I have a 2K Tacoma V6 Extra cab 4WD.
About 14 years ago I lifted it, but I can't remember what the specs were. I'm looking to replace the (now flat) leaf springs and front coils. I figured can add a bit of lift to the leafs. The front will be Sway-a-Way Racerunner coil overs, 0-3" adjustable.
The front spacer is a cornfed that measures 1.5". The rear has greasable shackles that measure 6.25" on bolt centers. I thought it was Daystar, and it looks just like it, but they are only 1.25" lift.
If my math is correct, the front should be a 3" lift and the back is 1.5" in the back. The problem is I seem to remember 2.5" front and 2" back.
Here is my math. The lift in the front should be about 2x the spacer height?
1.5"x2 = 3"
The lift in the back should be 1/2 the added length to the shackle?
Factory Shackle (Guessed from online info) on center.
85mm/25.4"/mm = 3.34"
Current Shackle
6.25"
Lift
(6.25-3.35)/2 = 1.45"
Can anybody confirm this?
1.5"x2 = 3"
Current Shackle
6.25"
Lift
