2001 Tire rub? - TTORA Forum
post #1 of 9 (permalink) Old 04-05-2005, 08:40 PM Thread Starter
2001 Tire rub?
I'm looking at purchasing an ext cab Tacoma. I've found a TRD that has been in a front end collision. It has about 31" BFG AT's on it but there is some significant tire rub on the pass side when turning right. I know there are some slight frame rub issues when running this size tire but this is catching on the back portion of the wheel well not just some rub on the fram. Is this something that's normal? Or is the alignment out of wack? The guy is telling me he just had it aligned but with this it seems like the alignment might be jacked. Can't see any new parts as far as the upper and lower arms or the CV shaft is concerned. Is there anything else I should be aware of with the 01 Taco's?
onetuff76 is offline
post #2 of 9 (permalink) Old 04-05-2005, 09:18 PM
Not really here...
synovus's Avatar
Are they 31's or "about" 31's? If they're 31's, they shouldn't rub unless the front suspension has sagged A LOT. Given that it's an '01, I wouldn't think the coils could've sagged enough to cause rubbing, but who knows. More than likely the alignment needs to be adjusted forward. Are they stock rims and tires, or aftermarket? If the rims are aftermarket, they may be too wide, or of improper backspacing. If the tires are 31's, are they 31x10.5's or 31x12.5's? Wider would rub easier.
You've checked to make sure the frame isn't bent?
synovus is offline
post #3 of 9 (permalink) Old 04-05-2005, 11:34 PM Thread Starter
Frame doesn't look bent. Rims are stock, tires I think are 31 AT's. Drivers side tire seems fine. There are some rub marks from the tires on both sides of the frame. Could bent control arms caust this?
post #4 of 9 (permalink) Old 04-06-2005, 10:37 PM Thread Starter
Back To Top
post #5 of 9 (permalink) Old 04-06-2005, 11:02 PM
Matt's Avatar
Send a message via MSN to Matt
I own a 01 TRD xtracab. The TRD version came with 265/70R16s which are 31" tires or so. It shouldn't be rubbing. Are they wide tires? Front end collision causing this?
Matt
Matt is offline
post #6 of 9 (permalink) Old 04-06-2005, 11:29 PM
x0ffr0adtac0x's Avatar
yeah i would say that the collision caused some sort of shift in the suspension components. do you know what side received the most impact?
x0ffr0adtac0x is offline
post #7 of 9 (permalink) Old 04-06-2005, 11:55 PM Thread Starter
I don't know which side was hit worse, but there was a front end impact. The drivers side seems fine, so wouldn't that rule out that the frame is bad and point to the control arms on the pass side being bad or maybe the subframe assembly being tweekd a little?
post #8 of 9 (permalink) Old 04-06-2005, 11:58 PM
DesertTRD's Avatar
Send a message via AIM to DesertTRD
i would not touch it.
- for 10,000 years, man has been hitting things with hammers to make them work....dont mess with a working formula
Book of the Piece Chapter 3, Verse 10
meh... it's yer junk... so wgasa. LoL -- TacoDell
DesertTRD is offline
post #9 of 9 (permalink) Old 04-07-2005, 12:32 AM
maybe you should look into a different truck, looks like this truck will only give you problems, and be unsafe
