Toyota 9.5" Land Cruiser Semi Float Nitro Xtreme Aluminum Diff Cover - TTORA Forum
post #1 of 11 (permalink) Old 12-27-2014, 10:40 PM Thread Starter
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
Nitro Aluminum differential covers are extremely thick and have been thoroughly tested in Moab, King of Hammers, and numerous other locations, proving they will handle the rocks, roots, stumps, and anything else you can throw at them. Finned aluminum dissipates heat faster than steel reducing the operating temperature inside your differential and extending the life of your components. Recessed bolts completely eliminate the potential for bolt sheering when crawling over rough terrain. Aluminum can't rust and a Nitro aluminum differential cover will keep your undercarriage looking great all year round. Our wide selection of available covers makes it possible to equip both the front and rear differentials with Nitro covers on many vehicles.
Fits Land cruiser 9.5" Semi-Float axles only, not Full-Float. Also has the same bolt pattern as 1955-1962 Chevrolet Truck with Drop-Out, C-clip Axles and rear cover.
Check them out here
  • Differential: Toyota 9.5", GM 1955-1962 Truck
  • Material: Aluminum
  • Differential Bolts: 10 included
  • Manufacturer: Nitro Gear & Axle
  • Warranty: 1 year*
  • Reinforced aluminum protects better than OEM tin covers.
  • Aluminum material helps dissipates heat.
  • Increased oil capacity.
  • Fill and Drain plug for easy maintenance.
  • Recessed bolts.
  • Rust-proof metal.
  • Wide selection.
  • Made in USA.
JTSDIFFS is offline
post #2 of 11 (permalink) Old 02-16-2015, 02:01 PM Thread Starter
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
Bumping this back up, check out all our different differential covers:
We carry covers from all the top manufacturers including Nitro, ARB, Riddler, Solid, Rockcrusher, Teraflex and many more. If you need a quote or have any questions let us know.
JTSDIFFS is offline
post #3 of 11 (permalink) Old 04-02-2015, 09:35 PM Thread Starter
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
Check out Jordan of JRT Offroad Racing taking his chase truck up Potato Salad Hill at EJS today. Jordan is running NITRO differential covers, Detroit lockers, and an assortment of other NITRO gear and axle products:
JTSDIFFS is offline
post #4 of 11 (permalink) Old 07-01-2015, 09:53 PM Thread Starter
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
We make differential covers for many different applications ranging from trail rigs to tow rigs and everything in between. Check them all out here:
JTSDIFFS is offline
post #5 of 11 (permalink) Old 04-02-2016, 10:23 PM Thread Starter
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
Made in the USA Nitro X-Treme Aluminum diff covers look great, help keep your axle cool and are extremely strong (proven in Ultra 4 racing applications). Nitro makes them for all common applications and we stock virtually all of them in both our warehouses.
Starting at just $139.99, check them out here.
You can find all the various differential covers we stock from different manufacturers here.
JTSDIFFS is offline
post #6 of 11 (permalink) Old 06-16-2016, 10:55 AM Thread Starter
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
Besides NITRO differential covers, we also stock a few other manufacturers covers. Including the ever popular and extremely durable nodular iron ARB differential covers. Check out all the ARB covers HERE.
JTSDIFFS is offline
post #7 of 11 (permalink) Old 07-10-2016, 10:55 PM Thread Starter
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
NITRO differentials covers and durable and lightweight, we stock all the popular models too! Click this link for pricing or call 866 349 6801 and speak with one of our Differential Experts to learn more!
JTSDIFFS is offline
post #8 of 11 (permalink) Old 07-19-2016, 01:23 PM Thread Starter
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
The first few of these new Nitro Alloy covers in red powdercoat have started shipping with a big batch in production shortly. Dana applications available to order now! Click here for details.
JTSDIFFS is offline
post #9 of 11 (permalink) Old 10-24-2016, 02:49 PM Thread Starter
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
Most oils today are 'Multigrade' oils, which means that the oil is defined by 2 viscosity grades (i.e. 10w-40, 5w-30, etc). Multigrades were developed more than 50 years ago to avoid the requirement of using thick oil in summer and thin oil in winter. The W stands for winter, not weight, which means that the oil has a certain viscosity/flow at low temperature. A lower 'W' number means the oil performs better in cold temperatures. The non 'W' number indicates the oil viscosity level at 100C (212F).This is a fixed limit, all oils that end in the same number (30) must meet the limits.
We recommend using 85w-140 in differentials. Whether you are changing out a differential cover, or just replacing the fluid, it's important to use the right oil in your diffs.
JTSDIFFS is offline
post #10 of 11 (permalink) Old 01-04-2017, 04:51 PM Thread Starter
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
Don't forget about a new differential cover when you're upgrading your gears or differential parts. They are cheap insurance against rocks and obstacles on the trail. You can check out all the differential covers we stock, HERE.
JTSDIFFS is offline
post #11 of 11 (permalink) Old 04-18-2017, 09:07 PM Thread Starter
Differentials!
TTORA GOLD Sponsor
JTSDIFFS's Avatar
Differential covers are always in stock! Whether you're rock crawling, towing heavy trailers, or building a street car; we have the covers to suit all your needs. Check out all the different ones by following the link below:
Differential Covers at JustDifferentials.com
JTSDIFFS is offline
Ford 9" Nitro HD 3.25" Billet Aluminum Drop-Out Housing JTSDIFFS J.T.'s Differentials & Axles 0 11-24-2013 06:37 PM
GM 10.5 14 Bolt Full Float 40 Spline Nitro Steel Spool JTSDIFFS J.T.'s Differentials & Axles 0 11-18-2013 11:10 AM
BTF Toyota 8" Diff cover tmorgan4 Parts/Electronics/Wheels/Tires 0 10-15-2009 03:16 AM
BTF Toyota 8" Diff cover tmorgan4 For Sale/WTB in CO 1 10-06-2009 09:38 PM
BTF Diff cover for toyota 8" HillBilly_Young01 Parts/Electronics/Wheels/Tires 5 07-30-2008 10:17 AM
