Fj80 Help - TTORA Forum
post #1 of 17 (permalink) Old 12-20-2009, 06:24 PM Thread Starter
Fj80 Help
I'm posting this for my father who needs some info help. He has an fj80 vx Limited from japan which is his baby but he does like to wheel it alittle bit. Hes taken his running boards off for some clearence but hes concerned now about rocker damage. So its rock slider time, we've looked at slee's and a few others but they want almost $1000 by the time there shipped for sliders. I know landcruiser stuff is expensive but that seems steep for what they are. I'm just looking for some companys that make sliders that you've had good expirence with, I know theres lots of little companys out there makin parts.
The other question is have any of you guys takin your sway bars off to get some more wheel travel? And if so does it make the truck undrivable on the road or just some body roll? He has an old man emu 2.5" lift waiting to go in it and is just on the fence if he should take the sway bars off or not.
Any info would be awsome.
Cheers
01 taco trd, 34's, full custom skids, bumpers, sliders and stinger, tubed firewall, stage 3 dent kit.
85 pickup, 3" custom lift, 33's, built 22re, lots of crawling goodies soon.
02 Taco short cab step side sr5, all stock and has all my love.
ILoveCugars is offline
post #2 of 17 (permalink) Old 12-20-2009, 07:03 PM
Banned
custom sliders homemade or local shop
hunter4runner is offline
post #3 of 17 (permalink) Old 12-22-2009, 07:26 AM
Solid Rock off Road makes good sliders that are less expensive. THe cheapest route is to get the long trailgear sliders and fab your own mounts.
I'd leave the sway bars on unless you want to fab up a quick disconnect. These rigs are top heavy enough--I wouldn't risk having to do an emergency manuever with them off.
The rears have more than enough travel, but to get some more travel out of the fronts, simply pull one front control arm bolt(preferably the one to the rear) and replace it with a standard hitch pin and clip. Remove the pin for more flex off road, and MAKE SURE to put it back in when you are finished.
Clarification: There are six total front control arm bolts. Three per arm. One attaches to the frame and two attach to the axle--one in front, one in the rear. Remove the bolt that attaches behind the axle. Only remove one bolt total.
I'd also get the castor correction bushings to help with driveability after the lift.
1995 T100, beater edition
1997 Land Cruiser, Collectors Edition
2001 Sequoia Limited, family wagon
2002 Camry, commuter chariot extraordinaire
Klierslc is offline
post #4 of 17 (permalink) Old 12-22-2009, 08:23 PM Thread Starter
The trail gear sliders is a good idea i like that.
Ok thats what we were both thinking that no sway bars and coils could be scary. The quick disconnect idea seems pretty solid tho.
Caster, camber correction bushing kit came with his OME kits so no worries there.
Thanks for the info man.
post #5 of 17 (permalink) Old 12-23-2009, 06:58 AM
The hitch pin mod will give you more travel than the sway bar disconnect, but you could do both if you really wanted to free up the front end.
I can't get you a link because I can't access it at work, but search over at IH8mud for info on the trailgear sliders. User "Box Rocket" did a nice write up with pics in the 80 series section.
Klierslc is offline
post #6 of 17 (permalink) Old 12-23-2009, 01:00 PM Thread Starter
Hes lookin for alittle more wheel travel so I think the hitch pin mod would work well. He doesn't push it really hard.
I'll check out the Mud write up. The trail gear sliders with the gusset kit and maybe some plating on the frame should work pretty well. just gutta figure out a way around the cat on the passenger side cuz I don't think you could mount a straight leg from the slider to the frame in that spot.
post #7 of 17 (permalink) Old 12-24-2009, 09:15 AM
http://forum.ih8mud.com/80-series-te...yone-else.html
Here is the link. Some of his pics are down, but it still should be pretty helpful
Klierslc is offline
post #8 of 17 (permalink) Old 12-24-2009, 09:21 AM
http://forum.ih8mud.com/80-series-te...-93-fzj80.html
more pics in that thread too.
Klierslc is offline
post #9 of 17 (permalink) Old 03-06-2010, 08:18 AM
Bear's Chauffeur
98taco4x's Avatar
Send a message via AIM to 98taco4x
Mossyrocks on here has done some amazing armor for a friend of his 80. Front and rear bumbers and sliders. Pm him for some pics. If nothing else his sliders are badass and nicely priced.
98 Tacoma 4wd xcab Sr5 2.7 auto, 265/75/R16 Kelly Safari TSR's, Mossyrock's Sliders, 881's and billy's, OME dakar leafs and shocks.
83 4wd pickup 22r some sort of lift, 5.29's, 36 tsl's, lockrite and spool, and a complete disregard for body damage alot more mods in the works
98taco4x is offline
post #10 of 17 (permalink) Old 03-06-2010, 08:42 AM
darwink1's Avatar
Just to clarify.
To do the hitch pin mod you remove the ds front axle mount bolt. The bolt that is closest to the front of the van on the ds.
As far as sway bars go, the dude I bought mine from has a vx w/o sway bars. He said it is managable and has been road tripping it like that for a while now. His is also lifted roughly 4".
That being said he did pick up a rear sway bar recently.
The ass end flexes pretty good out of the box so if youre going to mess w the sway bars either make quick discos for both front and rear (search mud) or try just removing the front one. See how it feels and then make changes as needed.
The ps cat area is a bitch when making sliders. There are a few threads on mud with pictures of peoples slider designs, the most popular seems to one "georges".
I made my own and just recently got them on. There are a couple pics here in the fab folder and more on mud in my "93 80 Beater" thread. It is possible to run the legs straight out from the frame if you bend back the rocker pinch weld. This gives you another 1" of clearance between your outriggers and the rocker. You just have to figure out what to do around the cats.
