Cooler Tranny temps (Even for Hayden coolers!) - TTORA Forum
post #1 of 4 (permalink) Old 08-15-2005, 07:48 PM Thread Starter
NorCal Chapter Pres
NorcalPR's Avatar
Cooler Tranny temps (For Hayden coolers and other vehicles)
Hey guys. Well my brother has a Duramax, and for some reason, GM came up with stupid engineering on the Tranny coolers. The Radiator is behind the intercooler, than the AC condenser, (each are aobout 1/2" apart) and then the Tranny cooler is aobut 2-3" from the rest!
So on the freeway, his tranny temps are cool. Around the street, even jsut putting around, the temps go up a little over 200, with no wieght!
So I thought his idea would help you guys out. What he did is took a sheet of aluminum and made a box that goes around the tranny cooler, and stays about 1/8" away form the a/c condenser. I'll explain the reasoning in a sec. He then used aluminum tape to seal it off and taped a 1/4" lip to the front of the tranny cooler all the way around.
Air wants to have the least resistance. Now, lets say on idle, the fan is pulling in air, right? Well, if you were air, (and you want to have the least resistance) would you rather go around the tranny cooler, or through it? Of course you'd want to go around it, it has the least resistance!
So putting the box around the tranny cooler forces the fan to suck the air through the tranny cooler. He went from tranny temps of about 202 down to about 170 degrees. I couldn't believe it neither, but it really does work.
Just though I'd pass it along to you guys. The thought behind it makes a lot of sense, and it does work! Maybe with the Hayden cooler and the box around it, we could see even cooler temperatures around the city. Around the highway this does not help at all, because the air is directly hitting the tranny cooler. This will only help in city driving and idle. (the Fan sucks the air through the radiator, and through the tranny cooler, not around it)
It didn't hurt his coolant temps neither. The box doesn't get any wider than the tranny cooler.
-Phill
W6FTW
NorcalPR is offline
post #2 of 4 (permalink) Old 08-15-2005, 09:40 PM
J-Man's Avatar
-Phill
sounds like a dam good idea. I was thinking of something like that myself cause the dam tranny gets hot, like 210-230 when loaded down, hell even not loaded down but up continous inclines. Do you have any snap shots of what it looks like? Id like to see so i can fab up something like that myself. Thanks for the heads up!
2001 Tacoma TRD, & 2000, 1999, 1997 Toyota 4Runners -all are 5spd 4x4 v6 with saw's / ome suspension.
J-Man is offline
post #3 of 4 (permalink) Old 08-15-2005, 10:04 PM Thread Starter
NorCal Chapter Pres
NorcalPR's Avatar
I'll do a sketch on paint.Mayke I'll take a picture of my cooler and modify it so you guys can see what I mean.
I'm actually going to build mine saturday. So I'll definately have pictures of it up by then (but I will not have results of it actually working, I have no tranny temp guage. But if it works on a d-max, it will def work with our tacos.)
W6FTW
NorcalPR is offline
post #4 of 4 (permalink) Old 08-17-2005, 11:05 PM Thread Starter
NorCal Chapter Pres
NorcalPR's Avatar
Here's some (very crappy) shots of what to do. What's in red is aluminum tape. Yellow is metal you add. I'd not saying ot add it in that spot, but will give you a idea of what to do for any vehicle.
The second picture is what you would do if you had a Hayden tranny cooler. Gives you another idea of what to do. Just pretend the wood is the a/c condenser. In the Dmax, you're basically using the metal to create a bridge between the cooler and the ac condenser, then using tape to seal it off.
http://photobucket.com/albums/y225/N...annycoolermod/
W6FTW
NorcalPR is offline
TRD tranny cooler MYTTAWD Wanted 11 10-28-2005 06:25 AM
Trasmission Oil Temp Gauge Install Interex PreRunner Tech 42 08-04-2005 11:12 AM
How does the TRD / Hayden Tranny Cooler mount? CMB1998 Early Tacoma Tech 3 05-04-2005 11:47 AM
Tranny Cooler w. Fan joeylead Early Tacoma Tech 19 02-01-2005 05:19 PM
auto tranny cooler purity Early Tacoma Tech 2 01-11-2005 07:23 AM
