'01 2.7 Manual Trans Shifter Bushing Cause Popping Out of Gear? - TTORA Forum
 1Likes
  • 1 Post By ShowStop
post #1 of 16 (permalink) Old 03-20-2017, 12:15 PM Thread Starter
I read something on another forum about the shifter bushing on manual trans Tacos getting worn out and causing it to pop out of gear. Over the past day or two I've noticed my truck seeming to shift differently into 3rd and 5th gear... almost like the gear pattern is slightly off. 3rd gear goes in but feels like it hits the blocker at a different spot than it used to and the same with 5th. It also popped out of 5th gear on me once and today I've had a really hard time getting it fully into 3rd gear at all. This happened pretty much all of a sudden.
The tranny pretty much shifts like butter aside from that.
Does this sound like the symptoms of a worn lower shift bushing?
partyman666 is online now
post #2 of 16 (permalink) Old 03-20-2017, 04:23 PM
It's a cheap and easy place to start.
Sent from my iPad using Tapatalk
Sparky of SoCal is offline
post #3 of 16 (permalink) Old 03-20-2017, 04:42 PM Thread Starter
Yeah... I just ordered the 2 parts from my local dealer today for about $15. Parts should be in by tomorrow, but I was curious if this is likely to fix the issue or if there is something else I should be considering.
post #4 of 16 (permalink) Old 03-20-2017, 05:20 PM
Sounds like the bushing. Should have gone with the Marlin kit. The dealer bushing will eventually wear out again.
ShowStop is online now
post #5 of 16 (permalink) Old 03-20-2017, 05:59 PM Thread Starter
I looked into that but I don't have time to wait for it to come in since my Taco is my DD right now and we have snow on the ground.. can't safely drive my other vehicles in these conditions due to them all having summer tires/RWD or only having 2 wheels . The Toyota parts will be available by 11 AM tomorrow at my local dealer which is 4 miles from home, so I can just limp my truck over there, pick up the parts and install it immediately, hopefully with a return to fully normal functionality shortly thereafter. I just don't want to risk damaging my tranny as a result of this, since it was grinding a bit this morning too when trying to hit 3rd.
Thanks for the helpful input as always!
On a side note, Marlin shipping costs are absurd. $14 to ship 2 small pieces that are the combined size of a dime and nickel? Most vendors at least give you the option to USPS that for like $1 or less.
post #6 of 16 (permalink) Old 03-21-2017, 02:11 PM Thread Starter
Ugh... I have been trying to get the spring loaded cap that holds the shifter to the tranny off for hours. I can't get it to turn counterclockwise enough while pressing down. I'm in neutral while trying since that seems easiest.
Any tips? My hands are killing. I've been using a rag to help get traction but it's a no go.
post #7 of 16 (permalink) Old 03-21-2017, 04:19 PM
I have never done it on that trans before but a few others I have gotten away with using a set of needle nose slipped into the slot,push down and turn.
post #8 of 16 (permalink) Old 03-21-2017, 06:12 PM
Rag usually works the best. I've also used flat pliers to press and turn the cap. If it still fights, try spraying a little WD-40 or penetrating lube around the rim. That helps break loose the dirt that usually jams down in there. Don't use too much spray as it will drip into the transmission and you want to avoid that.
post #9 of 16 (permalink) Old 03-21-2017, 08:02 PM Thread Starter
I did hit it with a bit of Seafoam Deep Creep earlier this morning and targeted it towards where the cogs go into the retainers on the ring (just enough to get in there, while being cognizant of whatever was in that area would drip into the tranny), but that didn't help much. I also heated it up a bit with my heat gun. I had to actually hammer down on it with wooden dowels to get it to even move down at all because it was completely stuck. I can get it to compress down about 1 mm now and I can sorta feel it wanting to turn but it won't go over the lip on the locking piece cut into the sides and that's with using almost my full body weight to push down on it.
