Possible 4x4 Swap - TTORA Forum
post #1 of 8 (permalink) Old 01-10-2017, 12:04 PM Thread Starter
Possible 4x4 Swap
I have a 2004 4 cyl, 5 speed Tacoma std cab. It is not a 4runner. Can I swap to 4x4 as I have seen in other threads in this forum?
Your help is appreciated!
berniestaco is offline
post #2 of 8 (permalink) Old 01-10-2017, 04:13 PM
Scuba's Avatar
You stated it's a Regular cab Tacoma. Then you said it is not a 4Runner.
I'm confused. Do you mean "it is not a Prerunner"? How man lug nuts hold your wheel on? 5 or 6? If 5, the answer is no, you cannot do the 4x4 swap. If 6, then yes.
Scuba is offline
post #3 of 8 (permalink) Old 01-11-2017, 06:01 AM Thread Starter
Sorry for the confusion. It is not a Prerunner and it is a 5 lug wheel so it sounds as if I can't do the swap. I am assuming it must be a Prerunner in order to be able to make the conversion. Are the frames etc. different?
Thanks again!
post #4 of 8 (permalink) Old 01-11-2017, 10:25 AM
The suspension set-up between the 5lug 2WD models and 4x4/Prerunners are completely different. If you want 4WD on your 5lug, the best option would be a full solid axle swap.
post #5 of 8 (permalink) Old 01-11-2017, 10:35 AM Thread Starter
I can do the work. What would I need for a solid axle swap? And thanks for helping a "new to the Tacoma world"!
post #6 of 8 (permalink) Old 01-11-2017, 07:32 PM
Scuba's Avatar
Lots of stuff. There is a SAS section here. You can do some reading in my SAS thread by clicking the link in my sig line.
Scuba is offline
post #7 of 8 (permalink) Old 01-12-2017, 05:25 AM Thread Starter
Thanks, Scuba!
post #8 of 8 (permalink) Old 01-12-2017, 10:52 AM
Keep in mind that the front axle is only one part of the picture. You will also need a new transmission, transfer case, transmission crossmember, ECU/wiring harness (to avoid CEL), exhaust mods (depending on trans/transfer combo) and of course rear suspension mods. You would be embarking on a lengthy and expensive project.
4x4 Swap Questions Cturner PreRunner Tech 4 10-22-2013 09:13 AM
TRADE 1990 4X4 TRUCK FOR TACOMA 4x4 SWAP PARTS NorCalMax Vehicles/Trailers 13 03-21-2012 04:24 PM
axle swap on a 86 e-cab 4x4 mudslut Newbie Tech 4 11-19-2009 07:06 PM
Prerunner to 4x4 swap parts EVERYTHING Qckslvrpst Parts/Electronics/Wheels/Tires 9 11-18-2009 02:02 PM
Cheap 3.4 swap 4x4 minerdude1 Parts/Electronics/Wheels/Tires 4 10-19-2009 08:22 AM
