - Jan...
01-20-2017 05:51 PM
Last post by ShowStop
Yesterday 04:36 PM
3 Replies, 185 Views
TruckHaven in March
01-16-2017 11:04 PM
Last post by 4x4orTOY
Yesterday 04:26 PM
2 Replies, 136 Views
Dash lights come one...
03-05-2011 10:58 PM
by Tipsovr
Last post by John T
Yesterday 03:57 PM
10 Replies, 14,101 Views
Random Picture thread.
01-16-2006 03:20 AM
Last post by mountainguyed67
Yesterday 08:35 AM
7 Replies, 1,280,410 Views
Eaton Performance Payout...
12-23-2016 12:29 PM
Last post by JTSDIFFS
01-21-2017 05:10 PM
3 Replies, 209 Views
12-23-2016 12:29 PM
01-21-2017 05:09 PM
2 Replies, 137 Views
2017 RAD events Area...
01-15-2017 04:40 PM
Last post by m3dragon
01-20-2017 11:44 PM
1 Replies, 79 Views
Hammers
01-20-2017 01:06 PM
by Pawn
Last post by Pawn
01-20-2017 01:06 PM
0 Replies, 51 Views
Cougar Buttes - Feb. 18,...
01-19-2017 02:07 AM
by sparky
Last post by Pawn
01-20-2017 01:03 PM
5 Replies, 128 Views
» Buyer's Resource
