Here is what I spent my last week workng on - TTORA Forum
LinkBack Thread Tools
Old 09-20-2010, 11:50 AM   #1 (permalink)
Bear's Avatar
My Rig: 1997 Toyota Tacoma
I had a member from Mississippi come up so that I could build him a set of tube doors and set of bumpers as well as a two piece skid plate. We were also going to try and figure out my truck while working on the fab work.
Needless to say my truck got little attention and we ran out of time before finishing both bumpers. We did manage to finish the tube doors, front bumper and get him a good start on the skid plates. The tube doors turned out nice, especially after the powder coat was applied. But they cost us a full day as adjustments for them became a real pain.
If we would have been able to get the doors to mount up immediately, we would have remained on schedule to get the rear bumpr on, BearAttack possibly running and make the Badlands on Saturday. But as it turned out, one day missed of fab work put us behind almost two days.
here are a few teaser shots.
To view the full album of images of the work we did you can either go to my facebook wall (thought I would never type that in a post) or go here to the photobucket folder:
http://s208.photobucket.com/albums/b...ng%20projects/
A little background on the front bumper. Andrew is planning on incorporating a removable hitch plate styled winch. So we had to design the front bumper to withstand that type of abuse. I think the mounting frame will work nicely to keep the bumper attached to the truck and the receiver I designed should be strong enough to pull an elephant over. There are photos of the how we securd the receiver in the photos. But the basics of it was the receiver was welded both front and rear of the face plate of the bumper, then gussestted by two 3"X3"X1/4" pieces of angle iron completed welded to the top plate of the bumper. The D ring mounts were als welded to the bumper face plate as well as to the mounting frame.
Tube doors were powder coated by Indy powder coat and we used Toyota latches inside some custom boxes I built and welded to the doors. Jeep crasher actually bent the tubing for us for the tube doors, and I think he did a great job!
BEAR
Originally Posted by abbott
GO SPURS GO!!!!
Old 09-21-2010, 08:45 PM   #2 (permalink)
99sr54wd's Avatar
bear,
I know your truck has a leaky O2 bung, but can't remember exactly what the exhaust pipe is. anyhow, I've got this down pipe from a 2000 V6 auto(stolen CAT), if you have a use for it, it's yours.
99 4Runner, SR5, 3.4L 4WD, 5spd. 265/75/16 Hankook A/T. SS 1.2, Marlin 1200 Clutch, ARB front bumper, BruceTS rear bumper, Tundra Brakes, Brembo rotors, Stubb's HD-SKO sliders.
04 SR5 4.0L 4WD, , Scion H/U, FJC silver Bil' shocks and coils, BFG A/T.
Daily Driver: 2000 Odyssey.
99sr54wd is offline   Reply With Quote Quick reply to this message
Old 09-21-2010, 09:03 PM   #3 (permalink)
Bear's Avatar
you have been awesomely kind Tony! I really do appreciate everything, and to answer your question. I would definitely be interested!
We were able to change the spark plugs on the toy last week, and discovered a few interestoing tid bits. #1 the shop that initially drained the fuel cell of the water also changed the plugs and put plugs in that were about 10 mm (estimation) shorther than stock plugs and that two cylindars are running extremely rich. Those plugs look carbonized as if they had been in the motor much longer than the few start ups they actually have on them. So I am going to swap out the fuel pressure regulator in hopes that it is the major problem cause. then go back and fix up all the other crap that has built up around that issue.
Anyway. Cub#1 has a job in Carmel now, so I can pick up the down pipe sometime when I take her to work. Just let me know when a good time is for you.
BEAR
GO SPURS GO!!!!
Old 09-21-2010, 09:12 PM   #4 (permalink)
99sr54wd's Avatar
I can probably drop it off at your home tomorrow, I got an internship gig at a race shop on the westside. if nobody's home, I'll just leave it on the porch.
Old 09-21-2010, 09:16 PM   #5 (permalink)
Bear's Avatar
and I need to go down town in the pm so if you get hung up I can swing by your place possibly. Totally up to you. Thanks again. just give me a call tomorrow and we can work the details out. right now, I need to hit the hay.
BEAR
GO SPURS GO!!!!
Old 09-22-2010, 01:42 PM   #6 (permalink)
Moderator
My Rig: 2005 TACOMA DCSB
Bumper looks good Bear!
NwiTACO is offline   Reply With Quote Quick reply to this message
Old 09-22-2010, 03:57 PM   #7 (permalink)
Bear's Avatar
thanks
BEAR
GO SPURS GO!!!!
