Clutch issues - TTORA Forum
post #1 of 6 (permalink) Old 04-15-2009, 02:08 PM Thread Starter
Clutch issues
Whats up everyone hopefully someone can help me im totally frustrated. Put a new clutch in a few months ago.. I have a 2000 Tacoma 4x4 3.4L I know all toyotas are self adjusting cluches but it releases just as high as my old worn out clutch. Also if I am going to a stop down hill push the clutch it shuttters really hard (only going down hill) I looked for threads about this but found nothing... Any in site?
fishin4life0228 is offline
post #2 of 6 (permalink) Old 04-15-2009, 02:43 PM
it shudders when you push in the clutch when you are rolling downhill???
as far as the enguagement, you can adjust that on the petal itself. there is a pin with a retainer clip on it that goes to the clutch master cylinder. take the pin out and turn it in a few turns and it will lower the enguagement lower on the petal
carl11 is offline
post #3 of 6 (permalink) Old 04-15-2009, 02:47 PM
The release point generally does not change when you put in a new clutch. Due to the hydraulics, the release point is usually always about the same.
The shuddering could be hot spots on the flywheel if it wasn't properly machined when the clutch was replaced, assembly grease contamination, warped clutch disc or just weak damper springs on the clutch disc.
Since you say the shudder happens when you disengage the clutch on a downhill, that sounds like the clutch disc is still trying to grab. What type of clutch was installed?
ShowStop is online now
post #4 of 6 (permalink) Old 04-15-2009, 02:48 PM
GatorTaco's Avatar
Send a message via AIM to GatorTaco
I've never heard of the shuttering you describe...
and Carl- I'll have to look into that.. I just figured the clutch depth was in the design.
-Chris
'99 Taco V6 4x4 Manual Everything
Rearranging Photobucket account- for broken pic links, PM me with link to thread
GatorTaco is offline
post #5 of 6 (permalink) Old 04-15-2009, 03:00 PM
it is in the design, but if you dont want it to let out so high, you can turn that rod inward and it will lower the petal height
carl11 is offline
post #6 of 6 (permalink) Old 04-15-2009, 04:09 PM Thread Starter
issues
Wow!! Just Wow.. You guys are on top of things.. I will adjust the petal .. It is a marlin clutch..I did resurface the flywheel but the guy who did it .. did it for free we all know what that means. I <3 TTORA
Clutch Issues chevyracer8262 Early Tacoma Tech 4 07-18-2007 07:08 PM
Clutch issues swank501 Tech 7 05-01-2007 12:30 PM
Clutch Issues jfrizzle Newbie Tech 6 01-01-2007 08:42 PM
Clutch Issues mdbuckle Newbie Tech 4 04-03-2006 12:22 PM
Clutch issues..... again wslytoy Performance/Engine/Exhaust 8 03-23-2006 10:19 PM
