98 t - TTORA Forum
LinkBack Thread Tools
Old 05-27-2010, 05:52 PM   #1 (permalink)
Scottdl99's Avatar
98 t
I bought this T after my Tacoma was bought back a few months ago. Took me forever to find exactly what I wanted. I found this one in KY a few hours from me.
Here's one with my friends 96 T
With the help of Bear I am in the process of installing a ToyTec BJ spacer kit with extended shackles. I will be ordering a 2" body lift (I know, dont say it)for it and then building sliders. Skid and bumpers will follow. I just bought some 33" BFG MT's for it today.
2006 DCS Tacoma
2002 VW Jetta
SOLD-1998 T-100 SR5 4x4: Toytec BJ Spacer kit, AAL, Torsion's turned, extended shackles, Cosmo Racing Intake
Returned-1998 SR5 Tacoma 4x4
Scottdl99 is offline   Reply With Quote Quick reply to this message
Old 06-01-2010, 09:26 AM   #2 (permalink)
Bear's Avatar
My Rig: 1997 Toyota Tacoma
That's false advertising! it don't look anything like that any longer. The bj lift is finished and looks good.
First time I had installed a ball joint lift and it wasn't too bad after the first side was finished. the second side was basically done on "auto pilot"
Scott, let me know what the schedule is for this week. as of right now I just have my truck scheduled to be worked on so we can go pick up the metal or do whatever.
BEAR
Originally Posted by abbott
GO SPURS GO!!!!
Old 06-01-2010, 09:55 AM   #3 (permalink)
99sr54wd's Avatar
what size tubing you guys are gonna use for the sliders?
99 4Runner, SR5, 3.4L 4WD, 5spd. 265/75/16 Hankook A/T. SS 1.2, Marlin 1200 Clutch, ARB front bumper, BruceTS rear bumper, Tundra Brakes, Brembo rotors, Stubb's HD-SKO sliders.
04 SR5 4.0L 4WD, , Scion H/U, FJC silver Bil' shocks and coils, BFG A/T.
Daily Driver: 2000 Odyssey.
99sr54wd is offline   Reply With Quote Quick reply to this message
Old 06-01-2010, 10:43 AM   #4 (permalink)
Bear's Avatar
I should probably let scott answer, but since I know he is at work I'll chime in on what we have been discussing.
whatever dimensional size he goes with, the minimum wall thickness will be .120 but I may have him talked into using .180. ( I know the thickness adds weight, but regarding sliders I like "beefy" over weight savings)
We have been discussion a hybrid type of slider with either square or rectangle tubing for under the rocker panals and then round tubing off of that somewhat like a nerf bar look. He also is thinking about angling the round tube up as well as building a kickout toward the bed end.
I am trying to talk him into using 1"x either 4" or 6" for main beam with 1.75" for the round tubing.
The sliders will have minimum of 4 legs attached to the frame via weld on scab plates.
BEAR
GO SPURS GO!!!!
Old 06-01-2010, 12:04 PM   #5 (permalink)
99sr54wd's Avatar
I like the hybrid better in terms of building one, I'd go 180 wall, too, since they are gonna be pretty long. notching is the most PITA part of the deal.
as for kick-out, I like Stubb's design, simple and effective.
Old 06-01-2010, 03:51 PM   #6 (permalink)
Scottdl99's Avatar
Yeah what you guys said sounds great. thanks for helping out with everything Bear! Here's the pics:
New ball joints and spacer installed.
2006 DCS Tacoma
2002 VW Jetta
Old 06-01-2010, 04:30 PM   #7 (permalink)
99sr54wd's Avatar
I've installed 3 sets of bj spacers on mine and others 2nd gen 4runners. since they are the same as your T100, I would say 2 things:
a.) maybe it's a little late, did you change out the ball joint grease zerk to a straight one, because you can't pack it with the original angled zerk after the spacer.
b.) not too late, get some grade8 nuts and swap out the grade 5 and put on spring lock washers under the nut. they will back out over time. those black head bolts are heat treated so they are fine. do one nut a time, only gonna take few minutes.
Old 06-01-2010, 04:48 PM   #8 (permalink)
Scottdl99's Avatar
Yeah there is a straight zerk on there I can get to easily.
There are some locking nuts that were put ontop of those nuts you see in the pic. That is what the kit came with. I might still try switching those out sometime.
2006 DCS Tacoma
2002 VW Jetta
Old 06-01-2010, 05:00 PM   #9 (permalink)
Bear's Avatar
I was happy to see straight zerks packed with the new ball joints! I loaded the first ball joint before installing but was able to wait on the second one until the ball joint was installed. made it a lot less messy.
on the nuts, I was a bit surprised to see toytec employ a locking nut set up. But it worked out good. I know what you mean about the grade 5's though. I was letting scott "torque" the first nut down, because I have a tendicy to over do it. I stripped out one nut installing the ones you see in the photo, but with as many lifts and what not. I had extra nuts which came in handy.
BEAR
GO SPURS GO!!!!
Old 06-01-2010, 08:04 PM   #10 (permalink)
Full_Tilt_Fud's Avatar
My Rig: 1985 Pickup
When I built my sliders I used 2x2 .188 wall for the legs and main rail under the rocker and 1 5/8 .120 DOM for the outer rail/
I too wanted the round angled up......but I did it different than most and I think it works out better......Instead of laying the inner sruare rail flat and angleing the round up off it I cut the legs off at an angle and layed the inner square rail in at the same angle I wanted the outer round to be at then welded the round square onto it....the angle I ran roughly matched the angle of the rocker.....I also knotched the pinch weld so I could keep everything in close.
