Truck wont idle when warm starting - TTORA Forum
post #1 of 9 (permalink) Old 12-01-2009, 07:46 PM Thread Starter
Arrow Truck wont idle when warm starting
After I have been running the truck and the engine is up to temp if I turn the truck on ,say to get gas or something really fast, when I turn the truck back on it wont idle and will actually stall if I don't give it any gas. I have found though that if I blip the throttle up to at least 3500rpm it will fix itself and idle. Any ideas? Thank you in advance for the help
Wisdomracer is offline
post #2 of 9 (permalink) Old 12-02-2009, 09:10 AM
Check if it is affected by your AC being on. Set the level at anything but the two windshield settings, because your AC will come on automatically on either of these two settings, or turn the fan off completely. If the issue resolves itself when the AC is not running, it is probably your AC idle up circuit.
'02 Double cab, 5 speed swap, dual T-cases, dual FJ80 axles, dual E-lockers, 37" MTR's
'80 Pick-up, '80 cab with '02 double cab chassis, 3.4L V6, 5 speed swap, IFS, airbag, air, power doorlocks, etc.
http://winchstoyotaparts.yolasite.com/
Winch is offline
post #3 of 9 (permalink) Old 12-05-2009, 12:56 PM Thread Starter
No it happens with the ac off. I also recently found if I just hold the idle up to about 2k for 30 seconds it will usually fix itself. It doesn't happen all the time but atleast 1 out of 5 times I am starting with the engine warm
post #4 of 9 (permalink) Old 12-06-2009, 06:52 PM
Have you tried cleaning the throttle body yet? Sounds like the IAC might be getting a little gummed up or a passage way.
tacoma2k is offline
post #5 of 9 (permalink) Old 12-06-2009, 11:46 PM
Winner! It sounds like your IAC (idle air control) valve is getting stuck. Time to clean the throttle body and the IAC thoroughly.
post #6 of 9 (permalink) Old 01-03-2010, 05:13 PM
Ritchie's Avatar
OK.... it appears as if I am having the similar issues with my truck.
Having an automatic trans is a bit different to diagnose in that my lifting of the throttle pedal between shifts doesn't do a thing, just stays where the rpm's were until it shifts.
My problem is the constant changing of the rpm's at idle. A quick stab of the pedal will let it come to the actual set idle, but if I don't do that, it will stay over 1000 rpm's.
Decelerating is becoming a problem too.
Some of you mentioned cleaning the IAC & throttle body.... I just ran a bottle of Lucas fuel injector cleaner through my fuel system... wonder if it could be that?
Any thoughts guys?
LaytBra's
'03 Reg Cab Pre-runner step-side. 3 link, Diamond axle, F&R ARB's w/ 5.29 Yukons, ARB twin compressor, Inchworm 4.7 Lefty, 285/75/16 General Grabber A/T2's, Warn M8000S, Shrockworks front bumper, custom rear bumper, custom sliders that hold air.
Ritchie is offline
post #7 of 9 (permalink) Old 01-03-2010, 05:53 PM
MASTICATOR
hossmaster's Avatar
i have this same problem at the moment. I recently cleaned the IAC, but there is still a problem. What is the best method and when is it time to give up the ghost and get a new one?
02 dbl cab 2.5 dirt logics Just another wanna be
"we had us some fun"
"Blue Water Inn, We Got Pyramids!!!"
hossmaster is offline
post #8 of 9 (permalink) Old 01-03-2010, 08:58 PM
I agree I just fixed this symptom in two yotas by cleaning IAC be prepared I needed the gasket on one of them possible tb gasket too
2000 2.7l x-cab 4wd.
mods .........yes
Scootn2nature is offline
post #9 of 9 (permalink) Old 01-04-2010, 05:03 AM
Ritchie's Avatar
What did you clean the parts with and where did you get them?
TanxNra'
Ritchie is offline
Hard Starting Warm Engine? JoelTacoma96 Early Tacoma Tech 6 09-26-2009 09:17 PM
truck wont idle titan34 Performance/Engine/Exhaust 2 07-14-2009 05:53 PM
Possible cause for high idle when warm? dadunc205x Performance/Engine/Exhaust 1 02-05-2009 02:10 AM
toyota wont restart when warm teamrip Early Tacoma Tech 10 05-13-2008 11:38 PM
truck wont idle cold sickyota Performance/Engine/Exhaust 0 01-30-2005 04:55 PM
