Deckplate Mod : Implemented - TTORA Forum
post #1 of 18 (permalink) Old 09-02-2005, 03:32 PM Thread Starter
if it sparkles & pleases
da'Burd's Avatar
Send a message via MSN to da'Burd
Been a little over 2 weeks now and the deckplate mod totally rocks!!! Thanks TTORA!!!
Increased my MPG by at least 1 solid extra MPG. And gave truckee a nice sound too. No check engine light thanks to sensor safe silicon.
Only let the silicon dry for an hour as reccomended on the packaging. Planned on letting it sit overnight, but the surf shop called and my new board was ready.
All in all - Love the mod. Noticed a little extra HP, as I was spinning out a little in take-offs without even trying.
9/26/2005 Update - Amsoil air filter has been installed, and over the past few weeks and a few more tanks of gas....I'll have to say that there is no MPG gain. Definetly have better throttle response, but can't say that equates to more HP though. Thanks Again TTORA!!!
1980 Std. Cab, 20R 4x4
da'Burd is offline
post #2 of 18 (permalink) Old 09-02-2005, 04:07 PM
Drive fast Take Chances
99ARTaco's Avatar
Send a message via MSN to 99ARTaco
Right on dude even if you can save at the pump these days it will help. Let me know how you like it after you install that Amsoil filter? Don't end up like this surfing that new board.
99ARTaco is offline
post #3 of 18 (permalink) Old 09-02-2005, 04:22 PM
themariachi's Avatar
glad you like it...
themariachi is offline
post #4 of 18 (permalink) Old 09-04-2005, 10:14 AM
NorCal Chapter Pres
NorcalPR's Avatar
Cool. I didn't even use silicone on mine. It's such a tight fit I figured that it water is egtting through the deplate, water is getting through the stock location.
:thumbsup:
W6FTW
NorcalPR is offline
post #5 of 18 (permalink) Old 09-04-2005, 11:03 AM
River Rat
hawaiianbro's Avatar
:thumbsup:
Either that or getting through the hole that you duck taped.
hawaiianbro is offline
post #6 of 18 (permalink) Old 09-04-2005, 12:00 PM
:thumbsup:
if I were you, I would spend the extra $3 and get the sensor safe just to be safe...IMO
post #7 of 18 (permalink) Old 09-05-2005, 11:58 AM
sploosh's Avatar
I see mostly everyone has a 4" deckplate. I read on the original thread you could go up to a 5". Is there a reason everyone's staying at 4"?
2001 Tacoma, slightly modified
sploosh is offline
post #8 of 18 (permalink) Old 09-05-2005, 12:00 PM
sploosh's Avatar
I plan on doing the mod next week and was just wondering if there was some issue with the 5" plates, since that's the one I had planned on getting.
sploosh is offline
post #9 of 18 (permalink) Old 09-05-2005, 03:43 PM
THAT guy.
SAR_Squid79's Avatar
When you do the mod you want to stay between the little hump in the airbox on the left side, and the windshield washer tank filler neck on the right side. The 5" deckplate makes that a little difficult.
~Jamie
2000 Tacoma TRD 4WD PreRunner
Supercharged. Locked. Armored.
Mountain: She can crawl it.
Ass: She can haul it.
"Roads? Where we're going we don't need . . . roads."
~Dr. Emmett L. Brown
My Rig My Trailer 4xInnovations
SAR_Squid79 is offline
post #10 of 18 (permalink) Old 09-05-2005, 06:35 PM
sploosh's Avatar
Alright man, thanks for the info. 4" Beckson deckplate it is.
sploosh is offline
post #11 of 18 (permalink) Old 09-05-2005, 09:56 PM
Coastie
boylem002's Avatar
Send a message via Yahoo to boylem002
I put a 6" in without any issues on the 3.4L It fits perfectly when centered on the front of the box. The top of the deckplate flange sticks above the top of the airbox by about 1/16th of an inch, but not really noticeable. I can install and remove the cover easily as well. It allowed me to skip the whole elbow removal mod, as it wouldn't really offer much more than a 6 inch hole allows.
boylem002 is offline
post #12 of 18 (permalink) Old 09-07-2005, 12:37 PM
Trunks Only's Avatar
Yea, the 6" deckplate was no problem, a little unnerving to cut such a large hole in the airbox, but it worked out great. I removed the elbow at the same time so I can't speak of an added bonus there, however, the sound is great as is the throttle response it seemed to help out with. last piece is new gears....any cheap tricks for those?
Na Kamali'i o Kaua'i
Trunks Only is offline
post #13 of 18 (permalink) Old 09-07-2005, 04:21 PM
Coastie
boylem002's Avatar
junkyard find might be cheaper, but may prove less reliable. Pretty much looks like somewhere in the neighborhood of 600 bucks for re-gearing. It's almost worth it to just save a bit more and go with an ARB airlocker (assuming you don't have the e-locker)
post #14 of 18 (permalink) Old 09-09-2005, 08:33 PM
NorCal Chapter Pres
NorcalPR's Avatar
Better than nothing!!!
I've had no problems with the silicone free deckplate.
W6FTW
NorcalPR is offline
post #15 of 18 (permalink) Old 09-09-2005, 08:40 PM
Coastie
boylem002's Avatar
yeah, i skipped the silicone. I figure if I'm in water that high, I should've had a snorkel anyway or I've got bigger problems going on in the exhaust department.
post #16 of 18 (permalink) Old 09-09-2005, 09:34 PM
gary briggs's Avatar
Send a message via AIM to gary briggs Send a message via Yahoo to gary briggs
im not entirely convinced i got any more milage or power from the deckplate mod, just better sound
gary briggs is offline
post #17 of 18 (permalink) Old 09-10-2005, 11:11 AM
hk'dontoys's Avatar
see if you can borrow a 4" hole saw. makes clean cut in seconds and the honeycomb inside airbox doesn't affect the saw at all like some have said about the dremel. i put a small piece of nylon windowscreen over the deckplate before silicone and stainless screws. i also bolted a 1/8" vinyl coated cable with terminal ends crimped and shrink wrapped to the center cover and airbox so i can't loose the cover if i tried. bought stainless from boat store and cable from lowes for less than a dollar for around 12". just my upgrade tip if you are interested.
2001 tacoma d/c, with never enough extras!
hk'dontoys is offline
post #18 of 18 (permalink) Old 09-10-2005, 12:08 PM
1noobie's Avatar
Had no problem at all with my 5" deckplate.
1noobie is offline
AEM cold air vs. Deckplate mod?? random hero Performance/Engine/Exhaust 25 05-29-2007 12:10 AM
Deckplate mod with no deckplate? VAshowTaco Cheap Tricks 18 09-23-2005 12:07 PM
Check Engine- Deckplate Mod wetsuitwookie Cheap Tricks 8 07-08-2005 01:41 PM
Deckplate mod Tacomapwr Performance/Engine/Exhaust 11 05-24-2005 05:04 PM
Deckplate Mod missing from "cheap tricks" twblanset Early Tacoma Tech 3 01-25-2005 10:00 PM