My advice would be to find a design you like and take it to a local fabber if you dont have the tools/knowhow to do it yourself.
Good luck.
D
2000 taco 4x4 SOLD!
93 FZJ80 Aussie locked, sporting 37's on a 2.5" lift. SOLD!
85 FJ60 The "hearingaid toylet". 350 ram jet, D60/arb, 14 bolt/arb, atlas 3.8, NV4500, 40" km2's and stuff.
06 Dodge power wagon beater dd...
1969 fj40 frankenplowvan
darwink1 is offline
post #11 of 17 (permalink) Old 04-19-2010, 01:13 AM
notyourmomslx450's Avatar
my
the hitch pin mod is great for giving a little more flex up front. Frees up the front axle nicely. I'd drop the front swaybar in a second. If you have to do any real wild emergency moves, you're probably gonna tip a lifted 80 anyway. For sliders, I've been looking at the ones 4xinnovations has. They look pretty decent and have some really good cat protection built in (which is also helpful if you live in Houston and people steal Toyota catalytic convertors like it's cool )
Jason
'99 Ford F-250 - Tow Rig slowly morphing into most excellent overlander
'98 4Runner Limited- SAWs, Camburg uppers, rear OME, Schrockworks front, 33" BFG A/T
"I got the jeep thing, now it burns when I pee!!"
notyourmomslx450 is offline
post #12 of 17 (permalink) Old 04-19-2010, 11:22 PM
vistataco's Avatar
Send a message via Yahoo to vistataco
Originally Posted by notyourmomslx450 View Post
my
Yes, the hitch pin pulled does add some extra flex up front but I still need to shave a little off the top of the control arms to prevent the tie rod from rubbing. I have heard this is fairly common...especially when your caster is corrected with plates like mine. Might also be because i have a Marlin tie rod and its a little thicker.
As far as the sliders go there are several out there. I had Jason Demello help me with mine.
So-Cal Staff Member STFU and WHEEL!!!
- 1997 Lexus LX450 Locked F/R, F.O.R. 3.5" coils with 7100's, 35" BFG KM2, DO sliders, DO bumpers, 4.88's, Yaesu 7900 (KJ6VCY), Superwinch 9500, and other do-dads. (Satin black)
2011 Lexus GS350 Pearl White (DD)
vistataco is offline
post #13 of 17 (permalink) Old 07-20-2010, 03:40 PM
colsoncj's Avatar
I fab'd my own sliders and some armor... pics in my build thread, link in the sig.
far as swaybars... removed mine within the first week, never put them back on. doesnt really bother me or affect my driving.
also look into armoring the rear lower control arm frame mount... tends to get beat up.
Cory
AR-TTORA NWAR SWMO NEOK Sub-Chapter TEAM Leader
OZARK MOUNTAIN CRUISERS
03 Chevy 3500 Duramax - Tow Rig
No wheelin rig at the moment, but do have a:
'11 Polaris RZR EPS
colsoncj is offline
post #14 of 17 (permalink) Old 07-20-2010, 08:06 PM
THAT guy.
SAR_Squid79's Avatar
4xInnovations makes 80-series Rock Sliders ($550 + shipping):
http://4xinnovations.com/pages/guarding/sliders.htm
~Jamie
2000 Tacoma TRD 4WD PreRunner
Supercharged. Locked. Armored.
Mountain: She can crawl it.
Ass: She can haul it.
"Roads? Where we're going we don't need . . . roads."
~Dr. Emmett L. Brown
My Rig My Trailer 4xInnovations
SAR_Squid79 is offline
post #15 of 17 (permalink) Old 12-11-2010, 02:07 PM
RIDEitINTOtheGROUND's Avatar
that is a nice deal!
I don't know a ton about other vehicles' sliders/frames, but I think the 80 sliders cost so much because the geometry is more complicated than say a tacoma that's nice n straight.
I just did mine and it cost ~300 for metal and pc, but it took me FO EVA to do (first fab project) so I see where the $$ comes in (jig must be pretty complicated)
RIDEitINTOtheGROUND is offline
post #16 of 17 (permalink) Old 05-19-2011, 09:18 PM
damaged110's Avatar
Send a message via Yahoo to damaged110
white-knuckle offroad has some great sliders
these things are built like a tank..http://white-knuckleoffroad.com/toyotafzj80.htm
1994 fzj 80 L/C OME lift dual batteries arb lockers (thank the wife for that) white-knuckle sliders 35 nittos arb bumper and icom 208H dual band and a yaesu ft-897d HF rig and gun rack
damaged110 is offline
post #17 of 17 (permalink) Old 12-17-2011, 03:25 PM
Land Pirates Off Road's Avatar
Clarification...
Taking off your anti sway bar does not give you more wheel travel, more articulation yes... But not more wheel travel. If you want more wheel travel, you need different springs and shocks...
Going with the hitch pin quick disconnect is a great idea to temporary disconnect the anti sway bar... But make sure you hook them back up while on the street...
Drive Harder, Faster, Safer & keep it rubber side down!
https://www.facebook.com/LandPiratesOffRoad
Landpiratesoffroad.com
Land Pirates Off Road is offline
Rolled FJ80.... howyadoin For Sale/WTB in AZ 13 04-04-2009 04:20 AM
TACO or FJ80 BOVADS Off Topic 22 03-25-2009 01:03 PM
FJ80 parting out on CL fjcruzer For Sale/WTB in CO 0 01-12-2009 01:20 PM
locked FJ80 ajordan1975 Hot Deals/Good Finds 2 12-30-2008 12:38 AM
fj80 lifts toyboy Land Cruiser Tech 6 02-20-2007 07:45 PM
