2005 taco SAW/AllPro-height/weight settings - TTORA Forum
post #1 of 5 (permalink) Old 04-28-2012, 10:05 AM Thread Starter
kala's Avatar
I installed an AP front bumper on my 05 with SAW 2.5s and 305/70R16 Swampers. The tires were only put on the other day and rub on full lock. I was previously running 265/75s and had no clearance issues. Im also running no sway bar. I just bought a 10k winch and want to install it.
With the smaller tires I didnt have a need to go higher on the c/o. Its still at stock settings, except the nitrogen is only filled to 120psi in the front. Im thinking of adjusting it an 1-1.5"s higher to help clear the tires. Am I going to run into any problems with the SAWs? Is the winch/bumper too much weight to be running on SAWs adjusted that high? Anyone use this set up in the desert/dunes?
If I need to, i'll go back to 265/75s and keep the ride height lower. I understand this set up may be a lil harsh on stock susp components, but fck it, I cant afford LT right now.
I'm Dirk Diggler and you're not.
kala is offline
post #2 of 5 (permalink) Old 04-28-2012, 11:55 AM
Tiny red truck
johnecon2001's Avatar
What height were you running previously? Do you have aftermarket UCA's?
ARB ~ Bilstien ~ Doug Thorley ~ AllPro ~ Desert Fab ~ Hankook ~ PowerMaster ~ Stubbs ~ Tom Woods ~ Total Chaos ~ TRD Trail Team ~ Bovads ~ Wheelers ~ Nitro Gear
johnecon2001 is offline
post #3 of 5 (permalink) Old 04-28-2012, 07:46 PM Thread Starter
kala's Avatar
Stock uca's and didnt adjust it. it was a good height installed. now i need to make it higher. I didnt plan for extra weight.
kala is offline
post #4 of 5 (permalink) Old 04-28-2012, 09:56 PM
Tiny red truck
Just be careful how high you go. The max you can go with stock UCA's is 2.5". Taller than that, and you won't be able to get a proper alignment out of them.
post #5 of 5 (permalink) Old 04-29-2012, 12:27 AM Thread Starter
kala's Avatar
Yeah, that's what I was going for, maybe slightly lower, but just around that height. I'll get to adjusting it tonight and i'll take it out tomorrow. I just didnt wanna be busting my saws!
kala is offline
keeping stock height with winch/allpro bumper hockeyplayer4 Suspension 7 10-07-2011 07:56 PM
Coil Length/Weight vs Ride Height questions blkrstr21 Long-Travel Suspension Tech 3 12-10-2009 12:35 PM
2005+ AllPro LT Hayhauler Wheels/Tires/Suspension 32 06-12-2009 12:42 PM
My Taco needs some height XJMedic Suspension 31 04-23-2006 07:52 AM
Weight of your sas taco... Tacominator Solid Axle Swap Tech 9 03-11-2006 01:28 AM
