Cat to exhaust flange broke - TTORA Forum
post #1 of 5 (permalink) Old 04-17-2017, 05:21 AM Thread Starter
I consider myself an advanced DIYer, yet I'm stuck here in deciding this; hit a massive pothole last night and all the sudden, sounds like I'm on the loudest Harley ever. Check under the cab; my tail exhaust has been separated from the cat flange both sides are essentially disintegrated and this was only a matter of time, though I likely would have heard the leaking at some point.
TLDL; what do you think is a good, quick fix? Cut off old flanges and weld on new ones or those split clamp exhaust flange things? I don't go off roading so it doesn't matter how pretty it is. What about the best gasket? It looks like a graphite one is the most recommended.
Beejis60 is online now
post #2 of 5 (permalink) Old 04-17-2017, 10:26 AM
Can you post a picture?
ShowStop is online now
post #3 of 5 (permalink) Old 04-20-2017, 11:24 AM
SafetyDang's Avatar
Send a message via AIM to SafetyDang
Can you weld? If so cut and sleeve. A shop charged me 20 bucks for this. Then I later added a flange for $40 installed.
SafetyDang is offline
post #4 of 5 (permalink) Old 04-20-2017, 03:41 PM
I've had one of those 2-piece replacement flange kits on my Tacoma for 4 years now. I've even taken it off and put it back on with a new rear muffler and it's holding up great. They are only like $20 MSRP and pretty much a solid and permanent fix.
I think this is the exact one I used:
http://shop.advanceautoparts.com/p/w...nge+repair+kit
After coupon codes it was like $14 for me.
partyman666 is offline
post #5 of 5 (permalink) Old 04-21-2017, 08:00 AM Thread Starter
I can but I don't own a welder anymore. Fortunately the shop by my house did it all for $50 (cut off old flanges, weld on new ones and new gasket). Works for me.
This was what I was considering and just worded it poorly in my OP.
Weld on exhaust flange alexh Early Tacoma Tech 2 10-17-2015 05:25 PM
Exhaust Flange On 2.7 Converter Pipe partyman66 Newbie Tech 0 09-22-2014 11:08 PM
3 bolt exhaust flange bwill808 Fabrication/Tools 4 01-12-2012 01:29 PM
