What is a "Cheap Trick"? - TTORA Forum
post #1 of 3 (permalink) Old 10-08-2004, 10:13 AM Thread Starter
Keyser Soze
WATRD's Avatar
Exclamation What is a "Cheap Trick"?
A "cheap trick" is either free or inexpensive when compared to the benefit it gives. The "Fulltime Power Outlet Mod" is certainly a cheap trick, since costs only pennies and provides a big benefit. The "Trailmaster Inversion Mod" is also a cheap trick since it costs nothing and improves the travel and reliability of the Trailmaster 6" lift. The "Deckplate Mod" might also be considered to be a cheap trick, since it costs relatively little, while still giving proven results that rival those of intakes costing hundreds of dollars more. However, the Supercharger would definately NOT be considered to be a cheap trick.
Also, PLEASE try to keep chit-chat to a minimum and on topic in this section so we don't dilute the content. If you want to chat about something that is unrelated to the mod covered by the thread, please start a thread in the "Off Topic" section of the board. Thanks in advance!
-Rob
Slightly Modified 2001 Tacoma - WATRD.COM
Washington|Oregon|Idaho|B.C. and beyond -
Northwest Toys
Tread Lightly! certified Tread Trainer
TTORA Member Number WA-2001-00172
Search 100+ Toyota tech sites, including this one: Toyota Tech Search
WATRD is offline
post #2 of 3 (permalink) Old 10-11-2004, 07:47 AM
MORE COWBELL!!
Morouse's Avatar
Send a message via AIM to Morouse
True Dat! you forgot about the Mudflap mod, now this is something that will be done for you if you are not careful!
"Imagination is more important than Knowledge." -- Albert Einstein
Morouse is offline
post #3 of 3 (permalink) Old 12-13-2004, 11:50 AM
1noobie's Avatar
Cheap Trick rules!!!
Edit: oh sorry bout that just read your whole message...
86' 4runner w/some mods
1noobie is offline
Closed Thread
Gear in this thread - Powered by O'Reilly Auto Parts
Cheap trick for sloppy rack bushings? totalloser Early Tacoma Tech 6 01-21-2010 06:02 PM
Any trick to cheap 31" Mud Terrains? Trevor 3blacktoys Off Topic 1 09-23-2009 04:13 PM
Cheap trick for repainting fender flares? Punani Cheap Tricks 13 10-04-2005 11:53 AM
Cheap Trick for Overdrive??? Brent13 Cheap Tricks 13 04-12-2005 03:29 PM
cheap exhaust trick for Tundra akshunj Tundra Tech 6 01-06-2005 11:18 PM
