Project "Get er done" a slow build. - TTORA Forum
Go Back   TTORA Forum > Regional Forums > Indiana > Tech
LinkBack Thread Tools
Old 03-15-2009, 07:46 PM   #1 (permalink)
Web wheelers anonamous
95toyotan's Avatar
Cool Project "Get er done" a slow build.
Well figured I might as well start a build thread. It's gonna be a slow process but you gotta start somewhere!
Here's where I started
Next I came across a good deal on some tires to atleast get her dirty and ended up with this.
Republican
95toyotan is offline   Reply With Quote Quick reply to this message
Old 03-15-2009, 09:03 PM   #2 (permalink)
95toyotan's Avatar
Cool The first project
And now for the main reason I started this thread, To give any knowledge (or lack of) back to my fellow Inttora members.
I know that with most things that we are gonna add to our trucks, rust is gonna be a problem. And This is where I hope I can help! Now powder coat or rhino liner would be my first choice but since I can't afford that, this is what I've come up with.
First, start off with nice clean welds ( thanks dave ).
Next I knocked off any weld splatter and wire wheeled every weld. Then I wiped with a prep solvent to prepare for the caulk, yep caulk. I used an adhesive paintable bathroom caulk because I couldn't find what I usually use "sikaflex". That's good stuff, use it if you can find it. The caulk is to help shield the weld from the elements,and can make some ugly welds look purdy! It smooths out the highs and lows and fills any holes, all to allow for better paint coverage and protection.
Should look kinda like this
Make sure to sand off any rust or steel coating.
Then after drying I wiped it all down and sprayed the entire piece with a rust converter. Here's some of the stuff I used.
After that dried I gave it a good coat of a quality primer.
And that's as far as I got today.
Republican
Old 03-16-2009, 09:16 AM   #3 (permalink)
Brian
brinner's Avatar
brinner is offline   Reply With Quote Quick reply to this message
Old 03-22-2009, 09:27 PM   #4 (permalink)
Bear's Avatar
My Rig: 1997 Toyota Tacoma
Originally Posted by brinner View Post
good idea..."Y" had a good back ground in body work and heavy equipment "finish out" work.
BEAR
Originally Posted by abbott
GO SPURS GO!!!!
Old 03-23-2009, 09:10 AM   #5 (permalink)
I used to use the caulk trick when we did a lot of sheet metal work on the race cars.
DN1911 is offline   Reply With Quote Quick reply to this message
Old 03-23-2009, 10:37 AM   #6 (permalink)
Moderator
My Rig: 2005 TACOMA DCSB
I used the "JB-weld" trick to smooth out the welds on the tube doors...
Blue Ribbon Coalition #4847
'05 Tacoma DCSB on Tons
NwiTACO is offline   Reply With Quote Quick reply to this message
Old 03-23-2009, 07:20 PM   #7 (permalink)
95toyotan's Avatar
Yep caulk and JB weld can make the welds look better, But my primary reason for using it in this application is to help prevent rust. But on bumpers ect. it will definately make the welds look smoooth!
Republican
Old 03-24-2009, 07:25 AM   #8 (permalink)
Bear's Avatar
my stinger bar has epoxy (jbweld) around it's joints. but that was because my welds looked like crap and I needed to dress them up.
On the trailer, Pam decided it needed to be painted since it had sat outside it's entire life so far. so I am in the process of "scaling" all the ramps and such. I forgot I had a product on the shelf called Jasco. So I wired wheeled the parts last night and coated them afterwards with the Jasco to kill the remain microscopic rust.
You make no mention of any metal prep such as that product. Do you not believe in that kind of stuff or do you feel primer over the bare metal is enough?
BEAR
GO SPURS GO!!!!
Old 03-24-2009, 07:18 PM   #9 (permalink)
95toyotan's Avatar
Yep it's in the picture, the can that says rust converter. I've never heard of jasco, but as long as it's a rust converter it should work. It's probably not really necessary but as much as I hate rust, anything that I can do to slow it down is well worth it!
I'm still working on borrowing a tube bender so maybe I can finish up this project
Republican
Old 03-24-2009, 08:22 PM   #10 (permalink)
Bear's Avatar
Jasco is more of a "wash" than a converter. but I brushed the Jasco on the parts last night and forgot about them until this evening and when I was putting the tools up noticed them.
NOt a bit of red/orange color on the metal. and it is all steel black again. I'll leave the stuff on until I get ready to paint them but you are suppose to wash this stuff after it is finished.
Just let me know about the tube bender, ironic that you mentioned it. I got to thinking about that rather "large" project we talked about on the drive to red bird. Your idea is sounding more and more enticing. Just need to talk to Pam like I said which is not good timing at the moment.
BEAR
GO SPURS GO!!!!
Insurance
Project "BR" - A Mild Build TRoss The Garage 61 09-19-2014 07:13 PM
Project "screw toyota and their diesel hate" bloc Tech 7 10-02-2008 07:47 PM
Paging Project "GoldMember" Crew... NorCalBorn General Discussions 3 03-14-2008 04:56 PM
PROJECT RIG: Converting a "Prerunner" to a 4x4 For a Friend, need parts! Boston Mangler Early Tacoma Tech 22 05-24-2007 03:07 PM
Need to slow down "hyper" turn signals Bear Interior/Electrical/Electronics 10 01-18-2006 05:00 PM
» Premium Vendor Showcase
» Recent Discussions
Photobucket WTF!!!
Today 08:05 AM
by Yanman
Last post by Yanman
Today 08:05 AM
0 Replies, 2 Views
2017 Schedule of Events
01-09-2017 12:45 AM
by sparky
Last post by Dawson 5
Today 01:36 AM
7 Replies, 984 Views
HELP Wired reverse...
06-20-2017 11:52 PM
by Wittler
Last post by NorcalPR
Yesterday 10:20 PM
3 Replies, 186 Views
What wheels for a 2000...
Yesterday 05:39 PM
Last post by Scuba
Yesterday 09:10 PM
2 Replies, 45 Views
constant beeping while...
06-27-2017 11:32 PM
Last post by Scuba
Yesterday 09:07 PM
2 Replies, 54 Views
Hello from Ingram Texas
06-26-2017 07:33 PM
Last post by Scuba
Yesterday 09:01 PM
7 Replies, 91 Views
Towing a 91 4Runner 5 Spd
Yesterday 06:15 PM
by RichG
Last post by ShowStop
Yesterday 08:51 PM
1 Replies, 30 Views
Completely new to...
Yesterday 06:13 PM
Last post by Jessehalderson
Yesterday 06:13 PM
0 Replies, 25 Views
Summit front rotors
04-27-2017 07:47 PM
by Jblong
Last post by jlake0540
Yesterday 02:43 PM
1 Replies, 221 Views
2001 Toyota 4Runner part...
03-31-2016 03:50 PM
Yesterday 05:53 AM
15 Replies, 1,588 Views
» Buyer's Resource