Old 09-24-2010, 11:58 AM   #8 (permalink)
Bear's Avatar
I'm waiting for Andrew to take photos of the doors mounted on the truck. We had been putting his truck inside the garage at night when we were working on it since the doors were off. but toward the end of the week, he put the stock doors back on so we didn't have to keep moving things around to get the truck in. When the doors were finished at the powder coaters, it made no sense to put them back on just for photos. He has a thread going on the national board so hopefully he will post those photos there.
He decided on keeping the stock hinges on the doors and door jam and just cut the hinge pins out. in the long run it made mounting the doors a lot easier (but still a chore) to put on. I was surprised that neither the tube doors nor the stock doors rattled. But then again we did make sure and get new pins that were a tad larger and drilled out the existing holes to that new size. In all honesty, I have never felt tube doors so solid on a truck before. there was zero deflection.
I just need to get back to my tail gate project, figuring out my truck, building a fence and finish putting down the transition boards for my wood floors. Oh and find a real job! but as you can tell, I am not busy. LOL
BEAR
GO SPURS GO!!!!
Old 09-24-2010, 11:59 AM   #9 (permalink)
Bear's Avatar
Tony, thanks for dropping off the down pipe! I got it. Sorry I wasn't home when you dropped by. I had to run an errand regarding my son's car. If I can sneak away from my wife this weekend. I may try and get that mounted up as well as mess around some more with the fuel pressure regulator.
BEAR
GO SPURS GO!!!!
Old 09-26-2010, 06:57 PM   #10 (permalink)
Web wheelers anonamous
95toyotan's Avatar
Nice lookin bends there Bear!
Republican
95toyotan is offline   Reply With Quote Quick reply to this message
Old 09-27-2010, 11:19 AM   #11 (permalink)
Bear's Avatar
wish I could take credit for the bends, Dave actually is getting the hang of his tube bender.
where you been?
BEAR
GO SPURS GO!!!!
Old 09-29-2010, 12:22 PM   #12 (permalink)
Hey Bear where do you get your sheet metal and tubing? I would like to buy some for my projects.
JStar100 is offline   Reply With Quote Quick reply to this message
Old 09-29-2010, 10:21 PM   #13 (permalink)
Bear's Avatar
warner steel on E. Raymond st.
http://www.warnersteel.com/index.html
BEAR
GO SPURS GO!!!!
Old 10-01-2010, 08:58 PM   #14 (permalink)
95toyotan's Avatar
where you been?
Workin, workin, workin
Plus I've got a couple other projects/toys taking all my time and money
Republican
Insurance
The best $20 I have ever spent Dirt4dinner General Discussions 9 09-20-2007 06:05 PM
How much money have YOU spent?? Fox4Rnr Off Topic 72 04-23-2007 07:37 PM
Spent rings? hopper Tech 1 02-13-2006 06:35 PM
Spent rings? hopper Performance/Engine/Exhaust 3 02-09-2006 07:48 PM
» Premium Vendor Showcase
» Recent Discussions
2.7 Timing chain?
12-20-2007 04:30 PM
Last post by RDCRunner
Yesterday 10:30 PM
21 Replies, 13,438 Views
Cougar Buttes - Feb. 18,...
01-19-2017 02:07 AM
by sparky
Last post by gofj80
Yesterday 05:55 PM
8 Replies, 178 Views
getting a frame...
01-12-2017 06:27 AM
Last post by Brake Weight
Yesterday 03:58 PM
2 Replies, 184 Views
Wraith Spawn
10-19-2016 06:37 AM
Yesterday 03:44 PM
1 Replies, 193 Views
Bomber basher
07-15-2016 01:40 AM
Yesterday 03:38 PM
3 Replies, 388 Views
Big Bear snow run - Jan...
01-20-2017 05:51 PM
Last post by ShowStop
Yesterday 02:17 PM
5 Replies, 250 Views
Intercooler/Aftercoo...
06-30-2008 05:18 PM
Last post by Jwsav1
01-22-2017 11:12 PM
26 Replies, 6,174 Views
TruckHaven in March
01-16-2017 11:04 PM
Last post by 4x4orTOY
01-22-2017 04:26 PM
2 Replies, 156 Views
Dash lights come one...
03-05-2011 10:58 PM
by Tipsovr
Last post by John T
01-22-2017 03:57 PM
10 Replies, 14,122 Views
Random Picture thread.
01-16-2006 03:20 AM
Last post by mountainguyed67
01-22-2017 08:35 AM
7 Replies, 1,280,457 Views
» Buyer's Resource
