05-06 write up??? - TTORA Forum
post #1 of 6 (permalink) Old 05-07-2007, 06:29 PM Thread Starter
06statechamp's Avatar
05-06 write up???
Im getting ready to install rear bilstein 5100's on my tacoma this weekend, with my 3" toytec lift. Does anyone have any write ups for the 05-06 tacomas on how to install the rear break lines, and how to bleed the breaks.
thanks
06statechamp is offline
post #2 of 6 (permalink) Old 05-07-2007, 06:32 PM
MrGrimm's Avatar
rear brake lines.
take off rear brakes, install new ones. bleed lines. very simple. search, i did this a month ago and found all of the information on here.
MrGrimm is offline
post #3 of 6 (permalink) Old 05-07-2007, 11:42 PM
You don't need to extend the rear line. But if you want to, just use a spacer between the brackets.
05 Gold SB DC 4x4, Hoes, TC arms, TSB leaf pack, Bilstein 5150's, Timbren bumps, limit straps, locker mod, locker skid plate, one piece rear driveshaft, blah, blah, blah
Definition of the day:
Bozone (n.): The substance surrounding stupid people that stops bright
ideas from penetrating. The bozone layer, unfortunately, shows little sign
of breaking down in the near future
mojavegold is offline
post #4 of 6 (permalink) Old 05-08-2007, 02:28 PM Thread Starter
Huh? Toytec said i'd have to get the break line extenders b/c the stock ones was to short
post #5 of 6 (permalink) Old 05-08-2007, 06:32 PM
Hey mojavegold do you have a pic of your brake line spacer? Thanks.
http://keepandbeararms.com/
Support our troops
Wallygator is offline
post #6 of 6 (permalink) Old 05-09-2007, 12:56 AM
Here ya go. Just carefully bent the lines more vertical and welded a 1.50 inch spacer tab between the brackets. Works like a charm.
write-up article on my FJ OFRD_GRL FJ Cruiser Tech 18 10-27-2006 06:26 AM
Short write up on CBI mr.trd Fabrication/Tools 3 10-25-2006 12:39 PM
A/C to air compressor write up? Lucky13TRD Performance/Engine/Exhaust 2 07-31-2006 09:42 PM
LCE Header write up? wslytoy Performance/Engine/Exhaust 25 03-22-2006 02:45 PM
How-to write-ups Fishbone Tech 6 10-19-2005 06:30 AM
