Synthetic winch line - TTORA Forum
post #1 of 4 (permalink) Old 02-23-2010, 05:48 PM Thread Starter
Toyotec77's Avatar
has anyone heard of a rope by the name of Blue steel?? does anyone know the quaily of this product?
03' Ext Cab Tacoma 2.7L 5spd OME 882's rear Block 255/85/r16 BFG KM2s on Black Steel ARB 2 IPF Xtreme driving lights Warn M8000 Winch
http://ttora.com/forum/showthread.php?t=151976<<<My Build up Page
http://ttora.com/forum/showthread.php?p=2243135#post2243135<<<My M-100 trailer build
Toyotec77 is offline
post #2 of 4 (permalink) Old 02-23-2010, 06:04 PM
puddlejumper's Avatar
AmSteel Blue maybe? Great stuff. In a nutshell-here is everything you need to know about it. This is from Samson's website: http://www.samsonrope.com/index.cfm?page=37
FAQ's:
Question:
What are AmSteel®-Blue Mooring Lines and what are the benefits of using them?
Answer:
AmSteel®-Blue Mooring Lines are produced with a synthetic fiber called Dyneema® SK-75 fiber, an ultra high molecular weight polyethylene material. The use of this fiber allows us to create a torque-free, 12-strand braided rope which, size-for-size, has comparable strength to wire rope but only 1/7th the weight. An example of an HMPE working line is AmSteel®-Blue which is flexible, easy to handle and floats.
The unique blue color is there for more than just appearance — It is created by a proprietary Samthane coating that enhances rope wear life and snag resistance.
AmSteel®-Blue doesn’t require lubrication because it doesn’t rust or “fishhook.” Its flexibility and extreme light weight will allow for an easier, faster and safer mooring sequence.
Question:
When converting from wire rope mooring lines to AmSteel®-Blue mooring lines, what implementation procedures are required?
Answer:
Chock and fairlead maintenance should be instituted to eliminate rough wearing surfaces, metal burrs and sharp cutting edges that could have been created by the use of wire ropes. In the majority of cases, the conversion can be done as routine maintenance with localized grinding and surface preparation.
Question:
How will AmSteel®-Blue synthetic line wear compared to wire line?
Answer:
The Dyneema® SK-75 fiber used in AmSteel®-Blue is also utilized for bulletproof vests, military helmets and cut-resistant gloves. It is a tough material. It should be noted, though, that all synthetic fiber can be cut, therefore care should be taken to protect the mooring line from sharp and rough surfaces that it could be worked against or over.
As the rope is used, it will develop surface wear on the outer fibers. This individual fiber abrasion will give the line a fuzzy appearance. Due to the normal external wear from use, the line will also gradually begin to lose its original royal blue color.
Question:
Can AmSteel®-Blue mooring lines be repaired aboard ship?
Answer:
Yes! The 12-strand construction of AmSteel®-Blue is one of the easiest ropes to splice or re-splice. AmSteel®-Blue can be spliced with new eyes by following the instructions available on our website or in your owner's manual.
2
Technical Bulletin
Frequently Asked Questions
Question:
How should the AmSteel®-Blue mooring lines be installed on deck winches?
Answer:
The correct installation of this mooring line on deck winches is important to the
long-term service life and performance of the rope.
After the removal of the old wire rope lines, and before installation of the new
AmSteel®-Blue ropes, please inspect the winch drum and flanges for rust, corrosion
or scoring damage created by the wire rope. These areas should be cleaned up so
as not to cut and abrade the new ropes being put on. See our technical bulletin on
retrofitting for detailed information.
On the storage half of the split drum winch, the first two or three layers of AmSteel®-
Blue should be reeled on under some tension to create a solid, smooth base layer.
After these layers, the rope on the storage side can be laid on in layers with some
crossovers. These crossovers should prevent the AmSteel®-Blue from diving
in between the layers and getting stuck during deployment.
On the working half of the split drum winch, it is recommended that only one layer of
rope, (8 wraps) be used — enough rope to grip the drum.
Question:
Is that all there is to it?
Answer:
No, not yet. Follow the path of the AmSteel®-Blue mooring line from the winch drum to
the chock. Make sure it is not rubbing against other metal surfaces. If it is going around
a roller chock, make sure the roller chock rolls. And finally, at the chock, make sure the
inside surface of the chock is not rusted, pitted or scored from wire ropes. Pitted, scored
or gouged surfaces act like knives against any synthetic rope
'08 Tacoma SR5 4WD "Rugged Trail Edition" Double Cab, V6 Towing Pkg, ARB w/Fog Lights and Superwinch EPi9.0s, Homemade Rear Square Tubing High Clearance Bumper, ATC Camper Shell, about a mile of chain and tow straps, Hi-Lift Jack,Basic Hand Tools, Garmin Nuvi 750, Cobra CBw/PA, Weathertech mats.
Whoop, Gig 'Em, Howdy! Fightin' Texas Aggie Class of '00
Originally Posted by John Luttrell View Post
We are not taking any questions, have a seat sir!
puddlejumper is offline
post #3 of 4 (permalink) Old 02-24-2010, 02:22 PM
NorCal Chapter Pres
NorcalPR's Avatar
Why the need for a duplicate post?
W6FTW
NorcalPR is offline
post #4 of 4 (permalink) Old 02-24-2010, 03:08 PM
Send a message via MSN to Elton
i think one was enough
98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
07 Tundra 5.7L 4x4 Limited Double Cab
90 acura integra b18b daily driver
Elton is offline
Synthetic winch line Toyotec77 Early Tacoma Tech 35 03-10-2010 08:51 PM
Synthetic Winch Line SCYotaMan Wanted 12 11-02-2008 06:49 AM
Synthetic Winch Line howyadoin Tech/Tricks 4 04-16-2008 10:46 PM
Synthetic winch line Don_G General Discussions 19 03-06-2008 07:13 AM
Where should I buy synthetic winch line? vanguard Off Topic 12 06-15-2006 08:43 AM
