3.4 JDM Engine Import Advice - TTORA Forum
post #1 of 2 (permalink) Old 01-10-2017, 02:19 PM Thread Starter
mackay's Avatar
Hi folks.
I am planning on replacing my 2000 3.4 with a newer 3.4 motor from Japan. Current block has 245k and doesnt have much power left, lots of valve noise and is leaking head gasket ect.
I am seeing these imported motors from Japan for around 800-1100 on ebay and other sites. Im planning on swapping the motor this spring, doing the clutch and throw out bearing and having the frame professionally blasted and painted while the internals are out.
I have some questions before I go ahead and pull the trigger.
Some of these motors have the wiring harness cut, some do not, is this a thing to consider when purchasing?
Anyone have any particular experience with a JDM importer that was good?
Some people have told me to rebuild it if the crank is good however I feel that by the time I have the valves professionally done Im already around 1100. Not to mentioned that the Japanese blocks are complete with alternator, pump, ect.
Looking for general advice and tips before i get started, thanks!
mackay is offline
post #2 of 2 (permalink) Old 01-11-2017, 11:44 AM
Doesn't matter on the harness. You have to swap that and lots of other parts over from your existing engine to the donor engine.
ShowStop is online now
Engine Problems.... Need some advice Kesepton Pickup/Early 4Runner Tech 12 06-08-2015 04:32 AM
Water in Jeep Engine - Any advice? Offroadtaco3 Off Topic 17 03-20-2010 11:10 AM
Engine Swap/Import Question RickerRicker19 Pickup/Early 4Runner Tech 20 12-14-2008 12:59 AM
Need engine and Suspension advice McNateMc Early Tacoma Tech 5 01-08-2008 02:30 PM
JDM Import motor 3.4 kylej Performance/Engine/Exhaust 15 02-12-2007 06:14 PM