I'll try again tomorrow with some different shaped pliers and maybe see if I can get another person to try to spin it while I'm pushing down on it with some screwdrivers. The pliers I tried today wouldn't work due to their shape. I bought a new cap too so I can replace that if I damage the one that's on there in the process of removing it. I may end up having to order the lower seat from Marlin if it's all broken apart, because my Toyota dealer said they can't order that part by itself. Sounds like BS to me though because I saw them for sale at other dealers online. What he ordered for me was actually not that part that I told him to get, so I didn't buy it and just left with the cap and new socket.
post #10 of 16 (permalink) Old 03-22-2017, 02:04 AM
You can also unbolt the entire shifter base from the transmission. Should be 6 bolts. Then work on it off vehicle.
Sparky of SoCal likes this.
post #11 of 16 (permalink) Old 03-22-2017, 03:27 AM Thread Starter
Thanks. I was considering trying that too but decided not to until I looked into whether or not this would mess anything up or if I would have to replace a gasket in the process.
I did a little research tonight and saw a guy with a similar type of shift lever cap on another Toyota who used a 19 mm open ended wrench to reach around the shift lever, push down and turn the cap. I think I'm going to try that the next time we get a day in the 40's or higher.
post #12 of 16 (permalink) Old Yesterday, 03:18 PM Thread Starter
I got that shifter cap/ring off today. I ended up shining a bright LED flashlight down into the area where the spring is so that I could see the pins and determine why things weren't moving and allowing the cap to come off. There were big chunks of greenish plastic from the destroyed OEM bushing all jammed into everything in there. I was able to use tweezers and Q-tips to remove everything I could see and this helped a bit. I then tried pushing down on it while looking at the pins to see if it was going down all the way, and it wasn't. I took a big flathead screwdriver and pressed down as hard as I could on one side of the ring and then while doing that hit the but of the screwdriver pretty hard a few times with the hammer until it went down further. I did this on both sides and it freed up the ring so that I could push it down further and spin it off. The entire bushing was completely gone and ground up into chunks that were getting in the way and preventing me from pushing down on the cap/ring all the way.
I cleaned everything out and am now waiting for the new seat to arrive from Marlin Crawler.
I also have a new cap/ring that I bought from Toyota in case I needed it. My original one is a little banged up from removing it, but I'm not sure how exactly to get the neck of the shift lever off of the bottom piece of it so I can replace it. Any ideas? I tried twisting it and it didn't budge. I don't want to break it in the process of trying to replace that cap, since I technically don't really have to replace it but figured I would since I already have the part anyways.
post #13 of 16 (permalink) Old Yesterday, 04:28 PM
I don't know how to get that piece off either.
post #14 of 16 (permalink) Old Yesterday, 05:10 PM Thread Starter
It looks like there is a dab of dried glue coming out of where those two pieces connect. Hopefully the whole assembly isn't permanently glued together or threadlocked with some sort of non-removable adhesive. I'm hesitant to hit it with too much heat or wrench on it to hard and end up in a deeper predicament.
post #15 of 16 (permalink) Old Yesterday, 06:48 PM
Not sure if the transmission shifter is different then the transfer, but it sounds like they are pressed together by some rubber bushing.
https://www.yotatech.com/f197/kawazx...l#post52105444
post #16 of 16 (permalink) Old Yesterday, 07:09 PM Thread Starter
Aw christ.... It's ironic that the asshats at the dealer even sell those parts individually when you can't decouple them from the whole assembly without re-engineering the shaft.... yet they tell me that they don't sell the easily replaceable bushing seat which seems to inevitable fail on most trucks at some point.
Sell parts you can't use... don't sell parts you need and can use.
manual trans pops out of 5th gear???? 4wheeltaco Early Tacoma Tech 14 07-18-2016 07:17 PM
manual trans lost 3rd & 4th gear dalethemail Early Tacoma Tech 0 06-05-2014 12:54 PM
Shifter seat bushing mmichel Early Tacoma Tech 8 05-28-2009 12:45 PM
Topping off manual trans via shifter SADGOAT Newbie Tech 9 08-22-2006 12:02 PM
Shifter seat and bushing Bro Hymn Early Tacoma Tech 3 01-21-2006 08:02 AM
