QUESTION: how do i remove diesel from gas can? - TTORA Forum
post #1 of 12 (permalink) Old 10-07-2005, 11:25 AM Thread Starter
hammerdown's Avatar
Send a message via AIM to hammerdown
Question QUESTION: how do i remove diesel from gas can?
i found several german military fuel cans at a surplus store for cheap, in good condition, but they were used for diesel previously. there is no diesel left in them, but a slight residual on the walls of the can and bottom.
question #1: is it neccissary to clean the can before adding gasoline?
question #2: if so, what do i use???
should i try to let them dry out? blow compressed air inside? use rags? is this a lost cause?
help please
hammer down,
weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee!!! :
Don't think too hard, just follow the damned instructions.
ca4wd#9730
hammerdown is offline
post #2 of 12 (permalink) Old 10-07-2005, 12:06 PM
J-Man's Avatar
dood, that is the greatest avatar ive seen in a while. hmmmmmmmm. Since diesel is a bi-product of gas, i'm pretty sure youll be okay - just as long as there isnt any liquid diesel left inside. Otherwise, spray some citrus cleaner or other de-greaser in there, fillla litte water, shake and rinse well and let dry upside down. All will be good.
2001 Tacoma TRD, & 2000, 1999, 1997 Toyota 4Runners -all are 5spd 4x4 v6 with saw's / ome suspension.
J-Man is offline
post #3 of 12 (permalink) Old 10-07-2005, 12:17 PM Thread Starter
hammerdown's Avatar
thanks man... i think shes the chick from FX's dvd on tv. can't remember her name... go figure.
the only prob with the degreaser method, is that the fuel can has a chamber divider in the middle, and i dont know how dry i'll be able to get it after adding water. maybe i can add some of that dry-gas stuff they have at walmart for snow areas. hmmmmmmmm...
hammer down,
ca4wd#9730
post #4 of 12 (permalink) Old 10-07-2005, 12:19 PM
J-Man's Avatar
if your that worried, then just go buy some quick dry electronics cleaner and spray that up in there. IT'll automatically dry everything inside.
J-Man is offline
post #5 of 12 (permalink) Old 10-07-2005, 12:28 PM Thread Starter
hammerdown's Avatar
good call. i forgot about that stuff.
hammer down,
ca4wd#9730
post #6 of 12 (permalink) Old 10-07-2005, 12:46 PM
help please
When I worked at a gas station, we used gasoline to clean diesel contaimination. Works pretty good. Just put a little gas in the cans, swish it around, then pour it out. Cans should be ready for gas. Use the bad gas for a lawn mower or something.
ShowStop is online now
post #7 of 12 (permalink) Old 10-07-2005, 01:40 PM
Drive fast Take Chances
99ARTaco's Avatar
Send a message via MSN to 99ARTaco
I second the pouring of a little gas in the can and swishing it around a bit. It should clean that gunk right out of there.
Carpe Diem
99artaco@tacomaterritory.com
1999 TRD Extra Cab Tacoma, V6, 5spd. Grey wire mod, deck plate mod, welded on sliders, and then who knows what will be next Maybe one day a SAC??
99ARTaco is offline
post #8 of 12 (permalink) Old 10-07-2005, 02:06 PM
01taco4x4's Avatar
Little bit of deisel wont hurt a gas motor anyways. Just add gas. If all it is is residue then dont worry bout it.
Its all fun and games till someone loses and eye.... Then its just a game, find the eye!!!
01taco4x4 is offline
post #9 of 12 (permalink) Old 10-07-2005, 07:04 PM
DakotaTacoma's Avatar
True that, I reused my dad's diesel cans and they still had a small amount of diesel sloshing around in the bottom. 0 issues. At the time he said it might even lubricate the valves and would be good for the truck.....
A little reside on the side of the can, like you have, will do nothing at all to your engine.
SEARCH and you shall succeed
1996, 2.7 l, 5-speed, Downey 3.5" lift, NWOR Try-y header, K&N FIPK, B F Goodrich 31x10.5 All Terrain KO's, custom rear bumper, Diamond headlights, NWOR cross-drilled rotors Whiteface glo gauges, and Firestone on-board air compressor with a 1 gallon tank.
DakotaTacoma is offline
post #10 of 12 (permalink) Old 10-07-2005, 07:23 PM
AngryAndy's Avatar
Send a message via AIM to AngryAndy Send a message via Yahoo to AngryAndy
help please
Matt-
I agree with others....the diesel should not be a big deal...but I wouild clean them for sure, just cause I am a neat freak like that.
I would use laquer thinner....its highly flammable, and any residual thinner would probably dissapate within a day or so at most...that shit tends to dry up quick...
Electronics cleaner is expen$ive....use brakleen or carb cleaner instead...but I would still use thinner before that....
Off topic....I need your cell#...I was working yesterday on Broadway between 13th and 15th and could have sworn I saw you...i saw quite a few ambulances with full lights on and everytime I was looking to see if you were there!!!! LOL....
"Soupbowl Challenge Winner 2006"
1997 Xtracab SAS Tacoma
1989 SAS 4runner "Project Angry"
2007 FJ Cruiser
AngryAndy is offline
post #11 of 12 (permalink) Old 10-08-2005, 12:09 AM Thread Starter
hammerdown's Avatar
you have mail.
hammer down,
ca4wd#9730
post #12 of 12 (permalink) Old 10-09-2005, 02:45 AM
truck ~n~ tow
TacoDell's Avatar
Just fill 'em up with gas and use 'em. If it's just residue. Don't clean with other hazardous crap that you have to figure out how to dispose of. There's no need for all that hassle. Mix the first batch with a fairly full tank of fuel and it will dilute it to a nearly untraceable level...
Truck...
Trailer...
Truck build --- Trailer build
TacoDell is offline
Gas light broken? Ripcurlsurfin96 Interior/Electrical/Electronics 28 01-22-2007 09:49 AM
Tacoma diesel motors? NisAznMonk Performance/Engine/Exhaust 7 09-26-2005 01:55 PM
Gas Air Compressor Question joeylead Off Topic 0 04-03-2005 08:44 PM
ATTN: remove your torch off of your MAPP GAS!!! supahonkey Early Tacoma Tech 12 04-02-2005 12:41 PM
No Turbo Diesel in America??!! Why not?? Beave Performance/Engine/Exhaust 10 01-11-2005 04:21 PM