By doing it the way I did I acomplished two things.
1. When I bottom out only the corner of the square tube touches which lets it slide along easier than having the entire flat side bottomed out.
2. with the legs angle cut they have more surface area in contact with the main rail that takes all the abuse and therefore more weld.
I hope this rambleing makes sense and is some how helpfull.
~ Todd
85 ex. cab 1 tons, coilovers, ect
09 Dodge Ram 2500 w/ a Cummins.....Tow rig
Full_Tilt_Fud is offline   Reply With Quote Quick reply to this message
Old 06-01-2010, 08:45 PM   #11 (permalink)
Scottdl99's Avatar
Some more shots:
2006 DCS Tacoma
2002 VW Jetta
Old 06-02-2010, 07:56 AM   #12 (permalink)
99sr54wd's Avatar
made these for a classmate's single cab taco, more for show than a real slider. 1.75" 083 tube, tig weld with stainless rod:
Old 06-02-2010, 10:09 AM   #13 (permalink)
Bear's Avatar
so how did it handle going home?
BEAR
GO SPURS GO!!!!
Old 06-02-2010, 10:10 AM   #14 (permalink)
Bear's Avatar
show off!
looks good!
BEAR
GO SPURS GO!!!!
Old 06-04-2010, 08:48 PM   #15 (permalink)
Scottdl99's Avatar
It rode ok. Going in tomorrow to get the torsions cranked and the 33's installed. Hope they fit.
More Pics....
Shackle Bear built
Pic's to compare. My friends T that sat identical to mine pre-lift. what is weird is as they sat from ground to fender mine only sat 1" taller than his.
2006 DCS Tacoma
2002 VW Jetta
Old 06-05-2010, 11:11 AM   #16 (permalink)
Bear's Avatar
how does your friends tire size compare to yours? that may have something to do with yours not sitting as high as you wanted in comparison
BEAR
GO SPURS GO!!!!
Old 06-05-2010, 03:56 PM   #17 (permalink)
Scottdl99's Avatar
Yeah I thought about that. He has 31's and I have 30's on there right now.
I took the truck to 4 wheel parts on east washington today. Ran into some issues tryin to get it aligned today. The front bolt on the passenger side and the rear bolt on the dirvers side are seized up. I found the replacement parts thru the stealership today. The front bushing and hardware are replaceable for about $75. The rear one is the big issue. The whole a-arm will need to be replaced, as the bushing is not replaceable. The dealership said he would give me wholesale on it for $200. I may get lucky and not need any of this if they can break free the bolts. I had them stop working on it today until tuesday when they will put more force and heat on the bolts. I'll let them do what they can and replace what gets broken or cut out.
2006 DCS Tacoma
2002 VW Jetta
Old 06-05-2010, 07:10 PM   #18 (permalink)
99sr54wd's Avatar
50% - 50% mix of acetone and ATF, the single best penetrating fluid on earth, let is soak for couple days see if you can break the bolt loose.
Old 06-05-2010, 09:07 PM   #19 (permalink)
Scottdl99's Avatar
I'll try that. I just hit them with PB. Plan on doing that a few times a day.
2006 DCS Tacoma
2002 VW Jetta
Old 06-06-2010, 10:04 PM   #20 (permalink)
Bear's Avatar
I have used ATF before, but didn't know about the acetone. sounds like a great idea though
BEAR
GO SPURS GO!!!!
Old 06-07-2010, 10:38 AM   #21 (permalink)
My Rig: 1985 Pickup
what alignment spec can't you get into the green?
Even if they won't break free there are ways of cheating to make it all work with out having to replace those parts.
~ Todd
Old 06-07-2010, 06:28 PM   #22 (permalink)
Scottdl99's Avatar
Two of the 4 bolts won't move to be adjusted
2006 DCS Tacoma
2002 VW Jetta
Insurance
» Premium Vendor Showcase
» Recent Discussions
Transmission mount...
Yesterday 09:44 PM
Last post by Brake Weight
Today 02:34 AM
3 Replies, 45 Views
Few upgrades
04-21-2017 09:11 PM
Last post by edschepis
04-21-2017 09:11 PM
0 Replies, 58 Views
Electric Gremlin
04-21-2017 12:56 PM
Last post by Crawler677
04-21-2017 07:16 PM
2 Replies, 91 Views
License plate light...
04-21-2017 04:48 PM
04-21-2017 04:48 PM
0 Replies, 59 Views
Sell CVV Quality 100% -...
04-21-2017 02:21 PM
Last post by beatbills
04-21-2017 02:21 PM
0 Replies, 62 Views
NITRO Lunch Box Lockers...
01-31-2017 04:12 PM
Last post by JTSDIFFS
04-21-2017 12:12 PM
3 Replies, 185 Views
01-31-2017 04:09 PM
04-21-2017 12:11 PM
3 Replies, 218 Views
Cat to exhaust flange...
04-17-2017 05:21 AM
Last post by Beejis60
04-21-2017 08:00 AM
4 Replies, 241 Views
Last min.. trip Cougar...
04-20-2017 10:01 PM
Last post by sparky
04-20-2017 11:22 PM
1 Replies, 85 Views
Old Guy New Here Central...
04-20-2017 01:05 PM
Last post by ShowStop
04-20-2017 09:19 PM
1 Replies, 125 Views
» Buyer's Resource
