Rear Shock Relocation Questions - TTORA Forum
post #1 of 17 (permalink) Old 04-17-2012, 08:43 AM Thread Starter
Lumpskie's Avatar
I did a quick search and couldn't find specs on this.
Right now, I'm running Bilstein 5125s in the rear of my rig (8.5" and 9") but I'd like to have more droop. At the same time, I don't want to limit my up travel, so I'm looking at doing a shock relocation.
To any of you guys that have done it, what length shocks are you using, and how did you fab up the shock mounts? I was thinking about going with 12" travel shocks, are there any issues associated with the extra droop that I should be aware of?
If you guys have any pics of your setup, I'd appreciate that as well.
'96 3.4L, 5Speed, Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Orbit Eye Leafs with 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" lights with Morimoto HIDs, full skids, Inchworm dual case setup - 15 clocking
Build Thread:
http://threeg4runners.freeforums.org...coma-t263.html
Lumpskie is offline
post #2 of 17 (permalink) Old 04-17-2012, 08:56 AM Thread Starter
Lumpskie's Avatar
Looks like I wasn't looking in the right section. I found some stuff in the Fabrication section. That being said, if anyone has an opinion on the right/wrong way to do it, I'd love to hear about their experiences.
Build Thread:
Lumpskie is offline
post #3 of 17 (permalink) Old 04-18-2012, 07:46 AM
Mikeybb's Avatar
Shock tech. I learned a thing or two, might help ya.
http://www.4x4review.com/Features/Te...7/Default.aspx
2000 Ext. Cab 2.7 Taco with retard strength
Mikeybb is offline
post #4 of 17 (permalink) Old 04-18-2012, 11:17 PM Thread Starter
Lumpskie's Avatar
Thanks Mikey. There was some good info in there.
Build Thread:
Lumpskie is offline
post #5 of 17 (permalink) Old 04-20-2012, 02:34 PM
Mikeybb's Avatar
No problem.
Mikeybb is offline
post #6 of 17 (permalink) Old 04-20-2012, 06:27 PM
a big limiter is that longer travel shocks have longer bodies, so to fit them you may need to go through the bed.
post #7 of 17 (permalink) Old 04-20-2012, 06:35 PM Thread Starter
Lumpskie's Avatar
Yeah Ike,
I've been looking at that. I, personally, don't like leaning the shocks too far inboard like I've seen done a number of times. So, I'm looking at slightly increasing the forward and back tilt while raising the mount points as high as possible. The passenger side looks like there is a lot of room, but the driver's side looks a little tight.
Have you seen anyone do that kind of mount on the top while retaining the stock mounts on the bottom? I'm aiming for a 12" shock... Do you think it's possible?
I'm really looking for someone with experiences to share, so feel free to chime in!
Build Thread:
Lumpskie is offline
post #8 of 17 (permalink) Old 11-15-2012, 01:45 PM
Prolly got your shocks figured out a while ago but bilstein offers their 7100 shock in a short body with remote reservoir. These seem to allow for long travel without having to go into the bed.
Edit: Just saw that you did just that!
DopuS is offline
post #9 of 17 (permalink) Old 11-15-2012, 06:40 PM
Jesse at TLT layed is back and attatched them to a new cross member. Don't have a link off hand.
Edit: old thread duh x2
2000 Tacoma
3.4 TRD
ICON C/O
Marlin Clutch
Wainiha is offline
post #10 of 17 (permalink) Old 11-15-2012, 10:37 PM Thread Starter
Lumpskie's Avatar
Edit: Just saw that your did just that!
Yes sir! On my truck they worked out perfect. Under full compression they have about a half inch left and they reach almost full extension as well!
Build Thread:
Lumpskie is offline
post #11 of 17 (permalink) Old 11-15-2012, 11:33 PM
How did you mount those 7100s? What lift on the Alcans?
2000 Tacoma
3.4 TRD
ICON C/O
Marlin Clutch
Wainiha is offline
post #12 of 17 (permalink) Old 11-16-2012, 02:04 AM
SafetyDang's Avatar
Send a message via AIM to SafetyDang
http://www.polyperformance.com/shop/...roductid=30194
This should help.
SafetyDang is offline
post #13 of 17 (permalink) Old 11-16-2012, 04:28 PM Thread Starter
Lumpskie's Avatar
I just put the the shocks into the stock locations. I've flexed the truck out and they don't run out of travel in either direction. I've got a custom set of Alcans (8 pack) that are sprung for stock +200lbs of load.
Here are some pictures:
Pictures - 12" 7100 shortbodies in stock locations
Build Thread:
Lumpskie is offline
post #14 of 17 (permalink) Old 11-16-2012, 04:40 PM Thread Starter
Lumpskie's Avatar
Also, like Hytenor mentions in the other thread, extended bump stops are a good safety against over compressing your shocks.
Here are a couple more pics to try to show the range of travel. Keep in mind these are the shorter '96 taco rear leaf springs. (a bit less travel than newer setups)
Build Thread:
Lumpskie is offline
post #15 of 17 (permalink) Old 11-17-2012, 01:19 AM
truck ~n~ tow
TacoDell's Avatar
what 5125 ? mine are 8." and 8.5"
thought 10" short body shocks could be fitted ?
still may need to heighten the bumps for those.
shock brackets must be welded directly to the axle tubing.
wanting more travel then those could offer ?!
would require a cross member, shocks layed / \ or rearward,
lowers welded to the axle tubes
^ that or thru the bed
Truck...
Trailer...
Truck build --- Trailer build
TacoDell is offline
post #16 of 17 (permalink) Old 11-17-2012, 12:53 PM
SADGOAT's Avatar
Yeah Ike,
IMO, if you are relocating shock mounts you should strongly consider a u bolt flip as well. The hardest part of flipping ubolts is the shock mounts. Don't know what type of wheeling you do, but the stock shock mount under the axle deal can easily get fubr.
2002 3.4 5spd X-cab
TTORA SPECIAL: Icon COs & Deaver-9s with 5100s; 255/85/16 Bighorns on rock-ringed steelies; 5.29s; locked F(ARB)&R(e-locker); all the armor; winch for good measure
SADGOAT is offline
post #17 of 17 (permalink) Old 11-18-2012, 06:09 PM Thread Starter
Lumpskie's Avatar
Hey Dell:
That's an old quote. I'm running 12" 7100 short bodies in the stock locations. You can see my clearance in the link I left above. I've run them for a while now with no problems both here in Colorado and out in Moab. Good Stuff.
Build Thread:
Lumpskie is offline
Rear shock relocation zanyzonies General Discussions 2 10-08-2007 09:00 AM
Rear Shock relocation climbdarox Fabrication/Tools 13 01-17-2006 09:38 PM
Rear shock relocation on an '05 mudferret Suspension 7 05-05-2005 04:30 PM
rear shock relocation 00LTTACO Suspension 1 04-06-2005 11:38 PM
rear shock relocation pics 2LONGTOY89 Suspension 3 03-09-2005 02:20 AM
